Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 18-05-2007, 10:03 PM   #1 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Default Vista's ReadyBoost flash drives lack significant boost
Windows Vista's Windows ReadyBoost sounds too good to be true, and based on our extensive lab tests, it is. The technology promises to let you speed up Windows by plugging an inexpensive USB flash drive into your PC. But we found that while ReadyBoost may speed up Vista a tiny bit, it can also slow it down in some instances.
The premise is this: Although writing data to and reading it from a flash drive is, in most cases, slower than writing and reading to a hard drive, if the data is scattered randomly in small chunks, then flash drives are faster. Vista's ReadyBoost is supposed to use that one speed advantage to create a faster, flash-drive-based cache of one of Windows' major bottlenecks -- the swap file on your hard drive that most Windows operations use. So ReadyBoost should theoretically speed up certain frequently performed Windows tasks such as loading programs.
The technology works with only the fastest flash drives -- those capable of 3.5MB/sec. throughput for 4KB random reads, and 2.5MB/sec. speeds for 512KB random writes. For this article, the PC World Test Center and I looked at three ReadyBoost-capable drives: Kingston's 1GB DataTraveler ReadyFlash, Lexar Media's 4GB JumpDrive Lightning and Ritek's Ridata 1GB Twister EZ Drive.
Source : http://www.computerworld.com/action/...icleId=9019742
techtronic is offline
Old 18-05-2007, 10:41 PM   #2 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Default Re: Vista's ReadyBoost flash drives lack significant boost
Yes....This Info is certainly True
rakeshishere is offline
Old 18-05-2007, 10:43 PM   #3 (permalink)
You gave been GXified
gxsaurav's Avatar
Oh comon, whoever expects Readyboost to be RAM replacement must be out of his mind.
about.me/gxsaurav
gxsaurav is offline
Old 18-05-2007, 11:25 PM   #4 (permalink)
El mooooo
eddie's Avatar
^ Please don't read just the last two lines in an article. Read the whole page before making comments. The article talks about the difference between flash drive and swap file on hard drive...not RAM. The second last line is just supposed to be an advice and not a reflection on the fact mentioned in the article.
Windows users shouldn't get to use the real computers. They know just enough to be dangerous.
eddie is offline
Old 19-05-2007, 12:05 AM   #5 (permalink)
hmm...readyboost works fine with my 1 gb sd card(courtesy my roomie's digicam)...costs just Rs. 650.....howz that for a cheap performance boost ???
Put your hand on a hot stove for a minute, and it seems like an hour.
Sit with a pretty girl for an hour, and it seems like a minute.
That\'s relativity - Albert Einstein
great_manish is offline
Old 19-05-2007, 12:17 AM   #6 (permalink)
aryayush's Avatar
I used my Corsair Flash Voyager 1 GB flash drive with Vista and certainly did not experience any boost in responsiveness of the operating system. Of course, I already have two gigabytes of RAM installed so maybe the feature is not for me anyway. Vista is certainly slower than XP though.
aryayush is offline
Old 19-05-2007, 12:46 AM   #7 (permalink)
gxsaurav's Avatar
On similar hardware, Vista is faster then XP. However on new hardware or old hardware unless you have proper driver support Vista will be slow.
Are you running it on Macbook ? Try installing the official intel drivers insted of the ones provided by Apple
The chipset is 945PM + ICH7
about.me/gxsaurav
gxsaurav is offline
Old 19-05-2007, 12:51 AM   #8 (permalink)
what ive noticed is that vista certainly boots up faster than xp.....
Old 18-07-2007, 12:24 AM   #9 (permalink)
Can this ReadyBoost feature be used with any Motherboard/Processor or we need to have selected MB/CPU also?
suhasde is offline
Old 18-07-2007, 12:27 AM   #10 (permalink)
Wire muncher!
infra_red_dude's Avatar
readyboost requires a fast flash drive and doesn't haf anything to do wid mobo/cpu combo
infra_red_dude is offline
Old 18-07-2007, 07:54 AM   #11 (permalink)
HELP AND SUPPORT
And Also OS should be Vista along with a compatible ReadyBoost Flash drive
Old 18-07-2007, 08:44 AM   #12 (permalink)
Wire muncher!
vista? obvisouly!! regarding 'compatible readyboost drive' a fast drive is enough. even if its not a certified one but has reasonably fast speeds it can be used for readyboost (tho i never saw any performance gain due to readyboost!)
Old 18-07-2007, 09:58 AM   #13 (permalink)
Wandering in time...
Ankur Gupta's Avatar
Well I used my San Disk Cruzer 1GB drive as ready boost and did not get any significant boost even though I have only 512MB RAM...
Having more RAM is the only way out...seems like a useless feature to me..more of a marketing gimmick...
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
Ankur Gupta is offline
Old 18-07-2007, 07:48 PM   #14 (permalink)
HELP AND SUPPORT
I just mentioned that coz I have seen innumerous queries in this forum- "whether is it possible to have ReadyBoost feature in XP?"
ANNOUNCEMENT
Currently,No hacks/tweaks have been found to use this kind of a feature in XP
Old 18-07-2007, 09:51 PM   #15 (permalink)
Wire muncher!
ANNOUNCEMENT
yeah rakesh.. true .....
but i think even in vista this feature is useless. i've tried it on several computers.. wid different flash drives.. some which were readyboost certified... i didn't find any noticable difference in performance.
Old 18-07-2007, 10:23 PM   #16 (permalink)
Hanging, since 2004..
tarey_g's Avatar
Is your drive passing the the min specs to be used as readyboost. Chk the MS site . A non compatible pen drive will slow down the process instead of speeding it . I have tested this with my (below specs )Transcend 1gb drive and it sucked. So before posting comments here pls chk the compatibility of your drive.
Windows 8 ? :lol:
I have a better OS installed, people call it Windows7 8-)
tarey_g is offline
Old 19-07-2007, 02:06 AM   #17 (permalink)
HELP AND SUPPORT
^^ Me too ..But i do have seen People reporting a considerable amount of diff @ Winvista official blogs where users did notice perfomance while working on Photoshop CS3
Old 19-07-2007, 09:08 AM   #18 (permalink)
Yes the drive is Ready Boost Compatible...
And yeah many Transcend ones are not...
I never said it slowed my PC,I said that it didnot show any significant performance boost..
Old 19-07-2007, 09:45 AM   #19 (permalink)
tarey_g's Avatar
what drive you have and what are the specs?
Windows 8 ? :lol:
tarey_g is offline
Old 19-07-2007, 10:11 AM   #20 (permalink)
I assume we can use a portable usb hdd too for doing this, is that right?? or it has to be a flash drive?
ranjan2001 is offline
Old 19-07-2007, 01:45 PM   #21 (permalink)
King of my own Castle
freshseasons's Avatar
I think the flash drive is preferable.
The USB harddisk will not be able to pass the ready boost test when Vista asks for in when you plug it.Moreover there is no significant boost from the harddisk.
The Very purpose of ReadyBoost is taking those files of slow harddisk.
So it has to be Flash Drive.
freshseasons is offline
Readyboost incompatible flash drives workaround Arsenal_Gunners Tutorials 7 30-03-2007 11:19 PM
Analysis: Vista's Ready Boost is no match for RAM techtronic Technology News 22 10-02-2007 10:01 PM
SanDisk rolls out flash hard drives for laptops s18000rpm Technology News 4 05-01-2007 03:17 PM
Top 10 Significant Hardware of 2006 techtronic Technology News 7 19-12-2006 02:16 PM
- by chris
