Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 14-08-2007, 06:08 PM   #1 (permalink)
dattebayo
anispace's Avatar
Default Nokia Announces Product Advisory for BL-5C Battery
from cnnmoney.com
ESPOO, Finland, August 14 /PRNewswire-FirstCall/ -- Nokia today issued a product advisory for the Nokia-branded BL-5C battery manufactured by Matsushita Battery Industrial Co., Ltd. of Japan between December 2005 and November 2006. This product advisory does not apply to any other Nokia-branded battery.
Nokia has identified that in very rare cases the Nokia-branded BL-5C batteries subject to the product advisory could potentially experience overheating initiated by a short circuit while charging, causing the battery to dislodge. Nokia is working closely with Matsushita and will be cooperating with relevant authorities to investigate this situation.
Nokia has several suppliers for BL-5C batteries who have collectively produced more than 300 million BL-5C batteries. This advisory applies only to the 46 million batteries manufactured by Matsushita between December 2005 and November 2006, from which there have been approximately 100 incidents of overheating reported globally. No serious injuries or property damage have been reported.
Consumers with a BL-5C battery subject to this advisory should note that all of the approximately 100 incidents have occurred while charging the battery. According to Nokia's knowledge this issue does not affect any other use of the mobile device.
While the occurrences in the BL-5C batteries produced by Matsushita in the time-period specified are very rare, concerned consumers can request a replacement for any BL-5C battery subject to this product advisory.
It is important to note that the BL-5C battery is not used in all Nokia products and that only a portion of the Nokia BL-5C batteries in use are subject to this advisory.
Nokia Battery replacement programme>>
http://www.nokia.com/batteryreplacement/en/
Yoda: No. Try not. Do... or do not. There is no try.
anispace is offline
Old 14-08-2007, 06:17 PM   #2 (permalink)
24online's Avatar
Arrow Re: Nokia Announces Product Advisory for BL-5C Battery
ya...on all news channels..... i have battery of BL-5C on my nokia phone...i will go to nokia center and will change battery....
The BL-5C batteries which are subject to the product advisory were used with the following Nokia models or separately as accessories:
Nokia 1100, Nokia 1100c, Nokia 1101, Nokia 1108, Nokia 1110, Nokia 1112, Nokia 1255, Nokia 1315, Nokia 1600, Nokia 2112, Nokia 2118, Nokia 2255, Nokia 2272, Nokia 2275, Nokia 2300, Nokia 2300c, Nokia 2310, Nokia 2355, Nokia 2600, Nokia 2610, Nokia 2610b, Nokia 2626, Nokia 3100, Nokia 3105, Nokia 3120, Nokia 3125, Nokia 6030, Nokia 6085, Nokia 6086, Nokia 6108, Nokia 6175i, Nokia 6178i, Nokia 6230, Nokia 6230i, Nokia 6270, Nokia 6600, Nokia 6620, Nokia 6630, Nokia 6631, Nokia 6670, Nokia 6680, Nokia 6681, Nokia 6682, Nokia 6820, Nokia 6822, Nokia 7610, Nokia N70, Nokia N71, Nokia N72, Nokia N91, Nokia E50, Nokia E60
Check both on nokia site......
I checked mine...and i have to replace.....
**#(o)#**
24online is offline
Old 14-08-2007, 06:27 PM   #3 (permalink)
-- No Easter Eggs here --
hemant_mathur's Avatar
Default Re: Nokia Announces Product Advisory for BL-5C Battery
I just checked my battery serial number on the site and mine is not affected. Not ALL BL-5C batteries are affected. Check your battery serial number on the site before going to nokia centre.
E6850 3.0 Ghz, 4gb 667 Mhz RAM, Asus p5n Esli Mobo, Nvidia 8600GT 512mb, 400gb WD HDD, Samsung Syncmaster 920NW, Vista x64
hemant_mathur is offline
Old 14-08-2007, 06:45 PM   #4 (permalink)
dattebayo
anispace's Avatar
even mine is not affected.... u can check on the site i mentioned above.
But there are gonna be thousands or even millions of people affected since BL-5C is present on almost every Nokia cell phone.
anispace is offline
Old 14-08-2007, 06:51 PM   #5 (permalink)
The battery of my phone too not affected
ThinkFree is offline
Old 14-08-2007, 07:22 PM   #6 (permalink)
The Devil's Advocate
iMav's Avatar
neither is mine ... man my grandparents hav freaked and are constantly behind me for the past half hour to call every1 and chk theirs ... thanx to aaj tak
http://beingmanan.com
iMav is offline
Old 14-08-2007, 07:50 PM   #7 (permalink)
Alive Again...
satyamy's Avatar
Smile Re: Nokia Announces Product Advisory for BL-5C Battery
hurrray mine also not affected
! जय हिंद ! Proud to be INDIAN
satyamy is offline
Old 14-08-2007, 08:37 PM   #8 (permalink)
I think nokia server has crashed they have the text only version running for the moment
W i d e S c r e e N is offline
Old 14-08-2007, 08:39 PM   #9 (permalink)
* Teh Flirt King *
Quiz_Master's Avatar
Mine is not affected too. Yippie...
