Need best LCD or LED Tv under Rs 15000/-
Results 1 to 9 of 9
Thread: Need best LCD or LED Tv under Rs 15000/-
  1. #1
    Alpha Geek Skyh3ck's Avatar
    Apr 2009
    Skynet
    Default Need best LCD or LED Tv under Rs 15000/-
    hi
    i need the best LCD or LED TV in market for price under RS 15000/-
    full Hd (or less)
    wall mount
    Pc connection (occasionaly)
    speaker(optional)
    and all other great feature
    Popular Gadget Deals
  2. #2
    I am the night...I am... vickybat's Avatar
    Aug 2009
    Gotham City
    Default Re: Need best LCD or LED Tv under Rs 15000/-
    Okay i just found the perfect TV for your budget.
    Its Philips 4000 Series 24PFL4505 & is fullhd as well. The price is Rs 15,890.
    But its only 24 inches in size. You will get bigger tv's i.e 26-32 inches in this price but none will be fullhd.
    Check here.
    Core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book ,Seagate freeagent ext hdd 1tb , hp dvd writer,Apc 650 va, logitech z313 , Micromax Funbook , Klipsch image S3 (IEM).
  3. #3
    Apr 2009
    Skynet
    Ok thanks suggest non hd in this price
    i will buy it on this 15 aug ...... There must be many offer on this day
  4. #4
    Aug 2009
    Gotham City
    ^^ For 2k more you can get Toshiba 32" LCD TV 32AV800E i.e Rs 17,490.
    Its a 32inch tv but has a native resolution of 1366x768.
    Check here.
  5. #5
    Wise Old Owl pulkitpopli2004's Avatar
    Jul 2010
    D!ll!
    ^^ why to get a HD ready TV..
    he should go for Philips only i think.. thats a gr8 deal for him in his budget..
    I'd explain it to you, but your brain would explode... Trust me
    i5 760, Asus P7P55D-EVO, Zotac GTX 460, VX550, Win7 64bit,4GB RAM @1600MHz, WD 500GB+1.5TB Caviar Black, NZXT Phantom
  6. #6
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata, India
    Quote Originally Posted by vickybat View Post
    Check here.
    Instead of buying a hd ready tv, he should opt for full hd tv as Philips is available inside his budget, right?
    [B][U]Inactive in TDF.[/U][/B]
  7. #7
    Aug 2009
    Gotham City
    I gave him the philips option earlier and he should go for it considering its fullhd.
    But op insisted on getting a bigger non fullhd tv at same price. So i gave the toshiba.
    Its completely upto him.
  8. #8
    Aug 2011
    u can go for reilance own led tv or akai or mitashi. But none of this are good. Increase your budget a little and get yourself a good 32" LCD full hd tv.
  9. #9
    Apr 2009
    Skynet
    well i was in Vijay Sales
    and all they had crap.
    one AOC 32" TV 1366 x 768 was for 14000 under exchange with 29 " TV with remote.. and without exchange was 17000
    i bargained will 15500, but he could not get it to that price...
    another tv from Samsung 24" full HD... however when i asked him to show me some HD content, he rejected and told me that i can check it once i take it home.....
    i also heard that Vijay sales,, sales crap things..... and it does not work more.....
    will hunt more for the TV
  1. Want to buy a notebook under Rs 15000?
    By clerkman1612 in forum Laptops and Netbooks
    Last Post: 14-07-2012, 07:18 PM
  2. Need Help Assembling a PC for 15000
    By bittutora in forum PC Components / Configurations
    Last Post: 04-06-2012, 06:33 PM
  3. Pc<15000
    By aniketana in forum PC Components / Configurations
    Last Post: 28-04-2011, 11:26 AM
  4. New PC within Rs.15000/-
    By rohitshakti2 in forum PC Components / Configurations
    Last Post: 17-03-2011, 03:57 PM
  5. xbox 360 for rs 15000 !!
    By Davidboon in forum Technology News
    Last Post: 21-10-2008, 03:48 PM
