Page 1 of 2 1 2 LastLast
Results 1 to 30 of 34
  1. #1
    Alpha Geek masterkd's Avatar
    Feb 2011
    Kolkata
    Default Display for 12K!
    Please help me to select a monitor.
    Screen size: 24"
    Budget: can go upto 12.5k if required but want to do with as less as possible
    Usage: gaming, watching movies, sharp text production is also required
    planning to buy it today evening. So please hurry guys. Thanks in advanced.
    i5 2500K|P8Z68 V PRO|560Ti Hawk|G Skill 8GB 1600MHz|SG 500 GB|WD Passport 1TB|TX850V2|690II Advanced|BenQ G2420HD|Razer Cyclosa Bundle|Razer Goliathus|APC 1.1 KVA|TP LINK WR841N WiFi Router|Windows 7 X64|XBOX 360 wireless controller
    Samsung Galaxy Note
    Steam: masterkdxp
  2. #2
    The Vagrant Seeker GhorMaanas's Avatar
    Jul 2011
    Default Re: Display for 12K!
    Hi,
    i have been using Benq G2420HD full HD 24" monitor for the past 1 yr or so, and am highly satisfied with it ! got it for ~11.5k. its true 24". bezel is not broad so the screen looks more fuller & prominent. black is truly deep. has got a vga port, hdmi port, and dvi port, a 3.5mm audio jack. VFM product ! you wont be disappointed with this !
  3. #3
    Feb 2011
    Kolkata
    @kilroyquasar,
    thank you for the suggestion. Could you please tell me a bit about Benq's service quality in india. Do they provide on site service?
    @tenida,
    i need a monitor, not a graphics card.
    Samsung Galaxy Note
    Steam: masterkdxp
  4. #4
    Gadget Freak Tenida's Avatar
    Aug 2008
    Calcutta
    Ohh sorry Deleted
    Benq serviced by Neoteric Informatic ltd.They provide good after-sales service.No onsite facility is not there.
    Look at the review of Samsung P2350
    My Gizmos O_O
    ||Core i7 2600K | MSI Z68A GD80 | MSI GTX560Ti ||
    ||F&D A555U | Roccat Kave | Funbook | LG Optimus L9 (W) ||
  5. #5
    Jul 2011
    tenida is correct....as per your query, i dont think there's on-site support for benq...i bought my monitor from a good seller, and he assured me that he'll handle the case if any issue arises...none so far....he's a good dealer too...recently one of my friends at nagpur encountered a dead pixel in his benq monitor, and he approached benq through his dealer, and his piece was promptly replaced with a spanking new one within 2 days ! so it would be a lot wiser to buy the monitor from your trusted/reputed seller. be in no doubt my friend, benq has superb monitors ! mine is kicking rock-solid !
    as far as P2350 is concerned, i think it doesnt have an HDMI out...may be am wrong...need to check, and its also 23.5", not 24" true....also, i will share some links with you below...i was in exactly the same fix in which you are in now, about more than an year ago....the guy who started the thread in the 1st link below helped me buy my monitor...pls go through them, they're quite informative......also, if you want i could share a video with you, which's unfortunately been removed by the owner from youtube now...from that video you can get a good idea of the humonguous size of benq vs samsung/other monitor(s) shown in the video...here are the links though :
    Samsung P2350 Vs. BenQ G2420HD (WHICH ONE TO BUY)
    Samsung P2350 or BenQ G2420??
    BENQ : Would you advise ??
    also, you could chk out benq's E2420 model...retails for ~12-13k i guess...has 2 HDMI ports, a couple of USB ports too, etc....has speakers too, but anyway they dont sound much good...nevertheless you can easily use the headphone jack.....you can get this model too if it fits your budget....chk this :
    Compare BenQ E2420HD and BenQ G2420HD Computer Monitors / Comparisons / LCD Monitors catalogue
  6. #6
    Here I Comes You Viruses Geek-With-Lens's Avatar
    Jun 2011
    Mumbai
    Buy Dell U2311H You Could get it for 13.5K.
    Back To ThinkDigit Forum After Long Break.
    Razer Carcharias 8-)
    Swan M10 :-D
  7. #7
    Jul 2011
  8. #8
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    For gaming, BenQ G2420HD is good but the Dell one is an IPS panel based monitor and so having better viewing angle and good color reproduction. SO watching movies will be fun on it.
    Also have a look at Asus ML238H BK/2MS/AP, available within 12K. It is also a great display.
    AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
  9. #9
    Feb 2011
    Kolkata
    Dell U2311H is way above my budget
    please do not suggest anything above 12.5k
    need to check some reviews on asus ml238h
    Samsung Galaxy Note
    Steam: masterkdxp
  10. #10
    Jun 2011
    Mumbai
    Swan M10 :-D
  11. #11
    Aug 2008
    Calcutta
    Check the Samsung PX2370 also.Don't know about the price but its great monitor.The color reproduction of Samsung monitors are true to life.
    My Gizmos O_O
  12. #12
    Feb 2011
    Kolkata
    afaik its around 15k..so no way i can afford that!!
    @kilroyquasar,
    have you measured the screen..some people saying it is 23.6 and does it comes with a dvi cable??
    Samsung Galaxy Note
    Steam: masterkdxp
  13. #13
    Super Moderator Skud's Avatar
    Jun 2004
    10 light years away
    Get Benq G2420HD, eyes closed. It's total VFM.
