Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 09-06-2008, 05:43 PM   #1 (permalink)
Wandering In Tecno Land
Ecko's Avatar
Question Which one is wrong Avast or ZoneAlarm
Either Avast is detecting something wrong or ZoneAlarm is sending spyware to user PC's
Ofcourse send one has got less probability
Born in Windows Die In Linux © 2009-10 All Rights Reserved.
Learn Linux : www.linoob.com (Official WebSite)
Ecko is offline
Old 09-06-2008, 06:08 PM   #2 (permalink)
a_k_s_h_a_y's Avatar
Default Re: Which one is wrong Avast or ZoneAlarm
Zone Alarm obviously is spyware because it collects user information and sends it to zone labs.
basically many software do example windows media player installer, IE installer and windows xp itself without your knowledge.
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
a_k_s_h_a_y is offline
Old 09-06-2008, 06:59 PM   #3 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
None of it is a spyware. And ZA collects user information only with your approval when you install it. See, this is simple - ZA has an antispyware, and it needs to update the definitions. Those definitions contain the "signature" of the spyware for detection. Avast looks for signatures too in files, and when it finds them, it thinks its a spyware. Thats it. WMP, IE and XP do it, thats different.
dheeraj_kumar is offline
Old 09-06-2008, 07:35 PM   #4 (permalink)
waste of resource
Faun is offline
Old 09-06-2008, 07:49 PM   #5 (permalink)
Distinguished Member
anandk's Avatar
Its a false positive
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 09-06-2008, 08:21 PM   #6 (permalink)
^^ Ah yes thats the word you're looking for. Thanks anandk!
Old 09-06-2008, 08:55 PM   #7 (permalink)
Here Since 2003
Indyan's Avatar
Notice the location of the file. I guess this is what was happening.
ZA downloaded the update containing virus patterns, was unpacking them and preparing for installation when Avast detected them and suspected the presense of a virus(as the file contained virus patterns).
My Blog :: http://www.pallab.net
Twitter :: http://www.twitter.com/indyan
Indyan is offline
Old 12-06-2008, 12:29 PM   #8 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
dont update any softy automatically ...... do it manually .....
... W H O T ...
ax3 is offline
Help! ZoneAlarm sourav QnA (read only) 15 21-10-2007 11:58 AM
Avast Or Zonealarm artem QnA (read only) 14 25-10-2006 02:05 PM
ZoneAlarm 6 ! ! ! ax3 QnA (read only) 11 13-11-2005 08:40 AM
ZoneAlarm Pro 6.0.591.000 Beta Sourabh QnA (read only) 7 06-06-2005 11:52 AM
About Zonealarm saROMan QnA (read only) 4 15-02-2005 11:58 AM
- by chris