Quiz_Master is offline
Old 14-08-2007, 08:39 PM   #10 (permalink)
Thumbs up Re: Nokia Announces Product Advisory for BL-5C Battery
hurrayyyyy... mine also not affected...
short tips for checking the status of your battery without going to nokia website..
note only 46 million out of 300 million batteries are affected...
if u have purchased ur batter along with the mobile or as a separate accessory before december 2005.. then ur battery is not affected...
if it came with ur handset press *#0000# which will display the date of manufacturing of ur mobile phone and if it is before december 2005.. then you are safe...
happy charging...........
Cig... Nature... Opposite from each other..
paradise_guy is offline
Old 14-08-2007, 08:51 PM   #11 (permalink)
Back in Power
almighty's Avatar
^^^ ya and one more thing coz that lot was made by a japinese comp so if ur battery show made in china then not to worry at all... mine all nokia cells battery are chinese made
so no need to worry
¡uʍop ǝpısdn ɹoʇıuoɯ ʎɯ pǝuɹnʇ oɥʍ ¡ʎǝɥ
almighty is offline
Old 14-08-2007, 09:21 PM   #12 (permalink)
You gave been GXified
gxsaurav's Avatar
I missed this post & wrote one in mobile section. Mods plz move.
about.me/gxsaurav
gxsaurav is offline
Old 14-08-2007, 09:38 PM   #13 (permalink)
g_goyal2000's Avatar
Well, I have 9 mobile phones using BL-5C battery.
Out which I have checked only 3 & all 3 are registered with Nokia as problematic.
So have registered them & will be getting replacements.
But what time, I don't know.
I have yet to check the rest 6 & don't know what will their fate be.
BTW, the personnel with whom the rest of the 6 phones are have freaked out ever since I broke this news to them.
so no need to worry
Don't be too happy dude.
Mine 9 batteries too are China made out of which 3 have problems. For rest 6, haven't checked as yet. Will check them tomorrow and post results.
Dell Studio 1558, Intel i5 M430 @ 2.27 Ghz, 4 GB RAM, 1 GB ATI 5470 Mobility, 500 GB HDD, IDT HD Audio with Creative X-Fi MB software
g_goyal2000 is offline
Old 14-08-2007, 09:40 PM   #14 (permalink)
TechTin.com
ravi_9793's Avatar
I have just submited mine mom mobile battery number.They said...they will try to replace as soon as possible.
ravi_9793 is offline
Old 14-08-2007, 10:16 PM   #15 (permalink)
24online's Avatar
so no need to worry
mine is china made & i have to replace...
but when i gone nokia care center & authorised center, they told me that they dont know abt this issue... they will inform us after getting proper solution & ofcourse batteries.....
i think nokia dont know indian mentality.... it will create bad image.... as many ppl rush to care center by hearing abt battery issue on media.... but no response by care centers... i think nokia has to first inform nokia care centers and then inform in media & on net...... also most of ppl have tv but dont have internet to check battery id. no.... so it will be headache to nokia centers in coming days......
but nobody knows that what is fault in battery? means any proper reason ???
**#(o)#**
24online is offline
Old 14-08-2007, 10:18 PM   #16 (permalink)
Hey here is the aks
arunks's Avatar
mine battery is also under consideration..they said they will send new battery and i have to send them my battery in envelope that i will receive from them alongwith new battery
yours truly
arun
The aks!!
have a nice day
arunks is offline
Old 14-08-2007, 10:45 PM   #17 (permalink)
Rebooting
Choto Cheeta's Avatar
One of My friend is one victim
Model 6630
Well it didnt explode actually Just saw yesterday morning that the LCD developed a wide crack and the battery was wide open some liquide comming out from it...
Poor dude....
question is will nokia going to provide warrenty ??
But Phone Didnt explode
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 14-08-2007, 10:52 PM   #18 (permalink)
kumarmohit's Avatar
My 6630 battery is not affected, thank god!
kumarmohit is offline
Old 14-08-2007, 10:59 PM   #19 (permalink)
TechTin.com
ravi_9793's Avatar
My Mom is another victim
Old 14-08-2007, 11:00 PM   #20 (permalink)
Cool G5's Avatar
Post Re: Nokia Announces Product Advisory for BL-5C Battery
My phone doesn't use BL-5C. So no worries.
