Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 06-09-2007, 08:48 PM   #1 (permalink)
You gave been GXified
gxsaurav's Avatar
Default HP Blackbird : Gaming rig & what not
Taken from Dailytech
HP's new Blackbird 002 is the result of the a year's worth of collaboration with Voodoo PC
HP and Voodoo PC are set to unveil the fruition of their efforts after the acquisition of Voodoo PC in the form of a new enthusiast oriented gaming machine next week – the HP Blackbird 002. The new HP Blackbird 002 sports a completely new chassis design, built from the ground up for looks, performance and versatility.
The new Blackbird 002 chassis features a completely aluminum chassis sporting a wedge-shaped design. HP’s Blackbird 002 features a hover design, where the chassis sits on a cast aluminum stand for a hovering look. The cast aluminum stand raises the chassis off the ground to provide airflow to the system’s 1100 Watt power supply mounted at the bottom of the chassis. The stand can also support up to 600 pounds, allowing users to stand on the system or set a couple concrete blocks on it.
HP touts the Blackbird 002’s superior thermal capabilities. The Blackbird 002 features a sealed, maintenance free water-cooling system. The water-cooling system cools the processor and graphics cards while keeping the system quiet. HP also touts the chassis’ isolated design, keeping every component chamber isolated and preventing hot air from contaminating the cool air stream.
The chassis also features a completely tool-less design, allowing owners to remove or replace all components without the needs of any tools. HP equips the Blackbird 002 with plenty of lighting. The chassis features accent and task lighting, according to Mark Solomon, lead designer, HP Gaming. Accent lighting highlights certain aspects of the Blackbird 002 such as the stand and front grille while task lighting highlights helpful portions of the case such as the chassis interior and rear ports.
The company claims it will equip the Blackbird 002 with industry standard components and the best components available. The chassis will accommodate standard off the shelf components such as motherboards, video cards, hard drives and memory. The system will also come with standard BIOS, allowing users to tweak and overclock the system to their liking.
about.me/gxsaurav
gxsaurav is offline
Old 06-09-2007, 09:04 PM   #2 (permalink)
M$™ Certified Spammer
entrana's Avatar
Default Re: HP Blackbird : Gaming rig & what not
wow looks hot, but ive learnt over the years that hp and compaq suck and i rather would have an assembled pc
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
Old 06-09-2007, 09:18 PM   #3 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
How much is it gonna cost?
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 06-09-2007, 10:36 PM   #4 (permalink)
Dark Overlord !!!
rockthegod's Avatar
3000 - 7000 USD !!!!
I would prefer Alienware at this cost !!!!
C2Q6600@3.2G; eVGA nforce 780i; eVGA 8800 GT 512 MB (650/1900/1620) in SLi; 2 GB OCZ EPP DDR2 8500@1066M; PP&C Silencer 750W; Antec 900
AT&T Tilt WM 6.1 Pro Running Android
Sony PSP 2000 5.0-m33
rockthegod is offline
Old 06-09-2007, 11:06 PM   #5 (permalink)
Rubik's Uncle!!
Charan's Avatar
What !!! did they put Doom 3 Engine into that cabinet!!!!
Charan is online now
Old 06-09-2007, 11:10 PM   #6 (permalink)
gxsaurav's Avatar
HP Blackbird 002 gaming rig reviewed
If the HP Blackbird 002's good looks weren't enough to justify is sky high price tag for you, than perhaps HotHardware's review of the top-end gaming rig will be enough to push you over the edge.
The folks there got their hands on a pre-release version of the system, loaded with a Core 2 Extreme QX6850 processor factory overclocked to 3.67GHz, 4GB of Corsair dual channel DDR2-8500 RAM, and two GeForce 8800 Ultra cards running in SLI mode, among other desirable specs. Not surprisingly, with all that under hood the system couldn't help but impress, with it delivering a few benchmark scores higher than any other machine they've tested.
They also, of course, dug the system's case design, which not only looks good but makes upgrading an ease (they replaced a hard drive in 12 seconds flat). On the downside, they found the system to be "somewhat noisy," and the slot-loading optical drives could limit upgradeability further on down the line. Then, of course, there is the price, which starts at $2,500 and tops out over $7,000 when packed to the gills.
about.me/gxsaurav
gxsaurav is offline
Old 06-09-2007, 11:12 PM   #7 (permalink)
Rebooting
Choto Cheeta's Avatar
One comment we can assemble one if having that much mooney but only problem is their custome made cabinets !!!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 06-09-2007, 11:19 PM   #8 (permalink)
gxsaurav's Avatar
Its completely upgradeable by the user. You can simply buy the $2500 base system & upgrade as u need.
about.me/gxsaurav
gxsaurav is offline
Old 10-09-2007, 11:13 AM   #9 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
WOW ........ & whot a cost ............
... W H O T ...
ax3 is offline
Old 28-09-2007, 11:52 AM   #10 (permalink)
TechTin.com
ravi_9793's Avatar
but too costly .............
I cant even think of this right now.
ravi_9793 is offline
Old 28-09-2007, 11:57 AM   #11 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
If i were to buy this one I would wait and see reviews from other users.I have seen a voodoo system burn when being tested.
Harvik780 is offline
Old 28-09-2007, 12:03 PM   #12 (permalink)
AJJU
azzu's Avatar
i cant tooo
I love and Live to Design
azzu is offline
To get Logitech G15 Gaming Keyboard and MX518 Gaming Mouse debasis_7012005 Hardware Q&A 24 10-09-2007 02:37 PM
what's the difference btwn Online gaming & Internet gaming singh Gamerz 2 12-08-2006 12:03 PM
Is this the best gaming rig???????? makarand Hardware Q&A 8 08-01-2006 11:39 AM
Gaming PC piyushp_2005 Gamerz 12 11-04-2005 09:07 PM
Can small gaming companies suceed in todays gaming market Charley Technology News 16 03-03-2005 10:56 PM
- by Krow
- by iGamer
