Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 05-12-2006, 10:32 PM   #1 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Arrow ANNOUNCING BETA: Spybot S&D TeaTimer / Scan engine / Vista integration
We are proud to announce new versions of miscellaneous tools are now available for beta testing!
Scanning engine
This update cannot be disabled in the download package below; it is not only used if you install TeaTimer, but by the main Spybot-S&D scanner as well. The methods available to detect malware have been more than doubled, including new ways to generically detect malware mutations.
TeaTimer
Aside from the fix of the graphical glitch so many users have been waiting for , there have been some important changes under the hood, which will reduce the number of change dialogs where the user has to decide.
TeaTimer now automatically allows any changes during the installation of other security software which follow the ASCs guideline of code-signing all files, as well as a much improved scan of the files associated with registry changes.
Vista Security Center
The Windows Security Center included with Windows Vista has a dedicated entry for malware protection software.
Microsoft ships Windows Defender with Vista, however, Spybot-S&D can now easily integrate into the Vista Security Center; which will then monitor if Spybot-S&D is up-to-date and whether the permanent protection (TeaTimer) is running or not.
This update will only show on Vista systems, since previous Windows versions do not offer anti malware integration into WSC.
Download beta versions of above tools here
Source
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 06-12-2006, 08:46 AM   #2 (permalink)
nishant_nms's Avatar
Default Re: ANNOUNCING BETA: Spybot S&D TeaTimer / Scan engine / Vista integration
thanx
nishant_nms is offline
Old 06-12-2006, 09:15 AM   #3 (permalink)
Distinguished Member
anandk's Avatar
it was hi-time spybot version was updated . i think they were waiting for vista release...thanx 4 d update. will check it out.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 06-12-2006, 09:29 AM   #4 (permalink)
thnx for the link..
signature??? :???: Let Me Think About It!!!:-D
paul_007 is offline
Old 06-12-2006, 12:40 PM   #5 (permalink)
-- No Easter Eggs here --
hemant_mathur's Avatar
thanx for the info
E6850 3.0 Ghz, 4gb 667 Mhz RAM, Asus p5n Esli Mobo, Nvidia 8600GT 512mb, 400gb WD HDD, Samsung Syncmaster 920NW, Vista x64
hemant_mathur is offline
Old 17-06-2007, 06:16 PM   #6 (permalink)
anandk's Avatar
final out :
download http://www.safer-networking.org/file...spybotsd15.exe
Microsoft® MVP
anandk is offline
Old 18-06-2007, 10:06 PM   #7 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Thnx anandk
rakeshishere is offline
Old 20-06-2007, 09:57 AM   #8 (permalink)
HELP AND SUPPORT
Hey..Guess.what I was able to install Spybot S&D 1.4 version on Vista with no problems or compatibility issues but it doesn't get recognized in Windows Security Center..
Hope they just release this very fast...Cant wait for it
- by Anorion
- by Niilesh
