Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 28-07-2011, 11:10 PM   #1 (permalink)
Mozilla Rep
sygeek's Avatar
Default Isostick, the USB memory-optical drive
In the old days, you used to have to put something called “optical media” into a “DVD drive” to install software and operating systems. Those days are long over thanks to an odd little USB key called the Isostick.
Although the project doesn’t officially exist – it’s almost funded on Kickstarter – the IsoStick promises to allow you to load any ISO disk image from any computer just as if it were loading it from an optical disk. Why would you want to do this? Well, some computers can’t boot directly from a USB thumbdrive and the IsoStick solves this by masquerading as an optical drive first and a thumb drive second. Almost any PC will boot from an optical disk, which makes the Isostick so useful.
You can write multiple ISOs onto the FAT32 drive and a special selector lets you pick which one to load. This means you could keep multiple install images on one USB drive and install them as needed.
Write the creators:
The isostick is targeted at IT people, computer technicians, and geeks in general that are sick and tired of carrying around lots of discs that always get lost, broken, scratched, or just stop working. Often times you’ll have to update your discs with the latest patches or virus definitions or what-have-you. With isostick it’s a breeze, just drop the new iso on the flash drive and you’re ready to go!
$225 gets you a 32GB stick and some stickers while the cheapest model costs $125 for 8GB. If you’re unsure what you’d do with this, you’re probably not the target market but they’ve had $21,000 in pledges (out of a target of $25,000) so far, so it’s likely this has always been an itch that needed scratching.
Project Page
sygeek is offline   Reply With Quote
Old 28-07-2011, 11:41 PM   #2 (permalink)
Stuck in Time...
Vyom's Avatar
Default Re: Isostick, the USB memory-optical drive
Wow... it IS too good to be true.
I would love to ditch DVD drives in favor of ISO Stick.
But I have a concern. Will this ISO stick be able to boot even if there is no option to boot from a flash drive? Theoritically, since computer would think ISO stick as a Disk Drive, it would be able to do so :S
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is online now   Reply With Quote
Old 28-07-2011, 11:47 PM   #3 (permalink)
Mozilla Rep
sygeek's Avatar
Technically, if the computer recognizes this as an optical drive on the boot-up, it should be able to run fine with the option to boot from a CD/DVD drive. At least that's what this device is based on.
Old 29-07-2011, 12:36 AM   #4 (permalink)
Electronic.
Neuron's Avatar
Well its a usb device.So it can't get detected as anything else.I don't know if its much more than a normal flash drive.We already have utilities that can make usb drives boot from isos.This one has that part hardwired in it already.
I don't always make sense,but when I do,I don't.
Neuron is offline   Reply With Quote
Old 29-07-2011, 12:41 AM   #5 (permalink)
Manchester United <3
Ishu Gupta's Avatar
The only plus point I see is that we can store multiple OSes on a single USB stick. But its a bit expenive.
You can get a 8GB drive for 450 bucks (that's 1 tenth of this ). Then use unetbootin and you get a bootable USB stick. One iso at a time though.
Edit: Damn you Neuron
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
Ishu Gupta is offline   Reply With Quote
Old 29-07-2011, 12:47 AM   #6 (permalink)
Mozilla Rep
sygeek's Avatar
But it certainly doesn't make them ACT as an optical drive.
Old 29-07-2011, 01:14 AM   #7 (permalink)
Electronic.
Neuron's Avatar
There are hardly a few Operating Systems that can't be made to boot from usb.Things might get a bit more easier with this one.Nothing worth 100$ for 8GB.
Old 29-07-2011, 01:16 AM   #8 (permalink)
Mozilla Rep
sygeek's Avatar
Well, I agree to that, but I guess you guys are just missing the entire point of this device. It's not this expensive just for the sake of it.
Old 29-07-2011, 10:34 AM   #9 (permalink)
Ishu Gupta's Avatar
Almost.
