Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 06-04-2007, 01:28 AM   #1 (permalink)
El mooooo
eddie's Avatar
Default Vista's long goodbye
Source: The Register
Vista's long goodbye : Deleting files can take forever
Windows Vista suffers from a bug that causes many machines to stall while deleting, copying and moving files, a flaw that has provoked consternation in online forums.
"I've seen this bug in action, and trust me, it's as if you're copying over a 64k link using only 256mb of RAM," one Reg reader complained. "To add to the problem, you can't cancel or anything."
According to a thread on Microsoft's TechNet site, Microsoft has issued a hotfix for the problem, but it has failed to quell the outrage. For one thing, individual users must get Microsoft's approval before the fix can be downloaded, according to our tipster. And for another, hotfixes are more of a pain to install than patches.
We've contacted a Microsoft spokeswoman, who promised to see if a patch for the problem in the works. Meanwhile, Vista users continue to grumble.
"I simply can not believe that I updated to a new computer and put windows Vista on it to find that it's not even capable of moving and deleting files in an efficient manner," one disaffected user posted in the Microsoft forum. "Microsoft must be kidding! The most basic of features that I use all the time is a slow train wreck." ®
P.S. I know it is old news but it might be new for some people and in my search on forums, I could not find any such topic. If it has been, then please merge it with the earlier thread
eddie is offline
Old 06-04-2007, 01:38 AM   #2 (permalink)
String Phreak
mediator's Avatar
Default Re: Vista's long goodbye
Its a news for me alright! It seems I'll be installing integrated VISTA-SP1 then.
mediator is offline
Old 06-04-2007, 01:52 AM   #3 (permalink)
 Macboy
goobimama's Avatar
This has happened to me as well... many times.
I'm like a bird... :)
goobimama is offline
Old 06-04-2007, 02:13 AM   #4 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
I have not been experiencing any such problems at all,i have copied files over 7.94 gb without any problems in Windows Vista Ultimate.In fact i am currently using vista.
Harvik780 is offline
Old 06-04-2007, 02:22 AM   #5 (permalink)
 Macboy
goobimama's Avatar
^^ Doesn't happen every time....
Btw, are you a HD movie collector?
Old 06-04-2007, 12:22 PM   #6 (permalink)
Wandering in time...
Ankur Gupta's Avatar
Well yeah this problem happens with me more often that not..hope a patch is included in SP1....
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
Ankur Gupta is offline
Old 06-04-2007, 12:40 PM   #7 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
I hv also noticed that Vista takes more time to copy/move/delete files than XP. I hv noticed a BIG difference in deleting files...
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 06-04-2007, 02:45 PM   #8 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Can confirm! Happens here too!
kalpik is offline
Old 06-04-2007, 03:10 PM   #9 (permalink)
Hanging, since 2004..
tarey_g's Avatar
Ya , happened to me too once, one small file took 2 mins to delete.
Windows 8 ? :lol:
I have a better OS installed, people call it Windows7 8-)
tarey_g is online now
Old 06-04-2007, 04:15 PM   #10 (permalink)
thunderbird.117
Posts: n/a
Ok. How long it takes to delete 4 GB file?.
Old 06-04-2007, 04:49 PM   #11 (permalink)
String Phreak
mediator's Avatar
^+How long it takes to defragment then?
mediator is offline
Old 06-04-2007, 04:55 PM   #12 (permalink)
tarey_g's Avatar
It does not happen always , but i happpens. it happend with my installation once in 1 month. So definitely a fix is needed .
I did defrag too , it was normal.
Windows 8 ? :lol:
Old 07-04-2007, 01:18 AM   #13 (permalink)
El mooooo
eddie's Avatar
Ok so Microsoft accepts the flaw (partially) and they released a hotfix (not a patch) but they will not give it to you until you ask nicely and politely
http://support.microsoft.com/default.aspx/kb/931770
So much for spending more than 20,000 bucks on an OS that wouldn't even copy-paste properly.
eddie is offline
Old 07-04-2007, 11:43 AM   #14 (permalink)
I Always Prefer 1080p
techtronic's Avatar
I have not experienced this even once.
I deleted about 3.6 GB worth of Very Important Data (Porn). It took the same time as XP
techtronic is offline
Old 07-04-2007, 01:25 PM   #15 (permalink)
 Macboy
goobimama's Avatar
^^ pr0n is not the same as junk. Please correct yourself. In fact, on many computers, it is the only meaningful form of data that exists...
