Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 27-10-2006, 03:41 PM   #1 (permalink)
a_g = JPKN
s18000rpm's Avatar
Default Intel: Viruses to be a thing of the Past
Intel believes that malacious codes, viruses and other security threats may become a worry of the past. Inte's R&D team is currently working on Trusted Execution Technlogy, previously known as LaGrande. Trusted Execution Technology or TXT will use hardware keys and subsystems to control what part of a computer's resources can be accessed and who or what will be granted or denied access.
Going beyond the NX bit, or the Non-execution bit that is currently enabled inside recent processors from both AMD and Intel, TXT will bring a whole new dimension of security to PCs. TXT will also be able to work in a virtualized environment on systems with Intel's VT technology. Guest operating systems will be able to take advantage of features on a TXT-enabled platform.
Intel will also provide a mechanism called Attestation for TXT, which is a self-monitoring component that ensures that the TXT system was enabled properly. Attestation will provide monitoring, as well as applications running in protected space.
Processors will have split execution spaces called partitions, similar to the concept of partitions on a hard drive. These partitions can be labeled as protected or non-protected. Standard partitions, those that are not protected, are now referred to as "legacy" partitions. A TXT-enabled processor will be able to have both a legacy and protected partition coexist together. Chipsets will also be designed with TXT technology. According to Intel, every part of a TXT-enabled platform will have the technology built in so that every pathway that is traversed by data will be able to offer a high level of security. With TXT, Intel is taking a no-compromise approach to securing data. All components of a system will be protected:
->Processor execution memory
->Processor event handling
->System memory
->Memory and chipset paths
->Storage subsystems
->Human input devices
->Graphics output
To view TXT's list of executions, goto source
Source: http://dailytech.com/article.aspx?newsid=4624
http://www.neowin.net/index.php?act=view&id=35843
__
s18000rpm is offline
Old 27-10-2006, 09:38 PM   #2 (permalink)
Default Re: Intel: Viruses to be a thing of the Past
So every lock there is a key. For every technology there is an exploit.
Raj® Anyone else is not me...!!!
rajas is offline
Old 27-10-2006, 11:34 PM   #3 (permalink)
Alive Again...
satyamy's Avatar
may be it really works
satyamy is offline
Old 28-10-2006, 12:18 AM   #4 (permalink)
sabret00the's Avatar
hmm,amd started doin this ages ago
C2D E6600,Asus P5N32 e SLI,1GB 667mhz,Samsung 940BW,Zeb 8600GT,Seagate 250GB sata II,16x Sony(OEM) dvd RW,Zeb Anitibiotic & Platinum 500W,Microsoft desktop pro 700,bluetooth,Logitech MX Revolution
sabret00the is offline
Old 28-10-2006, 02:29 AM   #5 (permalink)
18 Till I Die............
Viruses? Soon viruses will be history anyways. It's those scary rootkits that are taking over. And seriously I don't believe these kind of technologies will last long cos in the end they cause inconvinience to genuine users.
http://www.bash.org/?258908
mehulved is offline
Old 28-10-2006, 02:37 AM   #6 (permalink)
The Devil's Advocate
iMav's Avatar
some1 tell intel stop the research else mcafee, norton will sue them in europe (thats the only place where such pathetic lawsuits are filed )
http://beingmanan.com
iMav is offline
Old 28-10-2006, 04:50 AM   #7 (permalink)
knight17's Avatar
Correct
"It's not a silly question if you can't answer it." Sophie's World [ http://en.wikipedia.org/wiki/Sophie's_World ]
knight17 is offline