Your PC won't detect it as a CD but it still works as a CD would. And almost every computer supports USB booting.
What makes this worth 10 USB drives with the same capacity?
Old 29-07-2011, 01:42 PM   #10 (permalink)
cute.bandar's Avatar
Question: is there something special about the hardware or is it all just software that makes the PC think its dealing with a optical drive and not a USB drive.
btw there already exist software like unetbootin that would allow one to use usb drive for booting
Here is list of windows software that allow adding bootable iso to USB:
* unnetbootin - for linux
* sardu - multiple iso in one
* yumi - multiple iso in one (doesn't have xp option)
* wintoflash - only for windows installation (xp - 7)
personally I have had it with unreliable dvd and dvd players. Now I only use USB sticks to boot and internet to get content.
Computer parts search Engine(for india) : http://goo.gl/Sg8Yv
cute.bandar is offline   Reply With Quote
Old 29-07-2011, 04:49 PM   #11 (permalink)
Mozilla Rep
sygeek's Avatar
Originally Posted by Ishu Gupta View Post
Almost.
Read the context dude, the PC will SEE it both as an CD/DVD and a USB.
btw there already exist software like unetbootin that would allow one to use usb drive as an optical drive.
No, those softwares just write the ISO image to the USB, installs it's bootloader and marks it as bootable.
Due to multiple misconceptions, I've updated the article's context and I'm summing up this device's features:
  1. IsoStick is a USB key that allows you to booting into multiple ISO images.
  2. It acts both as an CD/DVD and an USB, so whatever your hardware supports booting from, it will be 100% compatible with it's BIOS
  3. You can write multiple images into this device just by copy-pasting an ISO image, regardless of their quantity.
  4. You can lock the device as readable so as to mark the operating system persistent/non-persistent with just a simple lock switch on the device.
  5. The isostick is targeted at IT people, computer technicians, and geeks in general that are sick and tired of carrying around lots of discs that always get lost, broken, scratched, or just stop working.
  6. If you're an average user, please don't bother using it, it will be nothing more than a expensive USB to you.
  7. In short, it's a device that acts both as an optical drive and USB while increasing the efficiency by a HUGE extent (and at the same time, it is expensive).
It is not possible for a software like unetbootin (and it's likes) to make a USB, function as the above. If you're not distro hopper like some people, you won't be able to respect it's features (which doesn't include the price).
Old 29-07-2011, 05:10 PM   #12 (permalink)
Ishu Gupta's Avatar
  1. IsoStick is a USB key that allows you to booting into multiple ISO images. Or you can buy 10 USB stick and attach them to a keyring(Get the tiny ones). You get 10x the storage and its geekier.
  2. It acts both as an CD/DVD and an USB, so whatever your hardware supports booting from, it will be 100% compatible with it's BIOS If your BIOS doesn't support USB booting, this won't work AFAIK. Externel DVD drives don't work.
  3. You can write multiple images into this device just by copy-pasting an ISO image, regardless of their quantity. See point 1
  4. You can lock the device as readable so as to mark the operating system persistent/non-persistent with just a simple lock switch on the device. On the hardware level,this IS possible on some USB drives.
  5. The isostick is targeted at IT people, computer technicians, and geeks in general that are sick and tired of carrying around lots of discs that always get lost, broken, scratched, or just stop working.See point 1
  6. If you're an average user, please don't bother using it, it will be nothing more than a expensive USB to you.Its expensive to everyone
It is not possible for a software like unetbootin (and it's likes) to make a USB, function as the above. If you're not distro hopper like some people, you won't be able to respect it's features (which doesn't include the price).I've installed 3 distros and windows in the last month all using the same 4GB USB drive.
This is not worth the money. If it was $20 for the 8GB, I would say its good but at $100 its taking the ****.
