Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 28-11-2007, 08:56 PM   #1 (permalink)
Smile ffmpegmenu -One click Video Conversion
KDE users, here’s a neat application that creates a ’service’ in your file manager that allows you to easily convert videos to other formats using ffmpeg.
ffmpegmenu is what you need. After copying the simple script into the right directory, an action will appear in the sidebar of either Konqueror or Dolphin (your choice), which easily allows you to convert selected video to DVD, MPEG or into iPod format with a couple of clicks.
The script itself is very simple, such that it’s definitely possible to edit it to customise the commands it runs to make your own ffmpeg conversion options. It does require you have ffmpeg and the necessary codecs to convert to DVD, MPEG and iPod already installed, as it is just a loader which calls ffmpeg. But enough of that, how do you actually install the script?
Source
For more tech news & freebies chk it out: http://www.nnepal1kta.blogspot.com
marulez is offline
Old 28-11-2007, 10:50 PM   #2 (permalink)
!! RecuZant By Birth !!
naveen_reloaded's Avatar
Default Re: ffmpegmenu -One click Video Conversion
Why is this a news?
Know My Thoughts..
Visit my Blog @ www.Urssiva.com
Visit My Tech Blog @ www.CloudTechnica.com
naveen_reloaded is offline
video conversion software for psp ashwin_ka Mobiles and Tablets 2 16-06-2007 12:18 PM
BEst Video Conversion Tool??? gauravakaasid Software Q&A 9 11-10-2006 02:22 PM
video conversion PROBLEMS soulrogue Software Q&A 3 14-08-2006 10:42 PM
Video conversion 3gpp vijaythefool QnA (read only) 1 26-01-2005 01:36 PM
best video conversion software???? akitosforever Software Q&A 2 29-10-2004 12:24 AM
- by chris
