Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 17-07-2007, 11:46 AM   #1 (permalink)
sachin_kothari's Avatar
Default VLite 1.0 Final Released
Windows Vista from Microsoft takes a lot of resources, we all know that. So here is the tool for easy removal of the unwanted components in order to make Vista run faster and to your liking. vLite can also create the bootable ISO and apply the tweaks directly.
This tool doesn't use any kind of hacking, all files and registry entries are protected as they would be if you install the full version only without the components you select for the removal.
It configures the installation directly, before the installation, meaning you'll have to remake the ISO and reinstall it. This method is much cleaner, not to mention easier and more logical than doing it after installation on every reinstall.
Changes in v1.0 Final:
* new: 'Windows Portable Devices'
* new: IIS and Halo 2 Compatibility options
* upd: 'Natural Language' (64bit leftovers)
* fix: Hotfixes cleanup when integrated before
* fix: 'Defrag' (Shrink ability saved)
* fix: 'Game Explorer' (gameux.dll popups)
* fix: 'Internet Explorer' (DX Web installer)
* fix: Memory Requirement option (Manual Install dependency)
Change Log - http://vlite.net/changelog.html
Download - http://vlite.net/download.html
sachin_kothari is offline
Old 17-07-2007, 12:37 PM   #2 (permalink)
Make Way the LORD is Here
ssk_the_gr8's Avatar
Default Re: VLite 1.0 Final Released
thanx for the unfo
will try it if i get time
(Gen.1:26-27) New Testament
FORUM RULES - Updated
Don't Buy from Sulekha
ThinkDigit Forum Workspace Showoff Contest
ssk_the_gr8 is offline
Old 17-07-2007, 01:08 PM   #3 (permalink)
You gave been GXified
gxsaurav's Avatar
Nice, time to slim the beast
about.me/gxsaurav
gxsaurav is offline
Old 17-07-2007, 01:51 PM   #4 (permalink)
do post your installation size after vliting vista.
will update mine once i try it.
Edit - My 64 bit Vista is reduced to 1.24 GB
Flashget 1.80 Final released manas Technology News 2 12-12-2006 08:13 PM
NOD32 v2.7 Final released! kalpik Technology News 16 24-11-2006 06:34 PM
WinRAR 3.50 - Final released rajat22 Software Q&A 5 09-08-2005 07:04 PM
Opera 8.01- Final Released Curious Guest QnA (read only) 6 23-06-2005 11:18 PM
~Trillian 3.1 Final Released~ drgrudge QnA (read only) 9 02-03-2005 12:10 AM
- by chris