Old 29-07-2011, 05:17 PM   #13 (permalink)
Mozilla Rep
sygeek's Avatar
This is not for your everyday picture storage device, yes it is costly, but it certainly can't beat a usual USB feature-wise.
As I said, that's NOT the point of this device.
I don't know how you are so sure. It is certainly not true, try reading the project page and some of the reviews.
Old 29-07-2011, 05:49 PM   #14 (permalink)
Ishu Gupta's Avatar
XBOOT – Multiboot ISO USB Creator (Windows) | USB Pen Drive Linux
YUMI - Multiboot USB Creator (Windows) | USB Pen Drive Linux
iodd2511 This is dead and has been overtaken by someone else.
Isn't the point of this to allow you to boot isos.
Any PC less than 5 year old can boot from USB. Those PCs are worth less than this USB.
And Admins don't need this either. They can simply use PXE.
Where does it explicitly say that "It doesn't need USB boot support"
Only BIOS' that support USB booting but are not able to boot into flash drives need something like this.
Hardware-wise, the Isostick is basically a MicroSD card (non-removable) that’s capable of 12.5MB/sec read (81x and 9.5x in CD/DVD parlance) and 4-6MB/sec write.
12.5MB/sec? That's slow
How about a Normal USB3 drive that can finih installing your distro in 1/10th the time this thing takes?
Old 29-07-2011, 05:54 PM   #15 (permalink)
Mozilla Rep
sygeek's Avatar
Link me a software which has the exact features as stated in the above post, and I'm not talking about alternatives with limited features.
The site's main project page..
A lot more than that, if you read the context.
Read the Project page and come back with valid arguments.
Old 29-07-2011, 05:56 PM   #16 (permalink)
Ishu Gupta's Avatar
Can you quote whatever from that article? So I know specifically what you are talking about.
And thanks for skipping over most of the post.
Old 29-07-2011, 06:02 PM   #17 (permalink)
Mozilla Rep
sygeek's Avatar
You don't want me to spoonfeed you, do you? Please the read the project page carefully, it is stated in BOLD letters.
Probably because they weren't valid arguments and I couldn't care less.
What exactly are you trying to say?
That the features can be easily overcome with the above mentioned softwares, if you care for it features, it isn't true. If are you saying that it's expensive? Well yes it is! Are you saying that 10 USB drives are better than this? Not at all (i'm excluding the price factor here)! Or if you're saying that it's a worthless device, well, then that statement doesn't follow for everyone.
Old 29-07-2011, 06:54 PM   #18 (permalink)
Ishu Gupta's Avatar
If you can see the first screenie, he is copying BT, Ubuntu, Slax. That's 3 ISOs/Distros.
In the second image you can choose the bootloader. It will allow you to choose an ISO when you boot from your USB.
You can also store your data along with the OSes.
Buy a 32GB external USB for 2k/$40. It will be 2x faster with 4x the space and still cost 60% less.
If you want to use ISO inside your OS, use Daemon Tools. It will be even faster.
Only limitation I see is this won't boot if your PC doesn't support USB booting (And I am still don't think that ISOUSB will boot in that case either. Very few BIOS' support USB booting but can't boot into flash drives (In this case normal USB won't work but isousb will work).).
AND I can't see anything that says that it'll boot even without the USB booting capabilty. Either you are missing something or I am.
Old 29-07-2011, 07:01 PM   #19 (permalink)
Electronic.
Neuron's Avatar
Even if it does boot in that case someone having a non-usb booting PC is sure not to have enough fortune to buy an 'isostick'.
Old 29-07-2011, 07:19 PM   #20 (permalink)
Mozilla Rep
sygeek's Avatar
Very well carried out. Yes, you're missing something, these ISO images don't just apply for operating systems, it goes for ANY CD/DVD ISO image. These features are not software-wise but they are built into the hardware, thus even more compatible. You don't have to install tonnes of bloatwares.
Even many windows functions can be replaced by tonnes of other softwares, that doesn't mean you shouldn't use it in the first place.
