06-09-2008, 12:34 PM
EXIT: DATA Junkyard
Shocker Of A Performer, 9800gt
You must all be thinking of the 9800GT and 8800GT funda. Well I agree that both are same in most(almost aspects) although the 9800GT is some Rs. 7500 while the 8800GT still sells over Rs. 8000.
The 9800GT has features like:
1. HYBRID SLi
2. BASED ON NEW 55nm
3. LOWER POWER CONSUMPTION
However, one review changed my thoughts about this little baby here.
I seems that the 9800GT when Overclocked(not even to the limit, just a little bit), beats the 9800GTX and HD4850 in all the games that were tested.
Absolute shocker isn't it, and I'm sure that further OCing will break the 9800GTX+ performance too.
So, now a new option comes up to us.
The HD 4850 or the GF 9800GT?
Check this review to know it all:
http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/9791-geforce-9800-gt-roundup-evga-asus-gigabyte-palit.html
06-09-2008, 03:58 PM
The Smaller Bang
Re: Shocker Of A Performer, 9800gt
I wonder how you can compare a card OCed to a non OCed card.
Compare HD4850, 9800GTX+ both OCed to their highest potentials on the same rig then post the benchmarks.
Apple iPad 2 16GB WiFi
06-09-2008, 04:19 PM
The Devil's Advocate
I think OCing a card is like doping. If you're to compare them, do it out of the box & raw.
OCing a card tells you how far the limits can be stretched and not how the card performs at room temperature (normal conditions).
http://beingmanan.com
06-09-2008, 07:00 PM
-----ATi-----
Is it even out yet?
I can't find anything related to the card on Anand Tech or Tom's Hardware..
http://twitter.com/akshayms
06-09-2008, 07:02 PM
EXIT: DATA Junkyard
Just trying to give the card a chance, it can become the new lower mid-budget choice if you see light in what I'm trying to tell you.
And anywayz, up till a resolution of 1680x1080, it performs very well.
And you must know one thing, more than 60fps in a LCD doesn't create any difference.
So 100fps by 4850 in one game and 60fps by the 9800GT in the same game won't yield you any performance difference, so it is completely suitable card for lower budgeted gaming PC's, ready to replace the lower end 9600GT.
06-09-2008, 07:11 PM
-----ATi-----
When 4850 is OC'ed the 9800GT can't beat it. Wont even come close.
In that case there wont be a need for a high end card. A card which can give 100FPS now can give 60FPS in the future. A card that gives 60FPS now, wont give 60FPS forever. When you buy a graphics card, future-proofing is important.
06-09-2008, 07:24 PM
EXIT: DATA Junkyard
Hello, there is no game where the 4850 actually gives 100fps with 9800GT giving 60fps.
It's just touching the line some 5fps lower, but a 2k price difference should be appreciated and I insist.
And, in games like Crysis(almost everyone's fav.) and GRAW2, 9800GT pawns the 4850 like hell.
So, what if 4850 is leading in those games where fps crosses 100, there it doesn't matter, whereas the main and popular games matter more.
06-09-2008, 07:28 PM
HD4850 beats the crap out of 9800GT in 3DMark and btw HD4850 can also be Oced, so leave the Ocing part and HD4850 is still the "Budget King"
06-09-2008, 07:32 PM
EXIT: DATA Junkyard
hello, you're gonna see PC Mark or Real Time gaming, and BTW, the 9800GT has more more more OCing potential than 4850 has.
06-09-2008, 07:33 PM
Well here's an update 4u Tweakdown says, "If you’re a user of an 8800 GT and you think the 9800 GT might be a bit of an upgrade, you will be severely disappointed" so sit tight and watch the show buddy
06-09-2008, 07:36 PM
EXIT: DATA Junkyard
No one's asking an 8800GT owner to buy a 9800GT, i'm aware of those facts already.
But those in search of new configs with 6-7k for graphics card will surely opt for this one then wont they!!!
06-09-2008, 07:42 PM
-----ATi-----
According to the site you have posted, the 4850 heats upto 88C on load. But it doesn't cross 60 if you have installed the latest BIOS.
And power consumption is ~10-15W less than the 4850. Not any significant difference.
Anyone heard of this site before?
06-09-2008, 07:44 PM
Maybe but I won't
06-09-2008, 07:46 PM
EXIT: DATA Junkyard
Okok enough already!!!! Just trying to help, don't make it nasty.
