Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 25-08-2008, 06:34 PM   #1 (permalink)
ionicsachin's Avatar
Default VLC Media Player 0.9.0 Test 2
Hey all i ve just found this....the testing version of VLC 0.9.0...everything seems magnified....lots of new features are added
http://downloads.videolan.org/pub/vi...0-test2/win32/
My first song
http://rapidshare.com/files/128849730/Sachin_-_In_My_Dreams.mp3
http://cid-e2d4f861e716a7fe.skydrive.live.com/self.aspx/.Public/Sachin%20-%20In%20My%20Dreams.mp3
ionicsachin is offline
Old 25-08-2008, 06:42 PM   #2 (permalink)
!! RecuZant By Birth !!
naveen_reloaded's Avatar
Default Re: VLC Media Player 0.9.0 Test 2
i would say to stay away from these test version....
these are for dev/beta testers ...
correct me if i am wrong..
Know My Thoughts..
Visit my Blog @ www.Urssiva.com
Visit My Tech Blog @ www.CloudTechnica.com
naveen_reloaded is offline
Old 25-08-2008, 06:51 PM   #3 (permalink)
yeah...but it is regularly updated....since it is beta version i m running it inside VirtualBox
My first song
Old 25-08-2008, 06:54 PM   #4 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
its perfectly usable in its current state. It has been so for the last few months, and the 0.9 svn versions ROCK. Check out +the nightlies.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 25-08-2008, 06:55 PM   #5 (permalink)
present verrsion itself is good for many..
i would nt recommend a beta version to mass...
Know My Thoughts..
Old 25-08-2008, 07:02 PM   #6 (permalink)
The Smaller Bang
Well, there is NO such thing as VLC "Beta Version" and I doubt there ever will be any. Nightly builds are regularly released every night (duh) and they are automatically generated, so there *might* be errors.
Current version, 0.8.6i +is re+co+mmended +if you want it for any critical applications.
But its a BOON for many if you use 0.9 svn. Because it runs away from the old wxWidgets based interface. This new baby has an interface written in QT4 and its quite stable by now.
On linux, I recommend you try out the nightly repositories MAINLY if you use KDE since QT4 intergrates awssomly into KDE. Its quite buggy, but you will enjoy discovering them +and r+e+porting them. Tru+st me. YJ+u+st++ ++r+e+por+t in thei+r forum.
On windows, well, QT4 interface is still under heavy development and its still ugly IMO. The best is yet to come, and as always, windows users are adviced to get only the stable versions. So go ahead and get VLC 0.8.6i.
On mac, VLC is written in Cocoa. Aayush, Milind, Sunny, Manan and other mac users would like this. I doubt its going to change since cocoa is DESIGNED for mac. So they too should get the latest stable release of VLC 0.8.6 mac-cocoa DMG.
O+ther Differnces:
The m+ain+ t+hing the new versions have is fixes+. Several+ issue+s a+re fixed.+ +VLC can now fore+w+ard in+ FLV fi+les+, h264 rendering is MUCH better +and mu+lti+core +su+pport for the same is bei+gn wo+r+ked on.++++
Final Advice++'++
Get the stable +rele++as+e+. If+ something is not satisfactory+ or if its buggy, get the nightly buil+d +++++++++++++++++++of the night you are in+ and see ho+w+ it w+orks. If you are satisfied w+ith it, keep it. Else, check out next night.
Last edited by MetalheadGautham; 25-08-2008 at 07:05 PM. Reason: Automerged Doublepost
Old 25-08-2008, 07:07 PM   #7 (permalink)
Console Freak
aditya.shevade's Avatar
Looks good, but ever since I tried sMplayer, I have stopped using this thing. Completely.
I have launched my blog and I am looking forward to link exchange. If you can then please add my blog link your blogroll and let me know then I can do the same.
http://blog.adityashevade.com
aditya.shevade is offline
Old 25-08-2008, 10:28 PM   #8 (permalink)
manishjha18's Avatar
sm player and km player rocks-
manishjha18 is offline
Old 25-08-2008, 11:23 PM   #9 (permalink)
O+ther Differnces:
Final Advice++'++
you learnin basic string addition ?
Steam/Flickr: psygeist
Asus Z68 V-Pro|i5 2500k|TRUE Black|Ripjaws X+Corsair Vengeance|U2311H|N560GTX|D7000|XONAR STX|RE272|RE0|CC51|XE200PRO Walnut| TD II V2| Ultraphile|N5800
Faun is offline
Old 26-08-2008, 12:26 AM   #10 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
Post Re: VLC Media Player 0.9.0 Test 2
use KMplayer its btter than WMP,vlc and media classic
Dell 15z + WD 2TB
Dell Studio 1555 + WD 1TB
iPhone 4 32 GB
Samsung Galaxy S2 White
Good Desktop Power Of C2D + 4850
NIGHTMARE is offline
Old 26-08-2008, 12:59 AM   #11 (permalink)
Ethan_Hunt's Avatar
Is it just me or this player isn't able to play HD files properly.I have all the necessary codecs & the files play properly in all other players except this one.It would only play the first 10 minutes & then if you drag the progress bar then the movie would just freeze.Anyone else experiencing similar issue?
Will try this new version.
V for Vendetta
Ethan_Hunt is offline
Old 26-08-2008, 06:02 AM   #12 (permalink)
Phenom II X4 920 Owner
prateek_san's Avatar
hey guys how do i install it and im not getting any setup file or any particular file through which i can install it..... im just getting a .exe files through which im able to open it but not able to install it....
"A strong positive mental attitude will create more miracles than any wonder drug." - Patricia Neal
prateek_san is offline
Old 26-08-2008, 07:12 AM   #13 (permalink)
The Smaller Bang
drunk keyboard syndrome
KMPlayer is a resource hog.