Let's say a case where you have to use something as a CD/DVD to make it work and you want to customize the contents without re-writing the whole CD/DVD, the USB comes in here too.
What if the other person is a computer administrator who wants to fix someone's sh1thole computer? That's where it comes in, IT IS NOT FOR THE AVERAGE USER.
I'm tired of this, let's move on guys :/
Old 29-07-2011, 07:28 PM   #21 (permalink)
Ishu Gupta's Avatar
These ISO images don't just apply for operating systems, it goes for ANY CD/DVD ISO image.
Really? BTW that software works for ANY iso too.
OK. This software only copies the content of the live CD to the USB drive. ie there is no software installed on the usb drive.
On the other hand, your usb has a firmware that reports the usb as a cd rom. It uses something that mounts those ISO at boot too
Of course if you install multiple ISOs, both of them would need a separate botloader.
OK 1 software is not 'tonnes of bloatware'. AND unetbooting doesn't even needs to be installed. Its a portable exe with no dependencies.
I haven't used XBOOT so can't say about that.
AND BTW your isostick also has a software for configuration.
Who uses the windows Disk defragmentor?
Who uses Windows Defender?
Who uses Windows Disk Cleanup?
Are you even reading my posts?
The edited ISO you need to copy to your isostick can be installed to a normal USB via xboot too.
If you don't need to boot from that edited ISO, you don't even need to waste time copying it to the slow isostick. Just right click on the ISO and mount with daemon tools.
And you were saying I was giving crap, invalid arguments.
Old 29-07-2011, 07:55 PM   #22 (permalink)
Electronic.
Neuron's Avatar
So this is specifically designed for fixing sh1thole computers.I don't find any other use.
Old 29-07-2011, 08:21 PM   #23 (permalink)
xboot isn't the same: it doesn't support ..
NOTE: Windows XP, VISTA ,7 install Disks are not supported.So do not try to add them.
Old 29-07-2011, 08:36 PM   #24 (permalink)
Ishu Gupta's Avatar
This one does.
And
SARDU – Multiboot USB Creator (Windows) | USB Pen Drive Linux
And you don't need these automated softwares. This can be done manually too.
Old 30-07-2011, 07:59 AM   #25 (permalink)
Just a means of selling flash at an expensive price. More profit.
Old 30-07-2011, 09:02 AM   #26 (permalink)
Living to Play
gameranand's Avatar
Whatever this is this is certainly not worth the money. Its just too costly and provide features which are achievable with third party softwares and that too plenty of them so definitely not worth it. Just a marketing and advertising strategy for the company nothing else.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Lost my Mobile. Will be offline for quite some time. :(
gameranand is offline   Reply With Quote
Old 30-07-2011, 09:40 AM   #27 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
The only people who will need it are those with really old PCs which when sold second hand will fetch less than this isostick itself
Apple iPad 2 16GB WiFi
MetalheadGautham is online now   Reply With Quote
Old 30-07-2011, 09:44 AM   #28 (permalink)
$225 for a 32 GB stick is quite high considering it costs only $4 less than a 4th Gen iPod Touch 8 gb
iPod touch $229
Old 30-07-2011, 12:38 PM   #29 (permalink)
Mozilla Rep
sygeek's Avatar
Yes, mostly. Of course this is not worth the money. Worth the features/hardware, yes.
Guys, stop posting about "OHH THIS IZ ZOO COSTLY" "MAN, COSTLY I CANZ NOT AFFORD IT". Of course you can't, I never intended you to buy it straightaway, just as a news about the latest hardwares in the market. So if you can't respect it's features, please stop whining about it's price. It's the same as complaining about Mac/iGadgets outrageous price.
I'm not sure about that, for now, it's not targeted as a company, it's just a project funded by kickstarter. So, I guess it probably goals toward selling enough of these to start and fund their startup. But it's certainly not a advertising strategy.
