Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 25-07-2006, 07:52 PM   #1 (permalink)
NEXT BILL GATES
mihirvashist's Avatar
Cool Lcd With Built In Xp
source:engadget.com
If you though that Apple's 20-inch iMac was an impressive all-in-one computer, just wait till you hear about Samsung's new 40-inch 400PXn and 46-inch 460PXn LCD displays, both of which feature embedded versions of Windows XP. Designed for use in commercial applications such as signage, the two monitors sport an updated version of Samsung's MagicNet technology, which allows them to run slideshows or video without the need for an external server; if a server is being used to stream data, it can control up to four of the displays at once, feeding them either separate images or one tiled picture (arrays of 4 x 4 units are possible). Specs-wise, both products are pretty run-of-the-mill: you get a 1,366 x 768 resolution, 8-millisecond response time, 800:1 contrast ratio, and 500cd/m² maximum brightness. Although they're available immediately, Sammy hasn't released any pricing info for these models, but TG Daily points out that the previous, non-XP versions cost $8,950 (460Pn, pictured) and $6,750 (400Pn), respectively -- so we can be sure the upgraded editions won't come cheap.
so who's gonna buy it?
KNOWLEDGE IS POWER!!:-)
mihirvashist is offline
Old 25-07-2006, 08:13 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Lcd With Built In Xp
so can we change the os in it
Pathik is offline
Old 27-07-2006, 03:46 AM   #3 (permalink)
but will they match the Mac quality??
ashnik is offline
Old 27-07-2006, 04:26 PM   #4 (permalink)
NEXT BILL GATES
Question Re: Lcd With Built In Xp
i don't think so!!!!
Old 30-07-2006, 06:38 PM   #5 (permalink)
Brave_Hunt's Avatar
That's so bad.
And well said, E=MC˛ And there's a light!
Brave_Hunt is offline
Old 30-07-2006, 10:05 PM   #6 (permalink)
damnthenet's Avatar
Nope...it's tough
Sony Xperia Neo V - Review and Discussion Thread:
http://www.thinkdigit.com/forum/mobi...ml#post1520514
damnthenet is offline
- by Niilesh
