Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 01-02-2007, 09:26 PM   #1 (permalink)
hailgautam's Avatar
Default Capture Fancier Screenshots with RumShot
TechBuzz
RumShot takes screenshots, but it’s not just a mere screen capture utility. It addition to capturing your screen, it puts beautiful frames and borders around it to make it look fancier.
So, does it involve any complex procedure? No… Not at all, I created all these within a wink of an eye. RumShot won’t replace your everyday screen capture utility because you can snap only fixed sized screenshot and it automatically puts frames around it. RumShot is extremely light; it weighs only around 227Kb. You can download additional RumShot themes from here.
Download RumShot | Download RumShot Themes
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
hailgautam is offline
Old 01-02-2007, 09:28 PM   #2 (permalink)
Tech Geek's Avatar
Default Re: Capture Fancier Screenshots with RumShot
nice one
thanks
Tech Geek is offline
Old 02-02-2007, 07:31 AM   #3 (permalink)
nishant_nms's Avatar
thanx
nishant_nms is offline
