Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 09-02-2006, 06:48 PM   #1 (permalink)
jamyang312's Avatar
Default Viewsonic announces "1ms" Response Time LCDs
Viewsonic Privately Announces "1ms" Response Time LCDs
Viewsonic's VP930b display has a 16, 8, 3 or 2 millisecond response time depending on which Viewsonic representative you speak to and during which purchasing seasonThe same company that brought you the 2ms response time LCD brings you another astonishing miracle of science and advertising
Just when you thought the LCD market couldn't stoop any lower, Viewsonic manages to do it again. Several blogs are reporting about an internal memo from the company with regard to the upcoming "1ms" response time LCDs to be announced later this year. The document claims that with a combination of OverDrive, Dynamic Structure and Amplified Impulse technologies, this year's new displays from Viewsonic will carry a 1ms gray to gray response time.
Gray to Gray response times are traditionally the average time it takes the LCD crystal to twist from one state to another. Specifically, the Viewsonic 1ms LCD panels use a 6-bit twisted nematic LCD panel; each subpixel on the display is capable of 255 states. Akin to a window shade, the further the liquid crystal twists, the more light passes through the display.
Viewsonic's current displays advertise 2 and 4 millisecond response times on gray to gray (GTG) scales over 256 data points. What the company does not disclose is the actual gray to gray states -- meaning the GTG response time may only represent the twisting of the liquid crystals from the 1st to the 2nd subpixel state, or the 2nd to the 3rd, etc. In essence, Viewsonic's 1ms response time is the measure of the liquid crystal twisting from #FF to #FE.
Viewsonic, like most display companies, does not manufacturer its own LCD panels. Viewsonic's current LCD provider for high response time LCDs, AU Optoelectronics, only manufacturers panels with 12ms and 16ms advertised response times. How Viewsonic manages to bypass the laws of physics to twist liquid crystals faster than the manufacturer by adding a digital signal processor remains to be seen.
source-http://www.dailytech.com/article.aspx?newsid=700
jamyang312 is offline
Old 09-02-2006, 07:38 PM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
hey this is supposed to be in the latest news section
vijay_7287 is offline
- by chris
