Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 02-10-2007, 06:18 PM   #1 (permalink)
The Devil's Advocate
iMav's Avatar
Default Betavoltaic Battery Could Power Your Laptop for Thirty Years
Research funded by the US Air Force Research Laboratory has come up with a breakthrough battery: a betavoltaic power cell that lasts for 30 years without a recharge. Made from radioactive material (I am writing this from my underground bunker) the batteries end their life being completely inert and non-toxic, so they're not as scary-bad as they sound.
Here's how it works: Made from semiconductor materials, the betavoltaic battery uses radioisotopes as its energy source. The beta particles that come from the decaying radioactive material are transformed into electric power that can power devices, such as a laptop, for up to three decades. Before you all run for the tinfoil, the batteries don't use fission or fusion, nor are there any chemical processes to produce energy, which means no radioactive or hazardous waste.
Source
http://beingmanan.com
iMav is offline
Old 02-10-2007, 06:24 PM   #2 (permalink)
TheSaint
NucleusKore's Avatar
Default Re: Betavoltaic Battery Could Power Your Laptop for Thirty Years
Nice, but the cost remains to be seen, not to mention the warranty
NucleusKore is offline
Old 02-10-2007, 06:50 PM   #3 (permalink)
Pawned!... Beyond GODLIKE
fun2sh's Avatar
wel this aint a new thing. VOYAGER spacecraft which is the FARTHEST MAN MADE OBJECT FROM EARTH IS POWERED BY SUCH SYSTEM AND ITS BATTERY IS STILL WORKIN
read this
http://en.wikipedia.org/wiki/Voyager_1
read this
If God has indeed created Himself in His own image, then I submit to you that God is a cockroach :mrgreen:!!!!!!!!
fun2sh is offline
Old 02-10-2007, 11:32 PM   #4 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
thirty years??
Sounds more like bomb to me..
jin files ka koi server nahi hota unka bittorrent hota hai
chesss is offline
Old 05-10-2007, 12:20 PM   #5 (permalink)
iMav's Avatar
Rumors of a betavoltaic battery able to power laptops for 30-years shot down
It is said that when something is too good to be true, it often is. In the case of a new type of notebook battery touted to last decades, new technology promises to uproot all conventional energy storage, but just how practical is it?
Internet publication Next Energy News ran a story earlier this week claiming a betavoltaic batteries are in development, and will run tomorrow's notebooks 30 years without replacement or recharging.
The betavoltaic battery works similarly to solar cells. However, instead of generating electricity when photons strike a substrate, betavolatic batteries generate power from using high-energy electrons generated by the decay of a radioisotope, in this case reported to be tritium.
As the radioisotope decays, beta particles are emitted that strike an interface layer between two layers of material generating a useful electrical current. The power in the battery will decrease proportional to the half-life of the radioisotope. While the battery uses radioactive materials, it would produce no radiation and when exhausted would be an inert mass easily disposed of.
Rupert Goodwins of ZDNET UK says in short that the entire betavoltaic battery story is simply off the mark. Goodwins says in his column, “One [problem] is that the sort of atomic structures that generate power when bombarded with high energy electrons are the sort that tend to fall apart when bombarded with high energy electrons.”
Goodwins also says that while eventually the tritium battery will turn into a safe lump of stuff, if you break the battery open during its life all the radioactive, presumably toxic, materials will spill out. The Next Energy News story says, “The reaction is non-thermal which means laptops and other small devices like mobile phones will run much cooler than with traditional lithium-ion power batteries.”
This particular claim is totally refuted by Goodwins stating, “[Betavoltaic batteries] don’t have a great conversion efficiency. Around 25 percent is the best you can get -- which is pretty good, but leaves 75 percent sloshing around as heat. That means a 25 Watt battery will get plenty warm.”
Goodwins goes on to liken the heat output from a tritium battery to that of a 60-watt light bulb. Certainly more heat than any person interested in usable genitalia wants sitting on their laps.
Another big issue Goodwins says is that betavoltaic batteries just don’t work that well, they can only output about 5-watts per kilo, which means they would need to be 72 times heavier than the battery in your notebook right now.
As good as betavoltaic batteries sounded in the beginning, fuel cells are still more likely to replace batteries in our notebooks.
http://www.dailytech.com/article.aspx?newsid=9150
iMav is offline
Old 05-10-2007, 01:58 PM   #6 (permalink)
GaurishSharma.com
gary4gar's Avatar
read this
read this
inresting read!
does the spacecraft still send some data back, i woder how long it how take the the data to come back
gary4gar is offline
Old 06-10-2007, 06:23 AM   #7 (permalink)
chesss's Avatar
^atleast 14.36 hours, since the distance from earth is 14.36 light hours..
chesss is offline
Old 06-10-2007, 05:26 PM   #8 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
cool ........ 30 hrs ........
... W H O T ...
ax3 is offline
Old 06-10-2007, 07:12 PM   #9 (permalink)
I have Yolks not Brains!
eggman's Avatar
Not hours..............years.................
Y U NO ALLOW PICTURES IN SIGNATURES?
eggman is offline
Old 08-10-2007, 12:30 AM   #10 (permalink)
great update man
arvivair is offline
is my laptop battery gonna oldie???? sandeep bhatia Laptops and Netbooks 9 26-09-2007 11:35 AM
Laptop Battery Not Recharging...! jal_desai Hardware Q&A 2 08-07-2007 12:28 AM
Battery power kumarn_2004 QnA (read only) 1 01-03-2007 10:14 PM
Laptop battery already dead?? harpoon Laptops and Netbooks 5 01-01-2007 11:13 AM
Balancing battery and power supply on laptop sakumar79 Laptops and Netbooks 5 11-05-2006 07:00 PM
- by chris
