Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 22-05-2009, 02:10 PM   #1 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Default HD4850 512MB GDDR5 Performance REVIEWED
http://www.fudzilla.com/content/view/13812/1/1/1/
This card is Gainward HD4850 GLH, but this is the same card as this:
Palit HD4850 512MB GDDR5 Special SONIC @ Rs 9,400/- only
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 22-05-2009, 03:18 PM   #2 (permalink)
toofan's Avatar
Default Re: HD4850 512MN GDDR5 Performance REVIEWEDhttp://www.fudzilla.com/content/view/13812
Best Card in mid range.
Check my work at:
http://www.flickr.com/photos/vimaljoshi
toofan is offline
Old 22-05-2009, 03:58 PM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
nope. look at HD4770. It is pawning HD4850 in every benchmark here and also takes lot less power
desiibond is offline
Old 22-05-2009, 08:23 PM   #4 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
dude, we're talking about the HD4850 512MB GDDR5 from Palit, which has a custom cooler and effectively replaces the HD4870 512MB GDDR5 at a much lower price and with just 50MHz slower core!
About me:
Old 22-05-2009, 08:25 PM   #5 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^Palit or Gainward.
okay. in that case, it looks good and is a bit faster than HD4770.
Waiting to see what Palit does to HD4770. Surprised why they haven't come up any HD4770 card
Old 23-05-2009, 06:10 AM   #6 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: HD4850 512MN GDDR5 Performance REVIEWED (fudzilla)
Old wine in new bottle
BTW, it's very strange that palit still has not released a card based on HD4770
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 23-05-2009, 09:48 AM   #7 (permalink)
dOm1naTOr's Avatar
Then how can they call it still a 4850? Almost same specs as 4870.
But if 4870 was at 10k, then it wud be lot better, as it cud still OC from its stock, while thie 4850 OC is running at its limit to match up with 4870 clocks.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 23-05-2009, 10:23 AM   #8 (permalink)
damnbadman666
damngoodman999's Avatar
Palit HD 4870 1GB for 12K .. thats very good deal ..
GTX 295 for 24K
damngoodman999 is offline
Old 23-05-2009, 05:31 PM   #9 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
er no.
HD4870 and HD4850 have the SAME GRAPHICS CORE, but with different memories. That's the difference.
And the other difference is the GPU Voltage, HD4850's is lesser than HD4870. That's y this HD4850 512MB GDDR5 has a TDP 10W higher than a normal HD4850 whereas HD4870 has a TDP of about 47W above a normal HD4850.
And FYI, this card is way faster than HD4770.
About me:
Old 23-05-2009, 06:31 PM   #10 (permalink)
dOm1naTOr's Avatar
thats what i said, with the lower core voltage, its runnijg at its limit with an OCED GPU. While 4870 seems to take that clocks easily with higher GPU voltage, and can easily OC further.
nyway, it shud be gr8 buy for 9k
G3: XPS M1530 |
FZ 16.
Old 24-05-2009, 11:06 AM   #11 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
for 9.4k, this card is unbeatable, it beats any GTS 250 and OTHER HD4850 out there. Dude, this card also pawns the GTX260 1k higher cost due to it's PowerConsumption and Price/performance ratio.
Yup, but the HD4870 cud hardly be OCed, I mean it was jhingalala if the core ever hit 850MHz, in most cases, 780Mhz or 800MHz was like the highest.
About me:
Old 25-05-2009, 04:00 AM   #12 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
9.4K ? Where ?
Does it fare well in 1080p gaming ?
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 25-05-2009, 10:43 AM   #13 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
^^It does, except in some games like Far Cry 2 and Crysis.
At 1080p, it can give max out w any game upto 2xAA(4xAA for some). That's good enuf for a 9.4k card I think.
About me:
Old 27-05-2009, 10:53 PM   #14 (permalink)
IronMan; Ready to Roll...
IronManForever's Avatar
^ Add to it that at native resolution, one might be able to adjust w/o AA.
I think 4770 is able to handle plain non AA 1080p gaming. God this is getting better!
