Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 28-06-2007, 01:00 AM   #1 (permalink)
The Devil's Advocate
iMav's Avatar
Default IBM Announces PetaFLOP Blue Gene Supercomputer
IBM's Blue Gene/P triples the performance of its previous supercomputer
The performance jump from Blue Gene/L and Blue Gene/P is due to several factors. In hardware, the Blue Gene/P supercomputer moves to doubles the number of processors per chip, with each processor operating at a higher clock speed. More memory is added along with an SMP mode to support multi-threaded applications. This new SMP mode moves the Blue Gene/P system to a programming environment similar to that found in commercial clusters. The system’s software is also upgraded for Blue Gene/P with refinements to system management, programming environment and applications support.
"Blue Gene/P marks the evolution of the most powerful supercomputing platform the world has ever known," said Dave Turek, vice president of deep computing, IBM. "A new group of commercial users will be able to take advantage of its new, simplified programming environment and unrivaled energy efficiency. We see commercial interest in the Blue Gene supercomputer developing now in energy and finance, for example. This is on course with an adoption cycle – from government labs to leading enterprises – that we've seen before in the high-performance computing market."
Four IBM PowerPC 450 processors running at 850 MHz are integrated on a single Blue Gene/P chip, with each chip capable of 13.6 billion operations per second. A two-foot-by-two-foot board containing 32 of these chips churns out 435 billion operations every second, making it more powerful than a typical, 40-node cluster based on two-core commodity processors. Thirty-two of the compact boards comprise the 6-foot-high racks. Each rack runs at 13.9 trillion operations per second, 1,300 times faster than today's fastest home PC.
Full Article
http://beingmanan.com
iMav is offline
Old 28-06-2007, 01:01 AM   #2 (permalink)
You gave been GXified
gxsaurav's Avatar
Default Re: IBM Announces PetaFLOP Blue Gene Supercomputer
Good, but.....Will it blend or does it calculates in HD
about.me/gxsaurav
gxsaurav is offline
Old 28-06-2007, 01:37 AM   #3 (permalink)
I WANT MORE FPS!!
adithyagenius's Avatar
Can it run crysis at decent framerate?
E8500+Asus P5Q Pro, GTX280 OC, 4GB RAM+RAID0 2*WD 500GB, CM690+Corsair 650TX, Razer Diamondback+Goliathus Control Edition Omega, Microsoft Natural Ergonomic 4000, Dell E228WFP, X-Fi Titanium+T6060
adithyagenius is offline
NASA selects IBM for next-gen supercomputer system Gigacore Technology News 3 08-06-2007 05:53 PM
Tyan launches the personal Supercomputer gxsaurav Technology News 7 28-03-2007 11:51 AM
Microsoft delays supercomputer version of Windows Sourabh Software Q&A 1 07-04-2005 11:31 AM
- by chris
