Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 27-07-2007, 11:45 AM   #1 (permalink)
The Devil's Advocate
iMav's Avatar
Default Secure IronKey Flash Drive Will Self-Destruct in 3...2...1...
Designed to be the world's most secure flash drive, the IronKey employs military-grade AES hardware-based encryption using its IronKey Cryptochip. The encryption keys are stored on the drive itself and your password is required in conjunction with the keys to access and decrypt files. If you forget your password, you may be in trouble; after ten consecutive failed password attempts, the IronKey self-destructs (internally) and erases everything on the drive using "flash-trash" technology that physically overwrites every byte, making the data completely unrecoverable.
The hardware encryption is one aspect of the IronKey, but the online component is another. When you log in to the IronKey website (which again requires both your password and your IronKey to be physically plugged in to your machine), you can activate their secure web-browsing service which turns FireFox into a malware-protected, "stealth surfing" application. Other security-nut features include a "potting" technique that fills the innards of the key with black goo, waterproofing it past military standards and preventing hardware crypto-analysis. $79 will get you 1GB of peace of mind, but the biggest option is the 4GB drive for $149
Source
http://beingmanan.com
iMav is offline
Old 27-07-2007, 12:11 PM   #2 (permalink)
dd_wingrider's Avatar
Default Re: Secure IronKey Flash Drive Will Self-Destruct in 3...2...1...
thx for sharing
http://iphone3g-india.com - One stop for all iPhone3G updates, tips,news,resources
http://iPadarena.com - Teh iPad Blog
dd_wingrider is offline
Old 27-07-2007, 01:24 PM   #3 (permalink)
Cool G5's Avatar
Post Re: Secure IronKey Flash Drive Will Self-Destruct in 3...2...1...
Useful for paranoids.
Cool G5 is offline
Old 27-07-2007, 06:14 PM   #4 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Can this security be decrypted?
rakeshishere is offline
How to convert ordinary flash drive into U3 smart drive? thetopcyborg QnA (read only) 13 02-11-2008 11:59 PM
Need some suggestions about buying Pen Drive(flash drive) ~It_is_Andrew~ Hardware Q&A 16 14-09-2006 10:23 PM
Diffrence between an usb pen drive & a flash pen drive? harpoon Peripherals 3 18-01-2006 11:25 PM
USB Flash Drive smash555 Peripherals 3 30-09-2005 03:53 PM
What do you use your USB flash drive for? rohanbee Peripherals 21 30-05-2005 03:10 PM
- by Krow
- by iGamer
