Go Back   Digit Technology Discussion Forum > Portables, Peripherals and Electronics > TVs / Monitors
TVs / Monitors Want to buy a TV or a monitor? Ask our members what they think before you do that.
Old 11-08-2006, 04:23 PM   #1 (permalink)
Default LCD Monitor
My choice for a new monitor is Samsung 17" TFT model. There are two models in the TFT Series from samsung and they are Samsung SyncMaster 713N and the Samsung SyncMaster 740N. What is the difference between the two?
hariharan is offline
Old 11-08-2006, 06:46 PM   #2 (permalink)
Ishan's Avatar
Default Re: LCD Monitor
Hey! i didnt find samsung syn master 713N any where in the site
http://www.samsung.com/Products/Moni...Specifications
see this for 740N
When was the last time when you did something for the first time?
So many words for the broken heart.....
for world wars. ishangajera.blogspot.com
Ishan is offline
Old 11-08-2006, 07:00 PM   #3 (permalink)
Tux Fan
shaunak's Avatar
713 is older and hence removed from their site. youll still find it with the dealers.
As the price difference between the two is very less idd suggest you go for the 740 as its better at displaying fast moving immages.
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 11-08-2006, 08:45 PM   #4 (permalink)
Ishan's Avatar
Ok..so if its older and removed from the site..u shouldnt buy that..but should go with 740 N only..if u have too choose bw these two
Ishan is offline
Old 11-08-2006, 08:52 PM   #5 (permalink)
shashank4u's Avatar
go for philips model tested by digit in previous issues.
at around 11 k .
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 17-08-2006, 10:40 PM   #6 (permalink)
at around 11 k .
could u plz tell me the exact philips model.
Old 17-08-2006, 10:44 PM   #7 (permalink)
Hey here is the aks
arunks's Avatar
its 9999 i think
yours truly
arun
The aks!!
have a nice day
arunks is offline
Old 18-08-2006, 06:41 AM   #8 (permalink)
nil_3's Avatar
In Samsung LCD 17" category, the best one is 770P but it is not available in India(at least at the time of my purchase one month ago). So I have to go for 740N. Working superb so far as LCD TFT is concerned.
I think these multi-national companies use our country for sell of their old stock. You will not find a new/latest product here.
P4 3.0GHz Dual-core.
Intel 945GNT MoBo.
1GB RAM.
Seagate 160GB SATA HDD.
HP 16X Dual Layer DVD Writer.
Coloursit 450Watt SMPS with NAVTECH cabinet.
Samsung SyncMaster 740N TFT LCD 17" monitor.
nil_3 is offline
Old 18-08-2006, 01:09 PM   #9 (permalink)
JGuru's Avatar
You can buy either SamSung or ViewSonic LCD monitor. SamSung's SyncMaster 770P is the best one.
When you are buying a LCD monitor look for these things:
* response time should be 6 ms ( not higher than that)
* Viewing angle. Unlike the CRT , the LCD monitors can't be viewed in every angle!!
When viewed beyond a certain angle, the Image appears dull, distorted!!
So look for greater viewing angle
* Also check for dead-pixels , stuck pixel.
stuck pixel - a dot whose color won't change
dead pixel - a pixel always appear black
JGuru is offline
Old 18-08-2006, 01:42 PM   #10 (permalink)
"Technologic"
Apollo's Avatar
My friend's waiting for the Syncmaster 770P. You should definitely go for that one, as far as buying a Samsung LCD monitor is concerned. Plus, nowadays the price differences between the various monitor do not tend to be that high... so even if you buy it a bit late, make sure you buy the best one that there is(within your budget).
One great use of words is to hide our thoughts.
Apollo is offline
Old 18-08-2006, 02:25 PM   #11 (permalink)
UBERGEEK
PCWORM's Avatar
Also look for acer models...
PCWORM is offline
Old 18-08-2006, 08:15 PM   #12 (permalink)
thanks lot could anybody tell me how long would it approximately take for the Samsung 770P to arrive in India?
Old 18-08-2006, 08:52 PM   #13 (permalink)
JGuru's Avatar
@Hariharan, just call this SamSung number 3030 8282 for any queries , from anywhere
in India.
JGuru is offline
Old 18-08-2006, 10:42 PM   #14 (permalink)
thanks a lot for the ph no JGuru
Old 19-08-2006, 06:10 AM   #15 (permalink)
Alfansey06's Avatar
i found the link for : LCD Vs CRT
http://www.viewsonic.com/monitoruniversity/lcd.htm
Alfansey06 is offline
- by chris
