Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 06-06-2007, 01:43 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
morpheusv6's Avatar
Thumbs up Dataone Usage Finder 1.5a released
source: http://duf.sourceforge.net/
Ver. 1.5a (4th May 07)
BSNL, a major ISP from India recently introduced its broadband Internet service named Dataone (www.bsnl.co.in/service/dataone.htm). This service imposes an upload/download usage limit on its users. Usage between 2am and 8am is free, under certain schemes. This makes it imperative for the users to keep an eye on their usage statistics. However, the BSNL website which provides these usage figures is not very useful, as any Dataone user will vouch.
Only the monthly total of the bandwidth used is provided. There is no provision for knowing the daily total. Also there is no demarcation between free time usage and paid time usage. These are the very figures a user would be most intersted in.
To calculate these figures, one either has to somehow get the raw statistics from the site manually into a spreadsheet or use a couple of utilities floating around on the net.
One such utility is an open source perl script hosted at dob.sourceforge.net. Another, and admittedly a very useful one, is at www.shaplus.com. However this utility is closed source, and understandably, users are wary of handing out their usernames and passwords to an untrusted application.
I, therefore coded a quick and dirty version of this program for myself. It served my purpose well and now I am making it open source so that it may be useful to a wider audience.
DUF (Dataone Usage Finder) is a very simple screen scraper program coded in VB6 (Yes guys, VB is still used!). It uses IE5 or higher, to fetch pages from the BSNL site, and after parsing out the required records, presents them in a manner which is more helpful. This data can also be saved as html files.
Hope you find it useful. Please send in your comments and suggestions to make DUF better.
Changes:
Version 1.5a released (May 4th 2007)
Okay, so the chinese developers at BSNL finally made some changes to their site. They changed a column heading from "Excluding Night Unlimited" to "Fee"! Wow.
Anyways since DUF is a duffer screen scraper, it failed.
Here is the patched version.
It will last only as long as there are no further changes in the BSNL site.
I am beginning to hope that is never
download: http://internap.dl.sourceforge.net/s...1.5a_setup.exe
Deven
morpheusv6 is offline
Old 06-06-2007, 02:00 PM   #2 (permalink)
HAF 922 Owner
i_am_crack's Avatar
Default Re: Dataone Usage Finder 1.5a released
thanks a lot... very usefull and handy
eBRo
Well Actually I forgot to say Hi to you???? Can I say now???
i_am_crack is offline
Old 06-06-2007, 07:07 PM   #3 (permalink)
hailgautam's Avatar
I have been using Data one Useage finder since long, I noticed that BSNL Night UL plan does not start from 2am but it takes a while -- only after 2.30 a.m one month i had to pay a huge bill due to this. Man @ 160-180 Kbps it downloads a lot.
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
hailgautam is offline
Old 06-06-2007, 07:39 PM   #4 (permalink)
!! RecuZant By Birth !!
naveen_reloaded's Avatar
anything similar for airtel please????
Know My Thoughts..
Visit my Blog @ www.Urssiva.com
Visit My Tech Blog @ www.CloudTechnica.com
naveen_reloaded is offline
Old 06-06-2007, 08:38 PM   #5 (permalink)
how much speeds do u get on ul ?
sagargv is offline
Old 06-06-2007, 11:30 PM   #6 (permalink)
sachin_kothari's Avatar
have used this before. now on UL
sachin_kothari is offline
Old 07-06-2007, 01:34 AM   #7 (permalink)
Rubik's Uncle!!
Charan's Avatar
@morpheusv6 thanks BTW there is no source code for 1.5a I wonder when it will be uploaded
Charan is offline
Old 08-06-2007, 02:49 PM   #8 (permalink)
morpheusv6's Avatar
Wink Re: Dataone Usage Finder 1.5a released
Yes same was the case with me a while ago when I used to keep the system on for downloading. The trik is that you have reconnect the modem at 2 am to start the UL slot properly else it gets added to the Limit. Here's a tutorial I had found on the net for schduling the downloads and it works.
Bsnl 2-8 download while u r asleep(my tutorial)
I have also mentioned the time details for the BSNL clock. Synchronize your downloads according to that.
Deven
Old 08-06-2007, 11:59 PM   #9 (permalink)
sauravktr's Avatar
Thanks 4 the Info
sauravktr is offline
Old 09-06-2007, 07:13 AM   #10 (permalink)
sabret00the's Avatar
thnax a lot buddy very useful info
C2D E6600,Asus P5N32 e SLI,1GB 667mhz,Samsung 940BW,Zeb 8600GT,Seagate 250GB sata II,16x Sony(OEM) dvd RW,Zeb Anitibiotic & Platinum 500W,Microsoft desktop pro 700,bluetooth,Logitech MX Revolution
sabret00the is offline
Old 09-06-2007, 12:33 PM   #11 (permalink)
thanks for find ..
hermit is offline
Old 09-06-2007, 08:34 PM   #12 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
DUF is very good programme to find the dataone usage. But there is one silly mistake in the Billing page. The Service tax will be 12.36% as the GOI introduce Higer education Cess as 1% on ST wef 11/05/2007 in addition of Normal Education Cess of 2% on ST.
skghosh44 is offline
Old 10-06-2007, 02:12 AM   #13 (permalink)
downloaded the program and installed it...very good program...thnx
LinkBack to this Thread: http://www.thinkdigit.com/forum/technology-news/59633-dataone-usage-finder-1-5a-released.html
Thread ShaPlus Dataone usage finder 2.8 | Digit Forum | BoardReader This thread Refback 01-11-2010 08:46 PM
doubt with dataone usage abinesh Software Q&A 11 31-05-2007 10:09 PM
BSNL Dataone usage issues..... hittheswitch Software Q&A 10 21-03-2007 12:32 PM
Dataone usage & PC scheduling webgenius Broadband and DTH 2 08-03-2007 05:57 PM
How 2 Know The Bsnl Dataone Usage kuldeep bhardwaj Broadband and DTH 3 04-05-2006 05:25 PM
BSNL DataOne Usage Finder (Open Source) released puja399 Broadband and DTH 4 07-01-2006 11:33 PM
- by chris