Aluminum MacBook 2.0GHz Collector's Edition
Windows Box: 2.26G P4, 1GiB RAM, 320GB SATA + 80GB PATA HDD, Nvidia FX5200
AOC Fovi F22
iPod Touch 16GiB, HTC Gene, Moto W230, Sansa Express
IronManForever is offline
Old 28-05-2009, 09:59 AM   #15 (permalink)
The Smaller Bang
Are you sure ? I *may* just get a Samsung 22" 1080p Screen if I am not buying a laptop.
Anyway, I think they should instead just release HD4870 CHEAPER. I mean, once this thing is overclocked, it BECOMES a HD4870.
As for HD4770 pwning HD4850 in benchmarks, may I ask since when ?
The only place where 4770 scores is power consumption.
Old 28-05-2009, 10:23 AM   #16 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
It does, but after a bare OC.
About me:
Old 28-05-2009, 10:55 AM   #17 (permalink)
Bond, Desi Bond!
desiibond's Avatar
I don't think so. for some games, it can handle but if you want to play Crysis, COH, COD lastest games, HD4770 is not the one for FullHD
Old 28-05-2009, 10:59 AM   #18 (permalink)
The Smaller Bang
State the stock and OC'ed values.
And at what price does the HD4770 come minimum, and at what price does the HD4850 come minimum ?
Which performs better, the HD4850 or the HD4770, when OC'ed to their maximum potentials ?
You should consider these facts and state them before making any comments on one thing pwning another.
Thanks for the information. I hope you are refering to your 7750BE and not Athlon 3000+ in this benchmark.
How does Crysis do @ 1080p WITHOUT AA on your rig ?
Old 28-05-2009, 11:14 AM   #19 (permalink)
Bond, Desi Bond!
desiibond's Avatar
my display max reso is 1440x900. And with AA, crysis at high settings gives 32+ fps. Haven't tested with 0xAA. should give 5-7fps more. And don't even think about 1080P gaming for Crysis with this card.
http://www.guru3d.com/article/ati-ra...4770-review/14
gives 13fps and 6fps with 2xAA.
Old 28-05-2009, 11:45 AM   #20 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
HD4770 OC
Core - 850MHz(gos to 970MHz actually)
Memory - 1000MHz(goes to 1150MHz actually)
This setting beats the HD4850 by more than 7% and matches or beats the GTS250.
And HD4850 can be OCed:
Core - 700MHz(from 625MHz)
Memory - 1100MHz(varies, max 1150MHz)
But at this setting, the card JUST would beat an OCed HD4770.
About me:
Old 29-05-2009, 10:29 AM   #21 (permalink)
The Smaller Bang
HD4770 OC
Hmm.... a GTS250 is a 9800GTX+ right ? But I guess that too overclocks a lot.
Old 29-05-2009, 11:06 AM   #22 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
^^Not much, core goes up to 800MHz(but very high and dangerous settings really) and memory depends on manufacturer, shader too goes by 100MHz.
About me:
Old 29-05-2009, 11:11 AM   #23 (permalink)
The Smaller Bang
guess thats because of its speed. its already as good as overclocked leaving very little room for more.
Where did you find benchmarks of HD4770 OCmax GTS250 OCmax ?
Old 29-05-2009, 12:23 PM   #24 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
^^HD 4770 OC benchmarks(850c/1000m)
http://en.expreview.com/2009/05/06/r...n-hd-4770.html
About me:
Old 29-05-2009, 01:51 PM   #25 (permalink)
Hanging, since 2004..
tarey_g's Avatar
Ahh this is what i was searching for, a special sonic benchmark. thx @ comp@ddict
Windows 8 ? :lol:
I have a better OS installed, people call it Windows7 8-)
tarey_g is online now
Old 29-05-2009, 03:16 PM   #26 (permalink)
Bond, Desi Bond!
desiibond's Avatar
HD4850 is seriously sandwiched by HD4770 and HD4870.
HD4770, though it little bit slower than HD4770 is enough for gaming till 1680x1050 and anything above, GTX260/HD4870 is a must as I think even a HD4850 stutters at fullHD in many games if you turn on eye candy to maximum.
I would suggest either HD4770 or HD4870/GTX260
Old 29-05-2009, 03:17 PM   #27 (permalink)
Bond, Desi Bond!
desiibond's Avatar
- by gforz
- by Piyush
