Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 06-02-2007, 09:19 AM   #1 (permalink)
Kiran.dks's Avatar
Thumbs up LG Releases first dual-format DVD player <Blue-Ray & HD-DVD>
LG unleases first dual-format DVD player in stores
Industry's first dual-format high-definition disc player is now available at retail stores
LG Electronics today said the industry's first dual-format high-definition disc player is now available at retail stores with a price tag of about $1,200, according to Pricegrabber.com.
The LG Super Multi Blue Player (LG BH100) was unveiled at the Consumer Electronics Show last month (see "LG to show dual HD DVD/Blu-ray player"). The player is now available at national retailers, such as Best Buy, Circuit City and CompUSA, as well as regional retailers and local dealers.
The LG BH100 allows you to play both Blu-ray Disc and HD DVD high-definition content by blending both technologies. While some industry pundits have seen the combination of the two high definition DVD formats as a solution to the quandry of which format to choose.
The LG BH100 incorporates interactive functions based on BD-Java, which allows advanced menus and functions to be displayed over the video of Blu-ray discs. The same level of advanced menu interactivity is not available while playing HD DVD discs.
The player also upconverts standard DVDs to 1080i resolution, providing compatibility with existing movie libraries while improving the picture quality of those discs, LG said in a statement.
The BH100 supports various A/V formats, including MPEG-2, VC-1, H.264 video, MPEG1/2 audio, Dolby Digital, Dolby Digital+, DTS and DTS-HD audio. The unit also includes multiple inputs/outputs such as HDMI out, component/composite video outputs, and optical/coaxial/discrete 5.1 channel audio outputs, among others.
News Courtesy: ComputerWorld
Image from Gizmodo
Kiran Kumar R
Kiran.dks is offline
Old 06-02-2007, 09:44 AM   #2 (permalink)
krazyfrog
Posts: n/a
Default Re: LG Releases first dual-format DVD player <Blue-Ray & HD-DVD>
^ thanks for the info
Old 06-02-2007, 10:36 AM   #3 (permalink)
hailgautam's Avatar
Will any one of u buy in next 6 months?
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
hailgautam is offline
Old 06-02-2007, 03:15 PM   #4 (permalink)
 Macboy
goobimama's Avatar
At that price it would be better to buy two standalone Blu-ray and HD DVD players.... Its a rip off...
I'm like a bird...
goobimama is offline
Old 06-02-2007, 07:51 PM   #5 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Dank für das Info
techtronic is offline
Old 06-02-2007, 07:52 PM   #6 (permalink)
Tech Geek's Avatar
Thanks for the info
Tech Geek is offline
