Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 22-08-2011, 06:35 PM   #1 (permalink)
Techno Freak
Default 13 Year Old Uses Fibonacci Sequence To Increase Solar Panel Efficiency By 50 Percent
Aidan Dwyer is just 13 years of age, but has been able to use the Fibonacci Sequence to increase the efficiency of solar panels yielding 50 percent more with his new design than a standard flat solar panel.
Aidan had a eureka moment while hiking in the Catskills and was intrigued by the patterns tree branches produce. After a more in-depth look he discovered that the branches of the trees were created using the Fibonacci sequence 0, 1, 1, 2, 3, 5, 8, 13, 21, …**
Aidan explains
“I knew that branches and leaves collected sunlight for photosynthesis, so my next experiments investigated if the Fibonacci pattern helped.” - “The tree design takes up less room than flat-panel arrays and works in spots that don’t have a full southern view. It collects more sunlight in winter. Shade and bad weather like snow don’t hurt it because the panels are not flat. It even looks nicer because it looks like a tree. A design like this may work better in urban areas where space and direct sunlight can be hard to find.”
Aidan now has a provisional U.S. patent for his Fibonacci sequence solar panel stand design and has generated interest from “entities” apparently eager to explore developing and manufacturing his design.
** The Fibonacci sequence is created by added the previous two number together.
Source: 13 Year Old Uses Fibonacci Sequence To Increase Solar Panel Efficiency By 50 Percent | Geeky Gadgets
I say this is One of the best research and Dev area... he must make a Patent and must work On the same stream and Others must help him...
Good thinking Great work!!!!!!!!!!!!!!
suyash_123 is offline   Reply With Quote
Old 22-08-2011, 07:05 PM   #2 (permalink)
Default Re: 13 Year Old Uses Fibonacci Sequence To Increase Solar Panel Efficiency By 50 Perc
genius. did't wait for the apple to hit the ground.
Old 22-08-2011, 07:53 PM   #3 (permalink)
A genius one!!
abhijangda is offline   Reply With Quote
Old 22-08-2011, 10:37 PM   #4 (permalink)
adi007's Avatar
Indeed a genius idea
So here's the problem. Aiden did not actually discover a more efficient way to convert solar energy into power as he claimed and these numerous publications reported.
This is where bad science starts « No One's Listening
But nevertheless great thinking by a 13 year old
doiteasily.com ►easy way(s) to do certain things
Tech Word of the day : ADSL
Aditech Blog ► There is something for everyone
Terminal Command of the day
regtweak.info ► Windows Registry hacks and tricks
adi007 is offline   Reply With Quote
Old 25-08-2011, 11:13 AM   #5 (permalink)
Living to Play
gameranand's Avatar
For 13 years old its a great achievement.
Although he did some mistakes but they are acceptable at his age.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Lost my Mobile. Will be offline for quite some time. :(
gameranand is offline   Reply With Quote
Old 30-08-2011, 07:11 AM   #6 (permalink)
agree!!!
wodeln is offline   Reply With Quote
Old 30-08-2011, 01:15 PM   #7 (permalink)
BMG ftw!!
d6bmg's Avatar
For a 13 year old, great!!
d6bmg is offline   Reply With Quote
Old 30-08-2011, 01:16 PM   #8 (permalink)
This guy is very very smart
13 years I couldnt even solve few Quadratic Equations
My Photography page on- Flickr
Follow me on - Twitter
Old 30-08-2011, 11:30 PM   #9 (permalink)
^^ sorry for the OT. but maybe you will like this: Youngest Android developer - XDA
Old 31-08-2011, 01:17 PM   #10 (permalink)
FUBAR.
KDroid's Avatar
^^ 12 Years Only!! Impressive!
Inactive. For a year.
Twitter
KDroid is offline   Reply With Quote
Old 31-08-2011, 04:10 PM   #11 (permalink)
BMG ftw!!
d6bmg's Avatar
I saw his profile before. Developing & coding android is not a big deal.
Old 31-08-2011, 11:29 PM   #12 (permalink)
God of Mistakes...
Garbage's Avatar
Hacker News | > Scientists and naturalists have discovered the Fibonacci sequence appearin...
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline   Reply With Quote
