Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 10-09-2008, 01:28 PM   #1 (permalink)
Default NVIDIA GTX 260 newer / older model - Differentiation
So NVIDIA decided that they are not going to change name of the new 216sp GTX 260, we’d better find a way to tell the new 260 from the old.
1. Shader
The new GTX 260 have 9 TPC, thats 24 shaders more than the old GTX 260, So the easiest way to see the difference is from ForceWare control panel’s system information.One of the improvement of ForceWare 177 is more info will be display in the system information page. So let’s see:
System info displays shader numbers
2. Core
If you can dismount the cooler, you will able to see the GPU core. look at the mark on it, you can see the new GTX 260 is G200-103-A2, not the rumored A3 core.
left: old, right: new
3. Performance
The Performance of the new GTX 260 is about 5%~10% faster than the old GTX 260. in 3Dmark Vantage Extreme Preset we can see 10% improvement, if you run a Devil May Cry 4 PC benchmark, the improvement can be boost up to 11%~12%.
Don’t worry, if you are going to purchase a 216SP GTX 260 after September 16, graphic vendors will change box designs and naming,like GTX260 Xtreme Edition, TOP or something. the new boxart and name can also help you to define which is 216SP GTX 260 and which is 192SP GTX 260.
Source
shadow2get is offline
Old 10-09-2008, 04:19 PM   #2 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Default Re: NVIDIA GTX 260 newer / older model - Differentiation
Sweet, but it becomes costlier then.
And the 4870 with a small OC beats it like hell(by small I mean, insignificant)
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 18-09-2008, 01:02 PM   #3 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Here's the link to the review, it's goodbut pricey!!!)
http://www.anandtech.com/video/showdoc.aspx?i=3408&p=1
About me:
Old 19-09-2008, 01:36 PM   #4 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Oi, here's the GTX 260 Core 216 OC review, it performs like the GTX 280 at more than 100USD less!!!!!
Official OVERCLOCKKER'S
About me:
How to Use Older Extensions and Themes With Newer Versions of Firefox topgear Tutorials 4 10-06-2008 11:24 AM
FireFox Speedups - Newer tips koolbluez Tutorials 17 06-08-2007 04:07 PM
Which is newer DVD writer?? jack// ani QnA (read only) 2 10-02-2006 05:00 PM
Newer Semprons are really 64bit or ? dabster QnA (read only) 8 11-09-2005 05:05 PM
WICH is new model nVIDIA Geforce4 or nVIDIA Geforcefx series ashu888ashu888 Graphic cards 1 24-01-2005 01:27 PM
- by chris
