Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 27-05-2006, 10:55 AM   #1 (permalink)
Distinguished Member
anandk's Avatar
Talking norton users...at risk...
"Symantec Corp.'s leading antivirus software, which protects some of the world's largest corporations and U.S. government agencies, suffers from a flaw that lets hackers seize control of computers to steal sensitive data, delete files or implant malicious programs...
...Symantec has boasted its antivirus products are installed on more than 200 million computers...testing showed the problem affects Norton Antivirus Version 10..."
read more at http://www.washingtonpost.com/wp-dyn...052501081.html
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 27-05-2006, 12:44 PM   #2 (permalink)
nagarjun_424's Avatar
Default Re: norton users...at risk...
I was affected by a trojan called Trojan.Nebular and Norton could not repair it or delete it! It started destroying all the files in my PC! It even un installed the Printer Driver! I had to reinstall my whole PC yesterday and now I use McAfee!
nagarjun_424 is offline
Old 27-05-2006, 11:49 PM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
i was affected by adware.cdt
and norton was unable to repair.
than i sifted to mcafee...now i m felling gud.
ravi_9793 is offline
Old 28-05-2006, 08:43 PM   #4 (permalink)
alekh_khanna's Avatar
Thumbs up Re: norton users...at risk...
Use Bitdefender Pro or Nod 32 ... Better than the regular league....
Faster scanning... Excellent detection....smaller updates... Low on resources..
What more do u want ???
HeLp : http://bux.to/?r=alekhkhanna
Zombie:- http://kevan.org/brain.cgi?Alekh%20Khanna
Finally wrote something:- http://alekhkhanna.blogspot.com/
alekh_khanna is offline
Old 30-05-2006, 07:49 PM   #5 (permalink)
The pWnster
Vyasram's Avatar
Used norton, mcafee- heavy on resources . Those two are just hyped up avs
Used Avast,Avg free- low detection
Using Kaspersky- Best so far
Yet to be tested- bitdefender,nod32
Sigs suck
Vyasram is offline
Old 04-06-2006, 02:39 PM   #6 (permalink)
Angry Re: norton users...at risk...
Watch your language. Another such outburst and you will be gone for good.
BY,
S.SUDHAKAR
sudhakar35in is offline
Old 04-06-2006, 02:47 PM   #7 (permalink)
speedyguy's Avatar
watch it sudhakar35in, there r certain rules to follow in this forum...
well im confused now as i just formated my whole system done a fresh install of xp wit norton yesterday....though my norton is very old (2004)....but ive unpdated d definations and all stuff from net....
cheers
No Pain...No Gain
speedyguy is offline
Old 04-06-2006, 03:00 PM   #8 (permalink)
The pWnster
Vyasram's Avatar
sudhakar35in, ur post has been reported and -repped
Sigs suck
Vyasram is offline
Old 10-06-2006, 04:18 PM   #9 (permalink)
I beleive no software is 100% perfect, although they promises to be. I am using Norton 2006 for the past two months an dit has got excellent protection. Couple it with Zone Alarm Pro Firewall and I believe I am quite safe. Also u can keep McaFee or other anti virus es installed (don't run them together) and use them for the ones Norton Can't treat
Techie_Geek is offline
Old 26-06-2006, 12:53 AM   #10 (permalink)
After I uninstalled Norton System Works2005, I am facing a warning at the time of opening of my pc showing some message that some files are missing and to have the files I am instructed to reinstall the Norton System Works 2005, then the computer instructs me ' Press any key to continue'.
But I did find any problem though I did not reinstalled the Norton System Works 2005.
Is there any method to remove the warning ?
ssingha is offline
Old 26-06-2006, 01:28 PM   #11 (permalink)
anandk's Avatar
Originally Posted by ssingha
After I uninstalled Norton System Works2005.....Is there any method to remove the warning ?
search for delete all symantec and norton file/folders; go in safe mopde and do it, if required (i am ASSUMING u don not use any other norton/symantec product). then use a good registry cleaner www.ccleaner.com to clear junk.
inspect ur startup entries also using ccleaner, and remove relevant entries.
it shud help !
Microsoft® MVP
anandk is offline
Old 02-07-2006, 12:44 PM   #12 (permalink)
JGuru's Avatar
Now Norton antivirus is at the receiving end!! Since Norton is the #1 antivirus the
hackers have began new ways to exploit it. Similarly the other aniviruses will get
their taste of the same medicine!! So no anitvirus is safe enough.
JGuru is offline
Old 02-07-2006, 01:32 PM   #13 (permalink)
Hey Does It Also Affect Symantec Antivirus Coporate Version 10 ?
Coz I AM Using It !!
Its Really Good Really low On Resources than the standard Norton Antivirus for Home Users Really Good Detection & Repair
Symantec Antivirus Coporate & Norton Anti Virus Are Both Made by Symantec !!
Kinnan is offline
Old 04-07-2006, 07:40 PM   #14 (permalink)
NEXT BILL GATES
mihirvashist's Avatar
i use AVAST! so i don't have to worry about this,it was detected a trojan when i executed a file ,
it works fine for me.
KNOWLEDGE IS POWER!!:-)
mihirvashist is offline
Old 04-07-2006, 08:40 PM   #15 (permalink)
dIgItaL_BrAt's Avatar
When were they ever.....not at risk???
dIgItaL_BrAt is offline
- by chris
