source:source to this thread is that it is a part of an email received by me from a trusted friend(she won't lie)it was about vista and its features(vector graphics,one care service & all ) i wish i could put the entire mail here but i have already deleted it.
besides, these restriction are to stop piracy not to cause inconvenience to its users,however we are feeling that this is wrong because we are used to piracy.
i just wanted to share all this with you
before any one of you plans to buy VISTA when released read the following restrictions to users:-
AACS Advanced Access Control System
(stops you playing dvds)
AEC Automatic echo cancellation
(stops you listening to music)
AES Advanced Encryption Standard
(without the original keys your movies/games/music wont play)
APO Output Encryption Audio Processing Object
(same as above but failsafe incase first fails)
COPP Certified Output Protection Protocol
(ever use TV out? well not no more this stops it)
DDI device driver interface
(no clue)
DTCP Digital Transmission Content Protection
(no more downloading and watching tv shows on a pc)
LFSR Linear-Feedback Shift Register
(DRM checking on Registration key before anything works)
HDCP High-bandwidth Digital Content Protection
(wanna download something? has to pass a certificate first)
HFS Hardware Functionality Scan
(scans hardware to see if trusted DRM is turned on if not wont play)
ITA Input Trust Authority
(same as above only disables system)
OMAC One-Key Cipher Block Chaining Message Authentication Code
(fancy way or saying DRM is locked in)
OTA Output Trust Authority
(contents need to be auth'd with content providers server before they play)
PAP Protected Audio Path
(wont play mp3 files that are not protected)
POC Protected Output Controller
(same as tv out protection)
PUMA Protected User Mode Audio
(only plays DRM'd bull****)
PVP Protected Video Path
(only plays DRM files with licence)
PVP-OPM Protected Video Path - Output Protection Management
(speaks for itself)
PVP-UAB Protected Video Path - user-accessible bus
(no hardware/software hacks as the protection is in the drivers)
RSA Rivest-Shamir-Adleman
SAP Secure Audio Path
(bye bye unlicenced content)
SCMS Serial Copying Management System
(other words if found with a invalid key it will remove it)
S/PDIF Sony/Philips Digital Interchange Format
SRM System Renewability Messages
UMA User Mode Audio
VAS Virtual Audio Server
VPO Virtual Protected Output
Now you all know the details!!!
so all those who wanted to buy VISTA will still stick to their decision?
plz rate this msg its my first new thread
i don't know what the above abbr. means exactly but searching on net will surely quench your thirst(of knowledge)