My friends have but they too are safe. Peace.
Cool G5 is offline
Old 14-08-2007, 11:40 PM   #21 (permalink)
And why should ppl panic? Are all these batteries going to explode today?
you've been using it for almost one year.
And you are lucky to get a brand new one.
cyberscriber is offline
Old 14-08-2007, 11:41 PM   #22 (permalink)
TechTin.com
ravi_9793's Avatar
Just for mind peace.thanks GOD..no one was harmed seriously.
Old 14-08-2007, 11:59 PM   #23 (permalink)
Mine is not affected. But one of my friends is. Saw one the Nokia manager on TV saying that they will send the replacement to home itself. When will he can expect the replacement?
Anyone who has never made a mistake has never tried anything new
sandeepk is offline
Old 15-08-2007, 12:54 AM   #24 (permalink)
The Frozen Nova
casanova's Avatar
Mine is affected
Entered my sr. no and they asked for address details for replacement.
www.nerdweed.blogspot.com
casanova is offline
Old 15-08-2007, 01:37 AM   #25 (permalink)
Well, it seems that either the Nokia Care helpline is either jammed due to calls or they've just shut the number cos when I call, it either says that all lines are busy (when calling from landline) or sometimes says that u'r request could not be completed (when calling from mobile or calling the toll-free number from landline).
Apparently, the Nokia India customer care wasn't ready for would come next after the news.
Which is bad for most people.
Old 15-08-2007, 07:37 AM   #26 (permalink)
I have a Nokia 1110i, and the battery model is BL-5CA. Will that be also prone to the problem?
Arun
sakumar79 is offline
Old 15-08-2007, 08:19 AM   #27 (permalink)
Rebooting
Shouldnt be, neither the model matches nor the Battery code
rebooting
ChotoCheeta.com
Old 15-08-2007, 01:12 PM   #28 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
phati phati .......... nahi phati ........... y ??
oooh ........ battery make is diff ..............
... W H O T ...
ax3 is offline
Old 15-08-2007, 01:14 PM   #29 (permalink)
@Choto Cheeta - I hope so, but phone model and battery model are so similar to the problem (1110 and 1110i, 5C and 5C-A), so was a bit worried...
Arun
Old 16-08-2007, 09:26 AM   #30 (permalink)
sourav's Avatar
The big hype today is that your Nokia mobile battery is going to go kablooey! That’s a load of C**p. Don’t worry people your Nokia phone battery no. BL-5C is NOT, I repeat, NOT going to explode. Here’s the real scoop on what’s going down inside your battery compartment.
The Scoop
Picture a slightly large balloon inside a tiny paper bag being blown up. In reality what’s going to happen is the balloon will continue to get filled and finally tear through the bag. The balloon will not explode, it simply increase in size.
Here’s the low down. Every time your phone is charging the current is causing your battery to heat up and therefore expand a wee bit. Since you already know that the battery compartment fits the battery perfectly and there’s really no room for expansion so it simply pops out of its casing. AND THAT’S IT! This is how it is according Nokia.
Nokia has issued an Advisory that has gone out to every one of us who can get it out to you as soon as possible. There is no cause to be alarmed at all. Let me put it this way – just take a chill pill people.
The batteries in question – the BL-5C manufactured by Matsushita Battery Industrial Co., Ltd. of Japan are quite common to most Nokia phones. You’ll find them in models like the Nokia 6270, Nokia 1100, Nokia 3100, Nokia 6230, Nokia 6600, Nokia N70, and Nokia E60. These are just a few of the more common models of course. If you want the complete list check out Nokia.com And Nokia is working closely with Matsushita and will be cooperating with relevant authorities to investigate this situation.
According to Nokia, even though there were around 300 million batteries like this there were only 46 million batteries that were manufactured during the period of December 2005 and November 2006 are the ones in question. Out of that number there have been approximately 100 incidents of overheating reported globally. No serious injuries or property damage have been reported and according to Nokia’s knowledge this issue does not affect any other use of the mobile device.
Now people please understand that the advisory that Nokia has provided is strictly for those who own Nokia phones that have the BL-5C battery that has been manufactured during the given period i.e. between December 2005 and November 2006. Other Bl-5C’s will have no problem.
source : www.tech2.com
We must accept finite dissapointment. But we must never loose infinite hope.
sourav is offline
Nokia Announces Seven Handsets for Emerging Markets 2kewl Mobiles and Tablets 1 03-05-2007 08:42 PM
Nokia Battery Consumption Ratio hikapil Mobiles and Tablets 9 26-01-2005 11:43 AM
- by Krow
- by iGamer
