Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 22-03-2008, 01:49 AM   #1 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
Wink IE8 is better then FF3 till now
Yup you heard it right microsoft is not sleeping now they have passed acid 2.0 test which FF3 HAS FAILED TOOO
http://www.sitepoint.com/blogs/2007/...dies-of-shock/
Thanks
krates
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
krates is offline
Old 22-03-2008, 02:04 AM   #2 (permalink)
You gave been GXified
gxsaurav's Avatar
Default Re: IE8 is better then FF3 till now
On Windows Vista, for me atleast Firefox 3 latest 21 march nightly trunk sux right now.
Feature wise my IE 8 beta installation is as tweaked as my firefox with extensions. They both support 99% same features now so the choice is between rendering speed & look & feel only.
Rendering speed wise firefox is better then IE 8 right now, but I can live with .2 nano second delay in IE 8's rendering of a page, however the look & feel of firefox on Windows just sux right now.
In IE 8 I can enable cleartype for HTML. Now I have a CRT monitor so system wide cleartype looks bad on my monitor. Despite of this I can enable in IE 8 cleartype for the HTML rendering only which makes reading things very easy. On the other hand in Firefox there is no such option, & I either have to live with non Cleartyped text in firefox or with system wide cleartype which looks bad on my CRT monitor.
I mean, comon.....IE 7 had cleartype for HTML since ages, safari too has it... I don't know about Opera, but why isn't this in Firefox 3 when they have a new rendering engine & Cairo Support.
The memory usage has improved, thanx god....
The new Vista-ish theme sux. Period. I expected something better like the mock ups from Mozilla.
about.me/gxsaurav
gxsaurav is offline
Old 22-03-2008, 02:14 AM   #3 (permalink)
krates's Avatar
when you will enable clear type for windows from
right click- properties - effects - advanced
enable smooth font rendering and select clear type from the list
then your firefox will also show that rendering
krates is offline
Old 22-03-2008, 02:19 AM   #4 (permalink)
gxsaurav's Avatar
Isn't that what I just mentioned in my post???
If I enable clear type using this method, it enables cleartype for my whole computer & UI. Now HTML in firefox looks better, but rest of the text in any application looks bad in my CRT Monitor, cos ClearType isn't exectly made for CRT Monitor.
If I disable system wide cleartype then firefox's text looks crap.
IE 7/8 or Safari 3 is better then Firefox in this regard. They have there own clear type engine independent of the OS settings.
At least this is what I expected in firefox 3. Now don't say "Upgrade to LCD" or "How many people use CRT Now??"
Here is the screenshot of this very page in both Firefox 3 latest nightly built & IE 8 beta. Just look at how bad the text looks in firefox. Cleartype is disabled from system control panel, & IE 8 is set to use cleartype for HTML
about.me/gxsaurav
gxsaurav is offline
Old 22-03-2008, 09:46 AM   #5 (permalink)
Proud to be Linux
abhinandh's Avatar
source???
i'am using firefox3 beta 4 and i can test for myself and it passes acid 2.
http://abhinandh.com
abhinandh is offline
Old 22-03-2008, 11:13 AM   #6 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Wink Re: IE8 is better then FF3 till now
Strange that I am not having this type of problem with cleartype in FF3. I am using beta 4 and by default it is rendering the page with cleartype enabled. I am also using a CRT (Samsung SyncMaster 798MB+). I do not know why are u having such problem with your CRT
debsuvra is offline
Old 22-03-2008, 12:03 PM   #7 (permalink)
PhotonAttack
DigitalDude's Avatar
GRRRRRRR IE8 passes Acid2 Test and FF3 fails
NOO NOT AGAIN PLZZZZ
_
DigitalDude is offline
Old 22-03-2008, 01:24 PM   #8 (permalink)
Juke Box Hero
Closed as posted and pretty much debated before.
Hitboxx is offline
Best of 2007 till Q3 ratedrsuperstar Chit-Chat 3 16-10-2007 09:21 PM
The Best Looking Racing Game Till Date !!! rockthegod Gamerz 10 31-08-2007 03:54 PM
What is the Game you liked to play till End.... saROMan Gamerz 46 01-09-2005 03:32 PM
- by Niilesh
