Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 25-04-2008, 02:11 PM   #1 (permalink)
Post Foxit Reader 2.3.2822 released
Change log:New features:
* Bookmark Design: Makes it possible to have your own bookmarks. Users can create, edit, or delete bookmarks in a PDF file if the security settings allow.
* Multi-tab Browsing: Enables users to open multiple files in a single instance.You can choose to view PDFs in a multi-tab window or multiple instances by setting documents layout from the Preferences dialog.
* Multimedia Player Support: Supports many media formats including audio and video. Read multimedia ebooks with Foxit Reader 2.3.
* Callout and Text box Tool: Creates comments in a callout text box or a box. You can also define their appearance as other commenting tools.
* Commenting Text Tool: Enables users to add most types of text edits by right-clicking on the selected text, including highlight, strikeout, underline, squiggly and replacement. You can also use the Commenting Text Tool to add bookmarks for PDF files.
* Rulers and Guides: Provides horizontal and vertical ruler guides to help users align and position objects on the page. Right-clicking on the ruler enables you to change the unit of measurement.
* Magnifier: Magnifies areas of the PDF files easily as you work on Foxit Reader.
* Automatic Scrolling: Allows users to view documents without using mouse actions or keystrokes.
* OCG Support: Enables the user to view related content stored in a variable number of separate layers.
* FDF Related: Opens FDF files directly with Foxit Reader without any import implementations.
Enhanced features:
* Optimized Rendering:Supports progressive rendering and significantly reduces the response time from the user interface events.
* Improved Link Tools:Allows users to add actions to links, such as go to a page view, open or execute a file, open a web link, etc.
* Improved Snapshot:Enables users to print the selected area in Foxit Reader by simply selecting the Print option from the context menu.
* Search Enhancement:Allows users to float, move and resize the Full Foxit Search box.
* Better Annotation control:Groups drawing markups to help users operate objects collectively, and allows users to move annotations through pages.
* Font Information:Lists the fonts and the font types used in the original document in the Properties dialog.
* Updated Command Line:Allows users to open password protected PDF documents with a simple command prompt.
* Streamlined UI:A completely redesigned UI with a new look and feel makes Foxit Reader more intuitive than ever before.
* Many bug fixes.
Download:http://www.filehippo.com/download_foxit/
apoorva84 is offline
Old 25-04-2008, 02:35 PM   #2 (permalink)
Default Re: Foxit Reader 2.3.2822 released
Thanks for the information.
ThinkFree is offline
Adobe Reader 8 for Linux Released Dark Star Open Source 14 20-09-2007 12:43 AM
ebook reader software like microsoft reader.. Manshahia Software Q&A 3 22-05-2007 01:46 PM
Reader kumarn_2004 Software Q&A 3 11-03-2007 06:46 AM
mmc reader for 98 choklate_007 Hardware Q&A 5 29-11-2006 03:59 AM
system mechanic 6 has been released released anandk QnA (read only) 10 22-10-2005 08:19 AM
- by Niilesh
