How to play videos through usb on sony bravia bx32?
Results 1 to 14 of 14
Thread: How to play videos through usb on sony bravia bx32?
  1. #1
    Dec 2011
    Default How to play videos through usb on sony bravia bx32?
    Hello.
    i recently bought a new SOny bravia bx32. The problem is that i cant play the video files through usb. most of them are BRrips or BDrips that i get from frnds. Pls help me out. the files are detected when i connect the usb but wen i select play it just displays the message 'No playback' or something on that lines.
    Popular Gadget Deals
  2. #2
    Alpha Geek reniarahim1's Avatar
    Jan 2008
    Bangalore(KA) / Cochin(KL) , IND
    Default Re: How to play videos through usb on sony bravia bx32?
    one option would be to convert the media into the format which your tv supports or to use a media player.
    Dell Studio 1555 - Intel Core 2 Duo P8600 @ 2.40 GHz, 3 GB RAM, 500 GB HDD, ATI Mobility Radeon HD 4500 | PC - Intel Pentium G620 @ 2.60 GHz, Intel DH67CL, 4 GB RAM, 500 GB HDD | Nokia Lumia 720 | Moto-G 16GB
  3. #3
    Human Spambot Zangetsu's Avatar
    Jan 2008
    Soul Society
    @wolverine12: I guess the videos u r playing are MKV format.
    First check whether they r supported or not in your monitor
    HTC One V | Nikon D3100 | Apple Ipod Touch 4G | SM ES18 | Casio Edifice EX106 | WD My Passport 1 TB | Seagate Backup Plus Slim 500GB
  4. #4
    Nov 2011
    You need to re-encode them into mpeg4(h.264) format and they will play just fine. For that you need some good encoding software. Free or paid thats all.
  5. #5
    Jul 2005
    Bengloor
    if they are avi extension files, they should play.
  6. #6
    d3p
    d3p is offline
    PowerHouse d3p's Avatar
    Jan 2010
    Bangalore
    Sony TV's only supports Thumb Drives not more than some capacity & it play only mp4 & mp3, wav. [Note: It doesn;t support even usb HDD's also]
    Other formats are not supported.
    [IMG]http://cache.multiplayuk.com/b/1-2547442-560x95-3773-FF5519-FFFFFF.png[/IMG]
  7. #7
    Dec 2011
    thanks for all the help.
    it worked fine after encoding into mp4(h264) format.
  8. #8
    Undead!!! Sujeet's Avatar
    Dec 2011
    India
    Quote Originally Posted by d3p5kor View Post
    I own a sony bravia bx series 32' tv and till now i have used multiple storage media with it to play vids.... card readers/pmps and phones in storage mode/flash drives of upto 16gb all through usb port...and it is capable of palyin MPEG 2 encoded videos too
    [B]HCL ME[/B] | Intel i3 310M | 320 GB | 2 GB DDR3 1333 MHz |
    [B]HP ENVYM6 [/B]| Intel i5 3210M 2.5 GHz | 8GB DDR3 1600 Mhz | AMD Radeon 7670M | 1TB
    [B]Samsung Galaxy Tab 2[/B] |7.0 P31000
  9. #9
    Jan 2008
    Quote Originally Posted by wolverine12 View Post
    which software you used to encode it?
  10. #10
    Dec 2011
    India
    Quote Originally Posted by reniarahim1 View Post
    1.Video Converter Factory For Quick Conversion OF HD Video Clips(Gameplays/Walkthrough/Trailers,etc) using predefined mpeg2 profile
    2.Handbrake For movie conversion using custom settings
    although video converter factory is decent for long video conversion too and its free!!
  11. #11
    I am the night...I am... vickybat's Avatar
    Aug 2009
    Gotham City
    I suggest buying an external media player for the tv to play all files. Players like AC RYAN POHD, ASUS Oplay , WD mytv hd etc are good options and should be highly considered for anybody owning or buying an hdtv.
    Core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book ,Seagate freeagent ext hdd 1tb , hp dvd writer,Apc 650 va, logitech z313 , Micromax Funbook , Klipsch image S3 (IEM).
  12. #12
    savage Computing... savagex's Avatar
    Apr 2009
    Bangalore
    Sony cant play lots of formats. Big reason why i switched to Samsung. Cheaper, same performance as a Bravia and plays all video formats under the sun.
    AMD Phenom II X4 B40 (unlocked 3 cores of AMD Phenom II X2 550 BE) @ 3.4 GHz, Asus M5A97, 4 GB DDR3 Ram, MSI Cyclone R6850 OC edition
  13. #13
    Jul 2005
    Bengloor
    Quote Originally Posted by savagex View Post
    can it play wmv
  14. #14
    Right Off the Assembly Line pratzgh1's Avatar
    Jan 2012
    Quote Originally Posted by d3p View Post
    Dude, do some R&D and then write about all of it so confidently. I own a 40" BX420, which has a 500GB HDD always attached (powered through USB itself) and plays almost every format thrown at it. Only a few are not supported.
    Here's a pic of the manual:
    Yeah, I know that other sony's may not support this list, that is where the converters come in play
    RiG: C2D E7400 @ 3.78Ghz || Gigabyte G31M-S2l || 3Gb Transcend 800Mhz @ 1080Mhz || ATI Sapphire HD6850 || 750GB WD Caviar Black + WD 500Gb Caviar Green || Mron Alpha 700W || Logitech Z2300
    Portables: Soundmagic Es18 || Galaxy Nexus || Htc Explorer
  1. Replies: 7
    Last Post: 02-03-2012, 03:52 PM
  2. sony bravia LCD KLV22-BX300
    By navipta in forum Software Q&A
    Last Post: 11-07-2010, 11:35 PM
  3. Sony bravia {help needed}
    By napster007 in forum Hardware Q&A
    Last Post: 27-06-2010, 11:04 AM
