Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 28-03-2009, 03:26 PM   #1 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Default HD4890 - The WORLD's first 1GHz GPU!!!!!!!!!
It has surfaced on the forums of Chinese tech community PCInLife, that the RV790 rather effortlessly reached the 1 GHz mark, the slider-limit of Catalyst Control Center, sparking off fresh rumors that AMD partners may be creating a fresh niche of highly-overclocked cards shortly after Radeon HD 4890 comes to be. The overclocker reached speeds of 1 GHz (core) and 1125 MHz (4.50 GHz effective, memory). At the said speeds, the card was put through 3DMark Vantage with its eXtreme settings. It churned-out a score of X5480, which puts its performance somewhere between those of the GeForce GTX 280 and GeForce GTX 285. It should also be taken into account that the drivers RV790 users the world over have been using, are preliminary beta drivers. AMD plans to release Catalyst 9.4 with the release of Radeon HD 4890, which just may impact positively on the performance of the product.
Factory-overclocked cards based on ATI Radeon have since now been a formality. Even cards with the iconic HIS IceQ TurboX branding, haven't been known to have high (~15~20%) increase in clock speeds. With this feat surfacing, it has been established that the RV790 holds the capability to reach some very high clock speeds. On course to the 1 GHz mark, the overclocker at PCInLife comfortably reached 925/1025 MHz (X5021) and 950/1075 MHz (X5202). It sounds plausible that these speeds could be the speeds factory-overclocked cards come at, with a branding system similar to what NVIDIA uses: a tier-1 (light overclock), tier-2 (moderate overclock), tier-3 (high overclock), and tier-4 (extreme overclock). At any rate, this is turning out to be an exciting fortnight for the high-end GPU industry.
http://www.techpowerup.com/89046/RV7...he_Making.html
http://pleaseguide.me/
comp@ddict is online now
Old 28-03-2009, 04:59 PM   #2 (permalink)
damnbadman666
damngoodman999's Avatar
Default Re: HD4890 - The WORLD's first 1GHz GPU!!!!!!!!!
Oh , just now they launched GTX295 oh no again Nvidia on backdoors
Ati RocKz
AMD Phenom 2 940 @ 3.4Ghz [Hyper 212+] MA790GP-UD4H OCZ DDR2 2x2GB Asus GTX 560ti 1TB SATA2 LG 20" LED Razer DA mice RED HOT cabby
damngoodman999 is offline
Old 28-03-2009, 06:39 PM   #3 (permalink)
Now hope that we may see a price war again..
Maxfx is offline
Old 28-03-2009, 09:26 PM   #4 (permalink)
Lets Do It!
amrawtanshx's Avatar
Ati RocKz
But the poster says it's preformance lies between GTx280 and GTX 295.It isn't above GTX 295.
Still good news for gamers as we will see some stiff competition.(Provided these ATi cards find proper drivers )
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
amrawtanshx is offline
Old 28-03-2009, 10:26 PM   #5 (permalink)
Right man in wrong place!
cyborg47's Avatar
ati always had problem with their drivers...the graphic cards did so much well, but their drivers were too bad to utilise the card's power..
Quad Core Q9300, Gigabyte EP45usb3 mobo, Zotac GTX 460 1024MB, 3x2 GB ddr3 memory, cooler master extreme 600W.
...They call me Prophet... - C2
cyborg47 is offline
Old 28-03-2009, 10:40 PM   #6 (permalink)
damnbadman666
ya , but prices are low when compared to GTX 295 for 10% extra performance always Nvidia prices are higher
Old 28-03-2009, 10:47 PM   #7 (permalink)
Lets Do It!
Ya, But considering the driver and game support Nvidia always has the edge over Ati cards.
These two factors undermine Ati cards true potential.
Old 29-03-2009, 12:20 PM   #8 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
It's between GTX280 and GTX285 to be frank.
Old 29-03-2009, 06:55 PM   #9 (permalink)
4T7
4T7's Avatar
4890 x2 = bye bye gtx 295
4T7 is offline
Old 29-03-2009, 08:09 PM   #10 (permalink)
dOm1naTOr's Avatar
very true.
but wat bout micro-stuttering?
with 4870X2 micro-stuttering was minimized but still its a drawback for multi gpu setups.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 30-03-2009, 08:35 AM   #11 (permalink)
4T7
4T7's Avatar
^Well it's something neither Nvidia nor ATI has a proper solution for thus far
4T7 is offline
Old 30-03-2009, 08:26 PM   #12 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Here's more:-
Radeon HD4890 overclocks to 1GHz+
AMD’s RV790 will probably be remembered as the first GPU that will easily overclock to over 1GHz core clock.
Some partners will ship overclocked cards but 900+ MHz should be the fastest clock out of the box which with some little help of the overdrive tool, you might get the chance to go over the magical 1000MHz barrier.
With water-cooling, we might be getting over 1000MHz easier, but we are not sure if the high clock should be enough to beat GTX 275. Nvidia’s partners will of course overclock their GTX 275 cards and again give AMD a run for its money.
Nvidia’s 1000MHz+ clock will have to wait for 40nm we reckon.
http://www.fudzilla.com/index.php?op...12887&Itemid=1
There won't be any HD4890 X2, sources confirm.
Old 31-03-2009, 06:08 AM   #13 (permalink)
Fast 'N' Furious
topgear's Avatar
What's the temp with 1Ghz clock speed ?
I remember those days when HD 4850 & HD 4870 cards easily reaches upto 85-90C with stock cooling & probably for the low stock fan spped. Then 3rd party maufacturers released their cards with custom cooling solutions & the heating issue gone away.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 31-03-2009, 07:54 PM   #14 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
It runs stable with reference fan set to 100% with 1GHz Core speed and 4500MHz Memory Speed.
So temps aren't exceeding 89C most probably.
But with cooling such as VAPOR-X or Dual SONIC, we might see higher clocks but less than 70C temps.
Old 01-04-2009, 01:49 AM   #15 (permalink)
Banned to Spam
Krazy Bluez's Avatar
Location: Look below...not under pants dumbo...use a GPS
How much will I have to pay for this ?
My DeviantART page now exists !!!
Krazy-Bluez.deviantart.com
Twitter: http://twitter.com/KrazyBluez
Krazy Bluez is offline
Old 01-04-2009, 08:47 PM   #16 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
249$, 18k about or tad more.
Guys update, GTX260 now costs Rs. 14,500.
Added it in price list.