    Gaming Rig:i7 2600K | N620 | P8Z68 Deluxe | 2x4GB RipjawsX DDR3 1600 | Vertex 3 120GB | Logitech G510 | Logitech G400 | Sapphire 6950 1GB | BenQ G2420HD | Corsair HX750 | Lancool K62
    HTPC Rig: C2D E7400 | EP45-DS3R | 2x2GB DDR2 800 | MS Wireless Desktop 2000 | Gigabyte 5770 | Samsung 32" | Seasonic SII 520W | Silverstone LC10
    Audio Gear: Altec Lansing VS2421 | ASUS Vulcan ANC | HiFiMan RE-0
    Storage: 2x250GB | 3x500GB | 3x1TB | 3x2TB
    Android: Galaxy R | Galaxy Y
  14. #14
    Feb 2011
    Kolkata
    so I'll be going for Benq G2420 or E2420.
    one more question, if i connect one device in dvi and another in hdmi, can i switch on the fly?
    Samsung Galaxy Note
    Steam: masterkdxp
  15. #15
    the m0nk who sold his PC! MatchBoxx's Avatar
    Apr 2011
    Kolkata...the ultimate city!
    Asus ML238H, my crush
    Intel i5-2400 || ASUS P8H77-M || G.Skill RipjawsX 8GB (4GBx2) || MSI HD6850 Cyclone PE/OC || Corsair GS600 || Cooler Master Elite 431(Side Panel) || Dell ST2220L || Logitech G500 || Edifier C2 || APC 1.1 kVA || Seagate GoFlex 1TB
  16. #16
    Jul 2011
    G2420HD is true 24" ! and comes with a VGA cable only...chk your inbox now.
  17. #17
    Jun 2004
    10 light years away
    But I got mine with both VGA and DVI cable???!!!
  18. #18
    Feb 2011
    Kolkata
    just set up the display..first impression AWESOME
    But the picture is too bright..need to reduce brightness
    And it came with both VGA and DVI-I cable
    G2420 users please post your optimal picture settings
    Next buy a graphics card..will buy in October!!
    Samsung Galaxy Note
    Steam: masterkdxp
  19. #19
    Jul 2011
    oh i had forgot you were to buy this evening itself...congrats ! i had told you...
    sorry had forgot about the DVI cable...lol...i usually game at 'standard' mode, but generally check between different modes before starting a game/movie...whatever suits the eye i set that mode for that particular game/movie....simple
  20. #20
    Jun 2004
    10 light years away
    Congrats for your purchase.
    Here's mine:-
    Mode: Dynamics
    Brightness: 55
    Contrast: 55
    DCR: 0
    Default dynamics mode is awesome for movies and games too, but for images and text things looked a bit washed out. And changing settings every time is a PITA. So make this compromise setting.
  21. #21
    Human Spambot MegaMind's Avatar
    Nov 2010
    Perambalur, TN
    Quote Originally Posted by MatchBoxx View Post
    Mine too..
    @masterkd, congos.. How much for it?
    i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - Plextor M3 PRO 128GB - 1TB 7200.12 - GTX 570 sonic platinum - CM M600 - HAF X - XONAR DX + VS4121/XB500 - OptX AW2210 - DSL 2750U - Micro 800va
  22. #22
    Aug 2008
    Calcutta
    Quote Originally Posted by masterkd View Post
    Congos Pics ??
    My Gizmos O_O
  23. #23
    Feb 2011
    Kolkata
    This display is BIG
    Attached Images Attached Images
    Samsung Galaxy Note
    Steam: masterkdxp
  24. #24
    Jun 2011
    West Bengal(howrah)
    Congratz masterkd bro..hey did you receive any 3.5mm audio jack with it ???
    Core i5 750 | Intel DP55WB | Corsair (2x2GB) DDR3 | Corsair TX650 V2 | MSI GTX560 Ti HAWK | CM Ellite 334 | BenQ G2420HD | Seagate 500GB |
  25. #25
    Jun 2004
    10 light years away
    I don't think it is bundled. Have you got one?
  26. #26
    Feb 2011
    Kolkata
    nope no audio cable is bundled!!
    Samsung Galaxy Note
    Steam: masterkdxp
  27. #27
    Living to Play gameranand's Avatar
    Apr 2009
    The Cyclone
    I guess I'll also purchase BenQ E2420HD or G2420HD whichever available easily our may be the dell one as it also comes in my budget. Damn why my monitor died so quick after just 4 years. I'll never ever purchase a Viewsonic product again.
    In war, Victory. In peace, Vigilance. In death, Sacrifice.
    Making of "The Cyclone"
    Welcome to "The Cyclone"
  28. #28
    Feb 2011
    Kolkata
    ^I had to buy this display because my minitor too died after 4 years and that one from viewsonic too!!
    We are so similar
    Samsung Galaxy Note
    Steam: masterkdxp
  29. #29
    Apr 2009
    The Cyclone
    We are so similar
    What was your model no. ??
    Mine was 1912wb.
    hey at what price you got this one ??
  30. #30
    Feb 2011
    Kolkata
    Mine was VA1912w-4 which already gone through a repair when it was under warranty!!
    Samsung Galaxy Note
    Steam: masterkdxp
  1. Replies: 0
    Last Post: 15-10-2011, 10:02 PM
  2. Replies: 6
    Last Post: 15-06-2011, 06:39 PM
  3. Continuously display 'cell info display' in my N79
    By Pragadheesh in forum Mobiles and Tablets
    Last Post: 06-09-2010, 06:01 PM
  4. HD WLED Glossy display vs. 720p WLED display
    By pranav_is_cool in forum Hardware Q&A
    Last Post: 24-06-2010, 07:41 AM
  5. Display gone bad! Plz help.
    By harmik in forum Hardware Q&A
    Last Post: 22-06-2007, 02:02 PM
