Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 28-09-2006, 09:39 PM   #1 (permalink)
crookbond's Avatar
Thumbs up Intel 80 Cores CPU.... WOOOOOOOOO
Intel is in the process of developing multi-core processors that are capable of increasing floating-point performance into the spheres that are reached by computing clusters today. The projected performance of Intel's 80-core prototypes at the time it could become available is expected to hit one teraflop. At this point it's also interesting to note the floating point performance of a Pentium 4 processor: A 3 GHz model reaches 0.006 teraflops, which underlines the impressive capabilities of the 80-core prototype. We have to add that floating point performance is more important for scientific applications and number crunching than it is for desktop applications, but it might enable geologists to analyze drill test samples on their way home instead of processing it in expensive server farms.
Source : http://www.tomshardware.com/2006/09/27/idf_fall_2006/
crookbond is offline
Old 30-09-2006, 09:11 PM   #2 (permalink)
-- No Easter Eggs here --
hemant_mathur's Avatar
Default Re: Intel 80 Cores CPU.... WOOOOOOOOO
nice !
E6850 3.0 Ghz, 4gb 667 Mhz RAM, Asus p5n Esli Mobo, Nvidia 8600GT 512mb, 400gb WD HDD, Samsung Syncmaster 920NW, Vista x64
hemant_mathur is offline
Old 30-09-2006, 09:16 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
Intel's gone crazy. Yes it is. And consumers have gone crazier getting wooed.
Now help me, I need to calculate the determinant of a matrix intel.
Intel: Buy our C2D.
Me:
Harsh J
www.harshj.com
QwertyManiac is offline
Old 01-10-2006, 01:39 PM   #4 (permalink)
SE><IE
Posts: n/a
What about AMD what have they got in the stable. any n00z?
Old 01-10-2006, 06:08 PM   #5 (permalink)
The Devil
blackpearl's Avatar
This is simply crazy. Intel is again losing focus. Earlier they were just trying achieve higher and higher clock speed instead of reviewing and rebuilding their CPU architecture. AMD showed how you can make faster CPU with lower clock speeds. Intel realised this only after about 4 years. Now with the coming of multi cores, Intel is again trying to squeeze more and more cores into the die, and do something foolish like all cores communicating through the external FSB.
They should try something innovative.
blackpearl is offline
- by Niilesh
