After RED was mentioned at the NAB event when Apple released Final Cut Studio 2, I checked out their site.
This camera is one sexy piece!
Typical high-end HD camcorders have 2.1M pixel sensors and record with 3:1:1 color sub-sampled video at up to 30fps. We deliver 12M pixels at up to 60fps and record 12 bit native RAW, or 10 bit over-sampled HD your choice. That’s more than 5 times the amount of information available every second and a vastly superior recording quality. Don’t need all that data for your workflow? Dial it back, and keep all the other advantages of the Mysterium™ Super 35mm cine sized (24.4 x 13.7mm) sensor. You get the same breathtaking Depth of Field and selective focus as found in film cameras. Mysterium™ boasts a greater than 66db Signal to Noise Ratio thanks to its large 29 sq. micron pixels. And 12,065,000 pixels deliver resolution that can only be called Ultra High Definition.
Its gonna be the new IMAX I guess...
http://www.red.com/
Currently downloading all the demo clips...