BTW-You have 8800GT kya?
06-09-2008, 07:50 PM
I love the Red Company, allergic to the greeny one
07-09-2008, 02:12 PM
-----ATi-----
07-09-2008, 02:53 PM
#19 (permalink)
Do you know 9800GT has only 112 stream processors whereas HD4850 has 800, and DX10 games will run smoother on HD4850 coz its somewhat future proof at least near future  so please don't compare a Maruti 800 with Scorpio
08-09-2008, 01:37 AM
#20 (permalink)
The Smaller Bang
The problem with OCing HD4850 is that it has only a single slot cooler.
Use the Palit HD4850 Sonic edition with Dual Slot Coolers.
THEN tell us how the OC difference is like.
And talking about buying lower end GPUs for lower FPS, well, then stick with onboard GPUs like Radeon HD3200 and HD3300 and GF9300 and GF9400.
08-09-2008, 04:17 PM
#21 (permalink)
EXIT: DATA Junkyard
I'm so sorry about the comparision, I didn't read that part, it's cause in the OCing, guru3d's ppl alwayz use Mass Effect, so sorry again about that.
But believe me, and OCed 9600GT and an OCed 4850 put together, although the 9600GT performs 5% slower, but who''l complain cause the 9600GT is 3k cheaper than the 4850.
08-09-2008, 04:45 PM
#22 (permalink)
Bond, Desi Bond!
^^^Check this new article from Tomshardware.
Here's what they say ( http://www.tomshardware.com/reviews/...rd,2011-3.html)
The Radeon HD 4850 is the new people’s champion, instantly bringing yesterday’s $300 performance level down to the mainstream $170 price point. The Radeon HD 4850 will usually best the GeForce 9800 GTX, and even the more expensive 9800 GTX+. This card has a lot of potential when used on its own, and becomes a devastating force when paired with a second 4850 in a CrossFire configuration.
The Radeon HD 4870 offers the same architecture as the 4850-series paired with its secret weapon: brand new GDDR5 memory. Because GDDR5 provides about twice as much throughput compared to GDDR3, its 900 MHZ clock speed is comparable to a 3600 MHZ effective memory speed. This edge allows the 4870 to up the ante and offer very compelling performance for the price, in some titles competing with the more expensive GTX 280.
08-09-2008, 08:03 PM
#23 (permalink)
-----ATi-----
Its not 3k cheaper than the 4850. Just around 20$ less than the 4850.
Paying 20$ extra for a card that offers 5-15% performance boost at stock speed is not that bad.
08-09-2008, 08:11 PM
#24 (permalink)
The Smaller Bang
+1
And if you compare the Palit HD4850 Sonic Edition to this card, its going to blow this away in terms of overclockablity because thanks to a Dual Slot cooler, it OCs much better.
As usual, 4850 is expensive in India MAINLY because ATI is expensive in India. Its as simple as that.
08-09-2008, 08:14 PM
#25 (permalink)
-----ATi-----
Yeah.. If AMD concentrates more in the Indian market it would really boost their sales.
Btw, how much does the Sonice edition cost?
08-09-2008, 08:16 PM
#26 (permalink)
Bond, Desi Bond!
^^ Recently I came to know this.
How big the fan is, ATI HD4850's processor frequency just can't go beyond 700Mhz.
PS: This card really doesn't need any overclocking
08-09-2008, 08:19 PM
#27 (permalink)
-----ATi-----
Why so?
Thats true..  At least it doesn't need to be OCed to beat the 9800GT
I think the thread title should be changed. The 9800GT is no 'shocker'.
Should be changed to 'another failure from nvidia'
08-09-2008, 08:20 PM
#28 (permalink)
The Smaller Bang
According to Palit, its going to phase out the standard edition since it has a slightly higher clockspeed and much better cooling. AT SAME COST.
But cunning Indian shopkeepers always do something evil. They sell it at Rs. 500-1000 higher.
08-09-2008, 08:22 PM
#29 (permalink)
-----ATi-----
If Palit Sonic is going to cost the same, then the prices of other models could come down.
08-09-2008, 08:23 PM
#30 (permalink)
The Smaller Bang
Nope. Not when palit is the CHEAPEST graphics card maker in India. Just recently out throned by Zotac for nVidia and Sapphire for ATI.
