Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 19-12-2008, 09:02 PM   #1 (permalink)
ionicsachin's Avatar
Default VirtualBox 2.1.0
This is awsome, 3d acceleration from host machine, and lots of new features
Change Log:-
This version is a major update. The following major new features were added:
* Support for hardware virtualization (VT-x and AMD-V) on Mac OS X hosts
* Support for 64-bit guests on 32-bit host operating systems (experimental; see user manual, chapter 1.6, 64-bit guests, page 16)
* Added support for Intel Nehalem virtualization enhancements (EPT and VPID; see user manual, chapter 1.2, Software vs. hardware virtualization (VT-x and AMD-V), page 10))
* Experimental 3D acceleration via OpenGL (see user manual, chapter 4.8, Hardware 3D acceleration (OpenGL), page 66)
* Experimental LsiLogic and BusLogic SCSI controllers (see user manual, chapter 5.1, Hard disk controllers: IDE, SATA (AHCI), SCSI, page 70)
* Full VMDK/VHD support including snapshots (see user manual, chapter 5.2, Disk image files (VDI, VMDK, VHD), page 72)
* New NAT engine with significantly better performance, reliability and ICMP echo (ping) support (bugs #1046, #2438, #2223, #1247)
* New Host Interface Networking implementations for Windows and Linux hosts with easier setup (replaces TUN/TAP on Linux and manual bridging on Windows)
In addition, the following items were fixed and/or added:
* VMM: significant performance improvements for VT-x (real mode execution)
* VMM: support for hardware breakpoints (VT-x and AMD-V only; bug #477)
* VMM: VGA performance improvements for VT-x and AMD-V
* VMM: Solaris and OpenSolaris guest performance improvements for AMD-V (Barcelona family CPUs only)
* VMM: fixed guru meditation while running the Dr. Web virus scanner (software virtualization only; bug #1439)
* VMM: deactivate VT-x and AMD-V when the host machine goes into suspend mode; reactivate when the host machine resumes (Windows, Mac OS X & Linux hosts; bug #1660)
* VMM: fixed guest hangs when restoring VT-x or AMD-V saved states/snapshots
* VMM: fixed guru meditation when executing a one byte debug instruction (VT-x only; bug #2617)
* VMM: fixed guru meditation for PAE guests on non-PAE hosts (VT-x)
* VMM: disallow mixing of software and hardware virtualization execution in general (bug #2404)
* VMM: fixed black screen when booting OS/2 1.x (AMD-V only)
* GUI: pause running VMs when the host machine goes into suspend mode (Windows & Mac OS X hosts)
* GUI: resume previously paused VMs when the host machine resumes after suspend (Windows & Mac OS X hosts)
* GUI: save the state of running or paused VMs when the host machine’s battery reaches critical level (Windows hosts)
* GUI: properly restore the position of the selector window when running on the compiz window manager
* GUI: properly restore the VM in seamless mode (2.0 regression)
* GUI: warn user about non optimal memory settings
* GUI: structure operating system list according to family and version for improved usability
* GUI: predefined settings for QNX guests
* IDE: improved ATAPI passthrough support
* Networking: added support for up to 8 Ethernet adapters per VM
* Networking: fixed issue where a VM could lose connectivity after a reboot
* iSCSI: allow snapshot/diff creation using local VDI file
* iSCSI: improved interoperability with iSCSI targets
* Graphics: fixed handling of a guest video memory which is not a power of two (bug #2724)
* VBoxManage: fixed bug which prevented setting up the serial port for direct device access.
* VBoxManage: added support for VMDK and VHD image creation
* VBoxManage: added support for image conversion (VDI/VMDK/VHD/RAW)
* Solaris hosts: added IPv6 support between host and guest when using host interface networking
* Mac OS X hosts: added ACPI host power status reporting
* API: redesigned storage model with better generalization
* API: allow attaching a hard disk to more than one VM at a time
* API: added methods to return network configuration information of the host system
* Shared Folders: performance and stability fixes for Windows guests (Microsoft Office Applications)
My first song
http://rapidshare.com/files/128849730/Sachin_-_In_My_Dreams.mp3
http://cid-e2d4f861e716a7fe.skydrive.live.com/self.aspx/.Public/Sachin%20-%20In%20My%20Dreams.mp3
ionicsachin is offline
Old 19-12-2008, 09:25 PM   #2 (permalink)
IronMan; Ready to Roll...
IronManForever's Avatar
Default Re: VirtualBox 2.1.0
* Support for 64-bit guests on 32-bit host operating systems.
This looks intresting... Though I doubt performance at that level of emulation/virtualisation; especially as my PC doesn't support any virtualisation technology.
Aluminum MacBook 2.0GHz Collector's Edition
Windows Box: 2.26G P4, 1GiB RAM, 320GB SATA + 80GB PATA HDD, Nvidia FX5200
AOC Fovi F22
iPod Touch 16GiB, HTC Gene, Moto W230, Sansa Express
IronManForever is offline
Old 19-12-2008, 11:02 PM   #3 (permalink)
TheSaint
NucleusKore's Avatar
Oh yes indeed^
very interesting, especially for me. I can do away with the dedicated 64 bit partition if this works well.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 19-12-2008, 11:11 PM   #4 (permalink)
"Experimental 3D acceleration via OpenGL"
Does this mean we can use the graphic adapter of host machine??
My first song
Old 20-12-2008, 12:03 AM   #5 (permalink)
^^that means you can run 3d apps, atleast most of them if you have good preocessor
Faun is online now
Old 20-12-2008, 12:41 AM   #6 (permalink)
but processor doesnt use OpenGL, its used by Graphic Card
My first song
Old 20-12-2008, 01:19 AM   #7 (permalink)
I'd speculate that the latest openGL has a feature that allows the use of Graphics Acceleration inside a virtual environment, similar to the DirectX10 implementation which has provision for hardware acceleration of 2d-3d processing inside a virtual machine in other propietary virtualisation tools; if the hardware is compliant to DX10, that is.
I don't know much about that, though..
AOC Fovi F22
Creating an internet connection in VirtualBox Cool Joe Software Q&A 8 20-12-2008 09:48 AM
Major Upgrade: Sun's VirtualBox 2.0 Released CadCrazy Technology News 15 10-09-2008 05:24 AM
Running Fedora as Live CD in VirtualBox guhanath Open Source 1 13-08-2007 11:42 PM
VMware or Virtualbox or Qemu or Microsoft Virtual PC... which supports beryl vish786 Open Source 12 20-06-2007 06:52 PM
