Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 16-01-2009, 08:42 AM   #1 (permalink)
sonicspeed's Avatar
Default sapphire hd4670 gddr4
Sapphire has gone the same way with HD4670 & releases it in GDDR4. The final specs are:
  • 512MB og GDDR4 memory.
  • 128-bit memory interface.
  • 320 shader processors.
  • 750MHZ of Core Clock.
  • 2200 MHZ of GDDR4 memory(200 MHZ more than GDDR3 version).
  • Native CrossfireX support.
  • Direct X 10.1 support.
http://www.techtrance.net/2009/01/pc...dr4-to-hd4670/
sonicspeed is offline
Old 16-01-2009, 09:19 AM   #2 (permalink)
S.I.P.
JojoTheDragon's Avatar
Default Re: sapphire hd4670 gddr4
Whats the price?
Steam: jojothedragon
TDF Steam Group : http://tinyurl.com/3cffox8
Get 2GB of free cloud space : http://db.tt/OJKPcZnY
JojoTheDragon is offline
Old 16-01-2009, 12:08 PM   #3 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
^+1
Username Changed - BlackBerry7100g To BBThumbHealer !
BBThumbHealer is offline
Old 16-01-2009, 03:15 PM   #4 (permalink)
BSD init pwns System V
hellknight's Avatar
Damn.. My friend just bought 4670 with GDDR3 only 3 days ago.. wonder how much the performance difference will be!!
My blog :- www.openenclave.wordpress.com
hellknight is offline
Old 16-01-2009, 05:52 PM   #5 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Not much actually. But power consuption would increase.
I wish somebody releases something REAL, like a DDR3 version.
Such products actually make sense.
AMD said they added DDR3 support in RV710 and RV730 because they hoped that companies could release DDR3 versions, which, compared to GDDR3 are much cheaper and consume less power but only slightly slower.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 16-01-2009, 10:07 PM   #6 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Originally Posted by jojothedragon View Post
Whats the price?
Did u read the whole news? Check the link given above & see for urself.
Well i thought DDR4 runs low on power consumption because of lower voltage for DDR4. Performance won't be a drastic but r u sure about the power consumption?
Last edited by keith_j_snyder2; 17-01-2009 at 04:35 AM. Reason: Automerged Doublepost
keith_j_snyder2 is offline
Old 16-01-2009, 10:53 PM   #7 (permalink)
The Smaller Bang
^^Its GDDR4 not DDR4.
Anyway, I am not sure about power consumption but I think DDR3 on HD4670 is a waste. Its supposed to be a low wattage card and HD4650 with DDR2 and lower consumption seems much much better.
Old 17-01-2009, 11:24 AM   #8 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
But i's a waste!!!
I mean b'cuz of the 128bit mem interface, DDR2 HD4650 and DDR3 HD4670 hav barely any difference in performance, it wud be more fruitful if a DDR4 HD4830 came out for the price of an HD4850.
http://pleaseguide.me/
comp@ddict is online now
Old 20-01-2009, 12:29 AM   #9 (permalink)
Rising ApocalypsE
well that would be more waste because the 4850 would still outperform it & no one will buy it even if it consumes less power.
This is a perfect product for a decent card. I mean company can always perform experiments with the non-moving item & this is a good example of it.
Old 20-01-2009, 02:55 PM   #10 (permalink)
A LOTR fan
x3060's Avatar
i just bought 4670..dd3 though...had a plan to go for 9500gt, decided against it at the last minute.
i hope it gives good performance ..paid 5.5k (tax included) palit.
that was max budget for me.
How many kilometers are there from washington Dc to Miami beach?????....
unban praka123!!!....
x3060 is offline
Old 20-01-2009, 09:28 PM   #11 (permalink)
Rising ApocalypsE
Don't worry dude, ur card is equivalent to 9600GSO or sometimes 9600GT. This is way better than 9500GT!
Old 21-01-2009, 11:06 AM   #12 (permalink)
A LOTR fan
x3060's Avatar
i never had a budget to go for 9600gt...i was planning to wait and accumulate 10k and buy 4850..but that will take long time.and expenses are on high side too. so i thought,better to spend now than wait and not even getting to buy even this.
x3060 is offline
HD4850 in GDDR4 sonicspeed Technology News 2 10-11-2008 07:17 AM
AMD's New low end Graphic card HD4670 yesh1683 Gamerz 6 17-09-2008 03:14 PM
ATI releases first GDDR4 memory graphics card crookbond Technology News 1 23-08-2006 07:57 PM
