Go Back   Digit Technology Discussion Forum > Portables, Peripherals and Electronics > TVs / Monitors
TVs / Monitors Want to buy a TV or a monitor? Ask our members what they think before you do that.
Old 09-09-2007, 10:09 PM   #1 (permalink)
godsownman's Avatar
Default Samsung LCD 19" power supply
Hi guys,
I know this question may be a little out of place here but I need some help.
Samsung sells their 19" montors (Samsung 920BW ) monitors with a in-box power supply cable that is a 15 amp power supply ( The big one we use for water heaters).
The wall socket that I have is a 5 amp power supply socket( small ordinary one) .
What will be the implications if I buy a convertor and convert the 15 amp plug to 5 amp.
Can someone please explain this concept to me.
Also is it good if I connect the monitor at the back of the cabinet in the socket provided( SMPS socket ) , but for this I will have to purchase the cable. Keep in mind samsung gave a 15 amp plug ( and thats the reason I ask).
Is the direct to the wall option better or the second one.
Please give me your views. Thanks.
I think I posted this in the wrong section, I have now reposted this in the right section -> Hardware.
Please lock this thread if required.
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
Old 09-09-2007, 10:28 PM   #2 (permalink)
dOm1naTOr's Avatar
Default Re: Samsung LCD 19" power supply
An LCD consumes far less power tha CRTs. A 19" one consumes only 30~32W. That is less than a tube light. So no problem if u convert the adapter from 15amp type to 5amp.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Power Supply gmanog Hardware Q&A 36 05-02-2007 01:19 AM
Power supply kumarn_2004 Hardware Q&A 1 24-12-2006 08:43 AM
Power Supply / SMPS klinux QnA (read only) 25 09-01-2006 10:27 PM
Getting the right Power Supply gxsaurav QnA (read only) 29 09-10-2005 02:18 PM
AMD 64 Power supply impetus CPU / Motherboards 4 18-01-2005 11:59 AM
- by chris