As I said before, HD issues are being worked on. Something to do with lack of samples and a bad h264 multicore support if I remember right. But if you have a sample which does not work, feel free to either pm it to me or post it at VLCForums.
And I repeat, this is NOT a new version.
Installing just means copying the folder to some directory and linking the exe to the desktop and associating files with it. I am sure you can do that with the files you downloaded.
Old 26-08-2008, 08:07 AM   #14 (permalink)
The G-Axe Effect
gxsaurav's Avatar
I tried it yesterday in Vista. On starting it gave me some erroe, some string not found in libvlc.dll. After that it was fine. It wasn't zooming double the size of video but the UI looks new & polished. I liked the Minimal version of UI. Waiting for Final version to be used as a portable player as in Windows Vista, WMP11 with K-Lite codec pack rocks
Graphics & Web Designer - SlideShare
Portfolio & Blog : http://gxsaurav.com
gxsaurav is offline
Old 26-08-2008, 03:01 PM   #15 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
@MetalheadGautham
i have sufficient hardware support to run KMplayer and u can optimizes also.do know any player which is better than KMplayer in Quality of picture and number of function r more than other
Dell 15z + WD 2TB
iPhone 4 32 GB
Old 26-08-2008, 05:42 PM   #16 (permalink)
+1
mrbgupta is offline
Old 26-08-2008, 06:10 PM   #17 (permalink)
The Smaller Bang
@MetalheadGautham
KMPlayer comes NOWHERE close to VLC in terms of lightness. I have tested it enough to say that.
Kaffeine
Old 26-08-2008, 06:25 PM   #18 (permalink)
Here Since 2003
Indyan's Avatar
@MetalheadGautham
KMPlayer may be heavier than vlc but its a lot more usable with a better interface.
In terms of quality I have found that if your video is already high quality NeuView Media player is the best. VLC's out of the box vid quality is quite bad.
My Blog :: http://www.pallab.net
Twitter :: http://www.twitter.com/indyan
Indyan is offline
Old 26-08-2008, 06:41 PM   #19 (permalink)
The Smaller Bang
More usable ?
Have you tried to use KMPlayer to rip mms and rstp streams ?
Can KMPlayer encode videos to different formats ?
Can KMPlayer stream video over the internet using on the fly application of filters and transcoding ?
Can KMPlayer run from commandline ?
And FYI, KMPlayer illegally uses GPLed code.
http://sourceforge.net/forum/forum.php?forum_id=462894
Its directshow engine can have MAXIMUM quality when you use the BEST directshow software, ffdshow. But do you know that ffdshow is based on FFMPEG which also powers VLC ?
If you want to make the video look better at the cost of resources, the procedure is insanely simple. All you need to do is to increase the default post processing level to a number above 0, and between 1 and 6.
Old 26-08-2008, 11:15 PM   #20 (permalink)
Here Since 2003
Indyan's Avatar
I didnt say KMP had more features. I said its more usable.. that means it has a better ui. I get access to most of its features even in full screen mode. VLC's ui sucks. The new ui looks better but still is ancient compared to other players. Though my fav ui is that of crystal player.
Indyan is offline
Old 26-08-2008, 11:18 PM   #21 (permalink)
The Smaller Bang
Usable ? Well, then I think Kaffeine and MPC have ZERO COMPETITION in that field. They work. And beautifully while at that.
Old 27-08-2008, 02:36 AM   #22 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
^^ Kaffeine player for xp or Linux
Dell 15z + WD 2TB
iPhone 4 32 GB
Old 27-08-2008, 03:56 AM   #23 (permalink)
The Smaller Bang
MPC for Win and Kaffeine for Linux.
Old 30-08-2008, 03:24 PM   #24 (permalink)
Firefox 3.0.2
http://ftp.mozilla.org/pub/mozilla.o...-firefox3.0.2/
My first song
Old 15-09-2008, 10:24 PM   #25 (permalink)
VLC 0.9.2 released....check the VLC website
My first song
Old 16-09-2008, 11:57 AM   #26 (permalink)
The Devil
blackpearl's Avatar
GOM Player kicks ass VLC player any day. Try it!
blackpearl is offline
Old 16-09-2008, 12:35 PM   #27 (permalink)
Krazy_About_Technology's Avatar
^No it doesn't. Combination of both works well. And the new version of VLC has some good enhancement, one that i particularly like is seeking in flv files is enabled now. GOM player lacks some basic codecs out of the box, but includes some which are not in VLC. So i think using both is a nice thing to do.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
Krazy_About_Technology is offline
Old 16-09-2008, 01:58 PM   #28 (permalink)
The Frozen Nova
casanova's Avatar
KM Player doesn't work well with vista. It doesn't work well with UAC and no one would like to click run in admin mode for a media player. I prefer codec packs anyday
www.nerdweed.blogspot.com
casanova is offline
Old 16-09-2008, 02:04 PM   #29 (permalink)
The G-Axe Effect
gxsaurav's Avatar
WMP 11 with K-Lite Codec pack is better then VLC anyday
gxsaurav is offline
Old 16-09-2008, 02:22 PM   #30 (permalink)
Fullbring
Zangetsu's Avatar
MPC has got No 1 rank in Digit mag....how can u say dat...
& also its my favorite
Windows OS Calculator Bug
Sqrt(9) - 3 = check the answer
Zangetsu is offline
play real media (.rm) files in windows media player mneo Tutorials 7 10-07-2007 08:30 PM
Can I watch all channels? <<media player or real player>> digidream Software Q&A 2 06-09-2005 04:42 PM
which is best media player? paul_007 QnA (read only) 2 04-02-2005 05:14 PM
Media player Sudipta QnA (read only) 6 21-10-2004 09:42 AM
