Results 1 to 4 of 4
Thread: Best LED Tv...
  1. #1
    EXTREME Siddharth_1's Avatar
    Mar 2011
    Default Best LED Tv...
    Requirements-
    • Full HD
    • Slim design
    • Loud Audio
    Which is the cheapest LED that fulfills these requirements?
    Plzzz reply...
    PC
    i5 2500k | MSI Z68MA-ED55(B3) | RipjawsX (2X4GB) | MSI R7950 2PMD3GD5 | Seagate 1TB 7200.12 | CM GX-550W | CM Elite 430|Samsung 22x | BlackWidow Ultimate DragonAgeII Edition8-) | MX518 | Goliathus Fragged Control Editon
    + Lumia 720 + iPod Touch 32GB + PSP
  2. #2
    Broken In sumit05's Avatar
    May 2011
    Default Re: Best LED Tv...
    Budget?? size??
  3. #3
    Mar 2011
    Size-32inch
    Budget-cheapest which matches these requirements
    PC
  4. #4
    Explorer aroraanant's Avatar
    Mar 2011
    Aligarh>>>Delhi
    No particular budget?
    If you want a cheap and good LED TV then the best option is Samsung 32EH5000, you can get it for around 33k, if you are good at bargaining.
    HTC Incredible S | Nikon S8100 | Sony VAIO VPCEG25EN | Macbook Pro 13"|
    Sony 5.2ch Component home Entertainment System HT-M5
