AMD is on course of releasing the industry's first GPU built on the 40nm silicon process: the RV740. Its specifications make it a cheap yet powerful GPU for the segment it is about to cater to. With the earliest pointers hinting at 640 stream processors and a 128-bit wide GDDR5 memory interface. The GPU also marks the industry's first mainstream implementation of the GDDR5 standard.
Fresh details emerging out of the inspection of the driver information files of ATI Catalyst version 9.1, as German website ATI Forum finds out, hints at the possibility of the RV740 being implemented in two SKUs: the Radeon HD 4730 and Radeon HD 4750. While in the driver file, the device string lists with "RV630", it can be seen throughout the file that several strings are assigned to the same RV630, and is merely a means to identifying a whole class or generation of graphics processors to the driver. Additionally, the string bears the device ID of the RV670, again, that's not relevant. The strings are what matter. The RV740 is not very far away from large scale production. It should become a reality by the upcoming CeBIT event, in March. From the view of being a mere postulation, RV740 being the GPU that goes into making the new SKUs, does end up sounding plausible. When released, these cards are intended to further strengthen AMD's market position in the sub-US $150 market.
