as the title suggests...
respected ladies and gentlemen...
after much persuasion...i have fially convinced my folks to spend some money on me to get a laptop..
now after considerable bargians to increase the budget...i have shortlisted down to the hp pavillion dv6314...
i liked the config...but i need sum sorta user review...
need all the pros and cons...etc.etc...
shivi
A review is not required. The specs are good, & it is like replacement of HP DV6226TX laptop. Just make sure u get the 9 Cell battery & 3 years warrenty.
shivi
i have purchased dv6314 its good
1.73ghz core 2duo
1gb ram
160 hdd
vista ultimate
web cam
card reader writer
blue tooth
15.4inch screen
almost every thing
but i think the model is discontuned
thanks a lot saurabh...i liked the specs as well...and i have bought one...im getting an extended 3 year warranty for 7000/- ...i shall look into the 9 cell battery option thing...thakns mate...
