Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 23-08-2009, 08:20 AM   #1 (permalink)
Default First pics of AMD "Juniper" DX11 cards surface
[IMG]file:///C:/DOCUME%7E1/PCS/LOCALS%7E1/Temp/moz-screenshot.png[/IMG] Originally Posted by techPowerUp
It turns out, the card is based on AMD's next generation successor to the 40 nm RV740, codenamed "Juniper". The pictures reveal quite a bit about the card, which inherits quite some of its design from the Radeon HD 4770.
The cooler resembles the one found on Radeon HD 4770 (reference), and Radeon HD 3870, albeit opaque black. With the 40 nm GPU running presumably cool, its air vent on the rear panel is reduced in size, and makes way for an arsenal of connectivity that includes two DVI-D connectors, and one each of HDMI and DisplayPort, just as pictured earlier. The PCB is black in color, holds memory on either sides. The card draws its power from one 6-pin PCI-E power connector. Expect a lot more about this as we head toward September 10, when AMD plans to unveil its next-generation GPU technology. Juniper is part of AMD's "Evergreen" family of DirectX 11 compliant GPUs.
http://img196.imageshack.us/img196/8400/118ah.jpg
[IMG]file:///C:/DOCUME%7E1/PCS/LOCALS%7E1/Temp/moz-screenshot-1.png[/IMG]
http://img38.imageshack.us/img38/9324/118bv.jpg
http://img208.imageshack.us/img208/7278/118cy.jpg
source:http://www.techpowerup.com/102018/AM..._Pictured.html
Regards,
coolnikk
coolnikk is offline
Old 26-08-2009, 07:33 AM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: First pics of AMD "Juniper" DX11 cards surface
^^ You should put the image links into img tag
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 26-08-2009, 11:35 AM   #3 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
^^and locals wont work
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
Old 27-08-2009, 05:33 AM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
picture source : http://www.techpowerup.com/102018/AM..._Pictured.html
They looks good but I will wait for a cutom cooler version when they will be released in market
topgear is offline
Old 27-08-2009, 04:14 PM   #5 (permalink)
the card looks good
www.guessthelogo.blogspot.com
harshagarwal is offline
- by gforz
- by Piyush