Old 07-04-2007, 02:16 PM   #16 (permalink)
tarey_g's Avatar
Yes porn is definitely not junk , pls correct your post or i will report it to mods
Windows 8 ? :lol:
Old 07-04-2007, 02:56 PM   #17 (permalink)
techtronic's Avatar
Lol
Lol
Old 07-04-2007, 03:52 PM   #18 (permalink)
 Macboy
goobimama's Avatar
LOL right back at ya...
Old 07-04-2007, 07:39 PM   #19 (permalink)
rake
Posts: n/a
The problem differs from configuration to configuration. There is no standard cure of this problem. One fix is to have latest manufacturer supplied Chipset drivers for your motherboard. Most of the companies have released new drivers already either in final or beta version.
MS requires you to call them, so that they can find how many people are having this problem with file copy & on what computer configuration.
You can download the fix from these links for the applicable configuration you have. I got these yesterday night from Microsoft Tech support myself. Although X64 version is also available on http://hotfix.xable.net
Vista X86 = http://hotfix.xable.net/download/ind...931770-x86.msu
Vista X64 = http://hotfix.xable.net/download/ind...931770-x64.msu
or rapidshare http://rapidshare.com/files/24670720...0-x86.msu.html
Disable download managers if you are downloading from the above links. Size = 176 KB
Another fix is to uninstall Remote diffrential Compression from Windows Vista, if you don't need it. Home users won't need it anyway.
In Windows Vista, go to control panel - > Programs -> Add\Remove Windows Components & uncheck "Remote differential Compression", then click on ok.
Make sure "Windows Update" & "Background intelligent transfer service" are running else you will not be able to install any "Microsoft Update" or .msu files in Windows Vista.
Old 07-04-2007, 11:24 PM   #20 (permalink)
kalpik's Avatar
Welcome back GX!
kalpik is offline
Old 07-04-2007, 11:25 PM   #21 (permalink)
18 Till I Die............
gx i thought you were not supposed to make another id on this forum? And you make a new one with your email id of yahoo - gxsaurav06
http://www.bash.org/?258908
mehulved is offline
Old 07-04-2007, 11:29 PM   #22 (permalink)
rake
Posts: n/a
I don't wanna post here right now, already banned myself for 1 month insted of 2 weeks. Just came here to post this fix thats it
Old 07-04-2007, 11:31 PM   #23 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Cool Re: Vista's long goodbye
No i burn backups of my Xbox 360 games.
Old 07-04-2007, 11:53 PM   #24 (permalink)
El mooooo
eddie's Avatar
BTW, those hotfixes are not supposed to be redistributed...so technically those links are illegal.
eddie is offline
Old 08-04-2007, 07:55 AM   #25 (permalink)
Let the music play.....
djmykey's Avatar
See this might be one of the reasons that M$ recommends high end hardware for Vista. I havent used it much but in our office no one complained abt this. I even took back my group head's laptop which had vista installed, he was deleting something like 7 GB of data and it went off in 5-6 mins. The laptop was a Dell one with 1 GB of ram nothing special (Latitude 610)
djmykey is offline
Old 08-04-2007, 10:21 AM   #26 (permalink)
rake
Posts: n/a
It is a known bug in explorer.exe. if you are using some other file manager, copying does not takes this much time.
Old 08-04-2007, 11:28 AM   #27 (permalink)
Self-Obsession
hittheswitch's Avatar
Hey.... this is a very prominent thing in Vista... It happens most o the times....
For the first few second...the dialog box freezes..... Its very stupid of Vista.....
I'm walking between mads,but whats the use i'm still the worst one.
hittheswitch is offline
Old 08-04-2007, 07:09 PM   #28 (permalink)
The Frozen Nova
casanova's Avatar
Never happened with me but i feel the copying and moving is slow.
www.nerdweed.blogspot.com
casanova is offline
Old 08-04-2007, 10:49 PM   #29 (permalink)
Microsoft MVP
Even if u delete a simple 300 KB file, sometimes it shows "Calculating time" for a few seconds and then start deleting it and shows the progress bar for a few seconds. In XP it hardly took 1 sec. to delete such files.
Old 08-04-2007, 11:15 PM   #30 (permalink)
Administratus Rotundus
FatBeing's Avatar
This is strange.. is this supposed to be a problem on just 32-bit? Because I've been using 64-bit for a few days and copying and moving is just like XP...
YOU SHALL PAY FOR YOUR SINS!
(In case you have already paid, please ignore this notice)
FatBeing is offline
Vista's in business saipothuri Technology News 1 30-12-2006 09:44 AM
vista's restrictions to users mihirvashist Technology News 29 09-07-2006 05:25 PM
- by Krow
- by iGamer
