Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 03-11-2006, 01:00 PM   #1 (permalink)
Come get Some
DukeNukem's Avatar
Default See this "awe-inspiring" Cooling Solution
source :> http://www.zalman.co.kr/
ZM-WB4 GOLD
1. Zalman’s creative dimple-type processing technology allows lightness in weight and excellent
cooling performance.
2. Pure copper-base material Water Block provides excellent heat transfer, and gold-plated base
prevents corrosion.
3. The light-weight Water Block Cover is made with durable reinforced polycarbonate, and is clear
providing an internal view of coolant flow.
4. The Connection Fittings each incorporate two different diameters to accommodate various types of
hoses and are built together with the Water Block Cover as a single unit utilizing durable reinforced
polycarbonate.
5. Compatible with Intel Pentium 4 (Socket 775/478) and AMD Sempron/AMD64
(Socket AM2/754/939/940) with the use of length-adjustable clips.
hit link on top for more visual action
Computers are like Air Conditoners, thet stop working properly when u open WINDOWS.
DukeNukem is offline
Old 03-11-2006, 02:25 PM   #2 (permalink)
Welcome To The Jungle
sysfilez's Avatar
Default Re: See this "awe-inspiring" Cooling Solution
zalman coolers have always lived upto the mark. gr8 product.
Me n My Canon EOS 350D with EF 50mm f1.8
sysfilez is offline
Old 03-11-2006, 04:08 PM   #3 (permalink)
!! RecuZant By Birth !!
naveen_reloaded's Avatar
__________
Know My Thoughts..
Visit my Blog @ www.Urssiva.com
Visit My Tech Blog @ www.CloudTechnica.com
Last edited by naveen_reloaded; 03-11-2006 at 04:08 PM. Reason: Automerged Doublepost
naveen_reloaded is offline
Old 03-11-2006, 06:36 PM   #4 (permalink)
jamyang312's Avatar
wow,, gr8!!! nice pics too,,,,
zalman coolers r gr8,,,,
think u will never see the devil?
look in the mirror and u will see one!
jamyang312 is offline
Old 03-11-2006, 07:30 PM   #5 (permalink)
-- No Easter Eggs here --
hemant_mathur's Avatar
Awesome
E6850 3.0 Ghz, 4gb 667 Mhz RAM, Asus p5n Esli Mobo, Nvidia 8600GT 512mb, 400gb WD HDD, Samsung Syncmaster 920NW, Vista x64
hemant_mathur is offline
Old 04-11-2006, 08:18 AM   #6 (permalink)
sabret00the's Avatar
really kool
__________
I guess they sell it in India as well. MEDIATECH (INDIA)
C/O SAFEXPRESS PRIVATE LIMITED, S-5, COMPLEX 4/4, CCI GODOWN,
KALAMBOLI, NAVI MUMBAI-410218, INDIA
TEL : +9122-2636-1111 FAX : +9122-2631-2222
http://www.mediatechindia.com zalman@mediatechindia.com
C2D E6600,Asus P5N32 e SLI,1GB 667mhz,Samsung 940BW,Zeb 8600GT,Seagate 250GB sata II,16x Sony(OEM) dvd RW,Zeb Anitibiotic & Platinum 500W,Microsoft desktop pro 700,bluetooth,Logitech MX Revolution
sabret00the is offline
Old 04-11-2006, 10:43 AM   #7 (permalink)
AFK
thewisecrab's Avatar
gr8.....how much is it worth??????
Check out http://thefinal3rd.com, an Indian footie blog. Follow me on http://twitter.com/thewisecrab
Fishdumplings!! Duniya goal hai?
thewisecrab is offline
