Results 1 to 12 of 12
  1. #1
    May 2011
    Default 40-42 inch LED TV
    Hi,
    I'm planning to buy full HD LED TV(non 3D). I'm open to Sony, Samsung and LG brands.
    Picture quality is most important.
    Secondly, if possible, it should be able to play big full HD files(4-8GB) from pen drive.
    Thirdly, sound quality is important.
    Lastly also prefer a smart TV(although not as important)
    Budget: less than 70K.
    Picture quality should be best
  2. #2
    Explorer aroraanant's Avatar
    Mar 2011
    Aligarh>>>Delhi
    Default Re: 40-42 inch LED TV
    If you want something cheap and good then get Samsung 43 Inches HD Plasma PS43D450 which is really good for its price but the only cons in this is it is HD and not Full HD.
    You can buy Samsung 40D5900 which costs around 60k, not 40D5000 and 40D5000 because the price difference in all the 3 models is very less and among all three 40D5900 is the best and it is a smart TV.
    Don't buy 40EH5000 and 40D5003, they are not good, even 40D5000 is better than them.
    Well there have been some recently launched models i.e. 40ES5300 and 40ES5600 from samsung but I don't know how are they as I haven't seen and compared them with other models.
    Not considering sony here as the quality of samsung is better than it and also sony doesn't support many video formats when you connect a USB drive to it.
    HTC Incredible S | Nikon S8100 | Sony VAIO VPCEG25EN | Macbook Pro 13"|
    Sony 5.2ch Component home Entertainment System HT-M5
  3. #3
    May 2011
    Thanks for recommendation.
    Actually my mom prefers Sony TV after comparing them alongside and she'll be the one using them.So can sm1 please recommend Sony model?
  4. #4
    Mar 2011
    Aligarh>>>Delhi
    Samsung is better than Sony so that is the reason I suggested you that
  5. #5
    Jun 2012
    Sony is the best t.v with the good picture quality and wireless usage for browsing on internet.
  6. #6
    Mar 2011
    Aligarh>>>Delhi
    I don't think so.
    Will you please elaborate.
  7. #7
    Alpha Geek RON28's Avatar
    Apr 2012
    i don't want any sony vs samsung war please, but OP should consider sony also in his list because i have been to CROMA many times and to me, SONY has amazing clarity, natural colors and crisp pictures, i don't know whether its because of there BRAVIA engine. and yes do not ever consider SANSUI, i was shocked to look at those unnatural and dull colors.
    i would suggest OP that go to a near by CROMA and have look a all LED'S and then decide.
  8. #8
    Mar 2011
    Aligarh>>>Delhi
    Sony supports only a few video format, so it becomes a big trouble when you connect a USB drive to play videos/movies.
  9. #9
    rated R ritvij's Avatar
    Apr 2010
    Gorakhpur
    buy samsung ua40d5500.. its great for 55k....
    I love TDF.. Everyone loves TDF.. Therefore, I am everyone.. :Problem? :D:
  10. #10
    Dec 2011
    Quote Originally Posted by aroraanant View Post
    can you tell me why 40EH5000 & 5003 are not good. and how much 40D5000 costs compared to these models?
    actually i am planning to buy 40inch LED. we know someone from Sony showroom, he can get us for lower prices, how much lower will be only known after finalizing the model. I don't want to commit to Sony without fully checking out best price offered by Samsung.
    on the paper Samsung 40EH5000 seems way cheaper than Sony EX 520.
    I know Sony TVs read way less formats compared to Samsungs. But i willing to to sacrifice that option as i will be using laptop connected to tv with hdmi providing Sony TVs have better picture clarity than Samsungs and have similar prices.
    i have some options here Sony EX520, Samsung 40D5000, LG LV 3500.
  11. #11
    Mar 2011
    Aligarh>>>Delhi
    EH5000 is 100Hz while D5000 is 200Hz, there is a lot of difference in the picture quality of both.You will get to know when you will compare them side by side.
    You can get 40D5000 for under 55k easily.
    And it is better than EX520, I have compared them so that is why I am saying so.
  12. #12
    Dec 2011
    EH5000 seems to be bad as you have said. I am searching for D5000 in stores in hyderabad, they seem to be quickly going out of maket. meanwhile i found 40C6900 for 61K. can you plz reply in this thread,Samsung 40C6900 for Rs 61K, Is it worth?
    we can continue discussion there
  1. 40' inch LED Sony best or 40'inch LED Samsung best
    By haithinkdigit in forum TVs / Monitors
    Last Post: 01-11-2011, 01:04 AM
  2. 32 inch led/lcd under 25k
    By abhijeet2021 in forum TVs / Monitors
    Last Post: 01-08-2011, 10:35 PM
  3. Macbook pro 13 inch or dell xps 13 inch
    By coolest111 in forum Hardware Q&A
    Last Post: 07-05-2010, 01:46 AM
  4. ACER 23 INCH or SAMSUNG 22 INCH??
    By manusag in forum Hardware Q&A
    Last Post: 26-04-2009, 08:56 AM
  5. 19 inch monitor or 15 inch lcd ?
    By dipdude1 in forum TVs / Monitors
    Last Post: 04-04-2005, 10:03 AM
