Results 1 to 8 of 8
24-04-2012, 07:12 PM #1
Suggest monitor which can support a PS3
I recently shifted from Home to Bangalore for job, and I only have my PS3 with me.
I dont plan to buy a TV for it. I'm gonna buy a new PC soon, but the monitor first.
So suggest me the cheapest possible monitor which can support a PS3. I'm pretty sure there is no way a PS3 can be connected to a VGA input monitor, but if there is a way, do tell.
I dont have much idea about the Monitor models in the market presently, so suggest the monitor on which I can run my PS3.
Size and resolution doesn't matter, even a 16" with 1280x720 one will do, but the PS3 should be able to run on it.
And the cheaper, the better, I've just started earning.
Big dilemma, I miss my 42" TV at home.
25-04-2012, 07:01 PM #2
Re: Suggest monitor which can support a PS3
The only thing that i can tell you is that shell out 14k and get a 22inches Phipipls / LG fulll hd monitor which you can use with your pc and aswell as ps3. You will have to use HDMI cables Btw.
visit this link below to see your options :
TVs Price List India: TVs & Video Players: Flipkart.comSteam : noasarcangel
Steelseries : Winning Is Everything.
25-04-2012, 07:16 PM #3
There is a guy selling a 3D monitor from LG (passive) for 10k on IVG. MRP is 16k. Check it out. But he has no market feedback
http://www.indianvideogamer.com/foru...&#entry1390903
[GUIDE] Everything you need to know about the PS3 - Digit Technology Discussion Forum check this out too
™Spoiler:
25-04-2012, 11:57 PM #4
Seriously tell the me cheapest monitor and way to make a PS3 run on it.
Atleast suggest me a cheap DVi Monitor, and the stuff required for Video & Audio output.
I'm gonna buy a TV later on, I dont wanna spend now much on the monitor.
26-04-2012, 12:04 AM #5Right Off the Assembly Line
- Join Date
- Apr 2012
- Posts
- 1
27-04-2012, 04:37 PM #6
Kira wants an answer!
27-04-2012, 11:35 PM #7
AFAIK there's no 16" monitor with DVI port available. So, get any 16"monitor and use a VGA-DVI convertor with it.
IMO to use PS3 with ur monitor you will need an external TV Tuner.
But what's good in getting a 16inch monitor now and later getting a 22inch for PC. Instead get a 22inch or 24inch now, use TV Tuner with it and connect ur PS3. DELL ST2220L or DELL2220M are good choice for 22inch monitors. Both have VGA, DVI and HDMI connectivity. Cost around 8.2k. BenQ G2220HDL is a cheaper option and costs around 7.3k.
30-05-2012, 01:28 AM #8Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 1
i bought a samsung monitor S23A350H ringgit Malaysia -RM 599.
The aim i bought this monitor not for pc but for ps3 gaming.
You can buy other monitor too but it must required some equitment :
1. Full HD resolution
2. HDMI cable
That is all. These information can help you.
Want to play MaxPayne3 & have multi Monitor support-Recommend a card please
By tinornit in forum Hardware Q&AReplies: 9Last Post: 11-06-2012, 03:09 AM -
Please suggest a tablet 3G having sim support in Rs. 15000
By arunks in forum Mobiles and TabletsReplies: 1Last Post: 21-02-2012, 01:39 PM -
Please suggest DVD Player with USB support
By vilas_patil in forum Chit-ChatReplies: 1Last Post: 10-04-2009, 08:31 PM -
Can Palit HD4850 512mb DDR3 card support my old CRT Samtron 56v monitor?
By dude09 in forum TVs / MonitorsReplies: 6Last Post: 07-03-2009, 11:38 PM -
will a compaq mv540 monitor support winxp??
By supersaiyan in forum Software Q&AReplies: 3Last Post: 06-05-2005, 09:32 AM
LinkBack URL
About LinkBacks
Gaming RIG
iΡod & iPhone 4 ♥
