Results 1 to 9 of 9
  1. #1
    Apr 2011
    Uttarakhand
    Exclamation Dark spot on LED screen - WTF?!
    My dad's ThinkPad L412 has got a small dark spot on its screen. It's not completely black, it's a grey irregular shaped (almost circular) spot. I thought it was a dirt particle so I tried cleaning but that didn't help. The spot's diameter is hardly half millimeter and is hardly noticeable except if there is a solid color displayed in that area. I have confirmed it is NOT a stuck pixel because a stuck pixel shows varying colors depending upon the color displayed. If it is a dead pixel, it must be black. But it is not. It is very very light grey in color and appears the same no matter whatever is displayed. I tried many dead pixel apps but none helped. Can you help me sorting out what exactly that spot is?
  2. #2
    RAMPAGE!!!! modder's Avatar
    Oct 2010
    In my turtleneck!!!
    Default Re: Dark spot on LED screen - WTF?!
    Quote Originally Posted by nilanko View Post
    A quick google search revealed that dead pixels can be of different colors (but I'm not that sure)
    See:
    dead pixel color ?
    Grey DOT on LCD screen???
    It might be a dead pixel.
  3. #3
    Apr 2011
    Uttarakhand
    But it's larger than a pixel and a dead pixel is generally sharp but mine is blurry -- about half a milimeter.
    I used a magnifying glass to see that area of the screen. I could clearly see small squares. None of the light squares were off. Only 2 squares were less lit (white display in that area) which is making a 'grey spot' or dull spot. It is neither a dead or stuck pixel cause it's only less lit. What might be that?
  4. #4
    Bang! Bang! noja's Avatar
    Nov 2010
    I once sat on my laptop
    it developed a huge black spot in the center of the screen.
    I took it for repair and told the guy at the shop exactly what happened.
    What did he do?
    he took a piece of paper
    made a paper ball from it
    rubbed it on the flat surface of a table to get a flat surface on the paper ball
    next he rubbed the same on the screen gently(but with a little bit of pressure) with the screen off
    after that he turned the screen ON and the spot was gone.
    It was like magic!
  5. #5
    Human Spambot abhidev's Avatar
    Sep 2009
    thats a new technique.....
    Core 2 duo E4500 2.2gHz , ASUS P5GCMX , 3GB Transcend , Corsair VX 550w, MSI R5770 HAWK Edition 1GB, CM HAF-922, LG W2243T 21.5" LCD, I-Ball Baton
  6. #6
    Apr 2011
    Uttarakhand
    @noja: will try that.
    I tried the UDPixel app and also the message technique, all this made the spot fainter but it didn't go away, also its shape has changed a bit.
  7. #7
    Sep 2009
    whats udpixel app??
  8. #8
    Apr 2011
    Uttarakhand
    ^^Helps in correcting stuck pixels. But my case is neither stuck or dead.
  9. #9
    In The Zone nginx's Avatar
    Apr 2011
    Kolkata
    Quote Originally Posted by noja View Post
    What did he do?
    It was like magic!
    That wasn't magic. Dead pixels can't be removed like that. Your screen just had some sticky dirt on it which is why he was able to remove it.
  1. IBM regains top spot in supercomputing.
    By kisame in forum Technology News
    Last Post: 19-06-2012, 08:40 PM
  2. Hittin' the G Spot
    By Plasma_Snake in forum QnA (read only)
    Last Post: 21-05-2008, 12:16 AM
  3. creative ep-630. spot the fakes.
    By sagar_coolx in forum Mobiles and Tablets
    Last Post: 16-11-2007, 02:43 PM
  4. Spot the difference
    By uzair in forum QnA (read only)
    Last Post: 14-08-2006, 06:20 PM
  5. Google loses its G-spot
    By devilhead_satish in forum Technology News
    Last Post: 20-10-2005, 11:34 PM
