Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 12-12-2007, 10:20 AM   #1 (permalink)
The Devil's Advocate
iMav's Avatar
Default New Material Provides Constant Light For 12 Years Without a Power Source
MPK, a company that has made a name producing glow-in-the-dark paint, has developed self-luminous micro particles called Litrospheres. The new material is said to be inexpensive (35 cents to light up a 8 ½ x 11 piece of plastic that is 1/8" thick), non-toxic, and capable of staying constantly lit for over 12 years thanks to a betavoltaic technology that uses a radioactive gas.
Fortunately, the gas is involves a "soft" emission of electrons that cannot penetrate the glass or polymer wall of the microspheres. So theoretically, you don't have to worry about brain tumors or taking on super powers when using it.
The Litrospheres, which can be injected molded or added to paint, are not affected by the heat or cold and they can withstand up to 5000 pounds of pressure. They can also give off light that is equivalent of a 20-watt incandescent bulb in almost any color imaginable. As you might expect, the first applications of the technology will most likely involve safety equipment—or the clothing and accessories of frequent clubgoers.
Source
http://beingmanan.com
iMav is offline
Old 12-12-2007, 10:26 AM   #2 (permalink)
Think Zen.
ray|raven's Avatar
Default Re: New Material Provides Constant Light For 12 Years Without a Power Source
http://www.ecofriend.org/entry/flexi...-247-lighting/
Dude,this site says it uses Tritium, which is RadioActive.
So, um well.....kinda useless to us, if true.
Oh n already posted.
New Flexible Light Source For 24/7 Lighting for 12 Straight Years
Regards,
ray
Do what you will; but not because you must. -- Zen Quote
ray|raven is offline
Old 12-12-2007, 12:54 PM   #3 (permalink)
!! RecuZant By Birth !!
naveen_reloaded's Avatar
I seriously doubt ... Whether its safe..
Surely it would produce radiation to very least and put it in a house for 12 years,ya everybody will became monkey's after few centuries...mutation
Know My Thoughts..
Visit my Blog @ www.Urssiva.com
Visit My Tech Blog @ www.CloudTechnica.com
naveen_reloaded is offline
Old 17-12-2007, 04:21 PM   #4 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
cool ........
... W H O T ...
ax3 is offline
Computer off, power light blinking g_goyal2000 Hardware Q&A 27 25-05-2008 08:33 PM
New Flexible Light Source For 24/7 Lighting for 12 Straight Years Hitboxx Technology News 7 13-12-2007 11:58 PM
Betavoltaic Battery Could Power Your Laptop for Thirty Years iMav Technology News 9 08-10-2007 12:30 AM
Power Source for Graphics Cards godling Graphic cards 1 21-12-2006 02:36 AM
Light power point files! abhijitroy Software Q&A 6 28-10-2005 04:40 PM
- by chris
