Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 16-12-2008, 11:58 AM   #1 (permalink)
kumarmohit's Avatar
Default MTNL launches CDMA Data Card - Unltd Plan @ 300 + taxes
More info here
http://mtnldelhi.in/cdma_151208.htm
kumarmohit is offline
Old 16-12-2008, 12:38 PM   #2 (permalink)
Default Re: MTNL launches CDMA Data Card - Unltd Plan @ 300 + taxes
Very late.
Can the sim be used in a phone as well ? Voice calls allowed or not?
ThinkFree is offline
Old 16-12-2008, 01:48 PM   #3 (permalink)
kumarmohit's Avatar
I do not think so!
Old 18-12-2008, 10:48 AM   #4 (permalink)
aditya_v's Avatar
Can anyone comment on the connectivity in Dwarka?
aditya_v is offline
Old 18-12-2008, 03:02 PM   #5 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
I just called up customer care in Mumbai and that guy told me that its available in Mumbai too at the same charges as in Delhi.
I am thinking of getting it. Can somebody please brief me about the feedback such as connectivity, speeds, etc.
गीक होना माँगता
victor_rambo is offline
Old 18-12-2008, 03:51 PM   #6 (permalink)
^^Why aren't you going for MTNL GPRS? In Delhi, it's Rs.350pm+Taxes for unlimited use and u will get better speed on GSM network than CDMA.
Old 18-12-2008, 04:09 PM   #7 (permalink)
kumarmohit's Avatar
If money and time are not an issue, you should wait for MTNL's 3G services.
Old 18-12-2008, 04:15 PM   #8 (permalink)
हॉर्न ओके प्लीज़
Thanks. I will inquire about that too with the CC. BTW I will have to purchase a Dolphin or Trump SIM card naa inaddition to my exisitng vodaphone cards?
Actually, both are issues, but more of money. You see, the markets are not that good so one has to be careful about liquid money!
गीक होना माँगता
Old 18-12-2008, 04:22 PM   #9 (permalink)
kumarmohit's Avatar
Hmm in that case, this is a data card, so you would not have to worry about cell phone battery either, only laptop battery.
Old 18-12-2008, 04:59 PM   #10 (permalink)
हॉर्न ओके प्लीज़
Great, so u mean that I won't need any dolphin or trump connection? Thanks Mohit.
गीक होना माँगता
Old 18-12-2008, 09:42 PM   #11 (permalink)
kumarmohit's Avatar
With this thing the thread is running about, Nope not a separate sim card. Keep in mind that the modem does cost 2500 rs.
Old 18-12-2008, 09:55 PM   #12 (permalink)
हॉर्न ओके प्लीज़
Thanks.
I don't mind that investment on 2500 as I will cover it within an yr! I am more attracted because I will be able to use it mobile.
Vodaphone GPRS/EDGE costs a bomb.
गीक होना माँगता
Old 19-12-2008, 10:57 AM   #13 (permalink)
Pat
Member of Apple Family
Pat's Avatar
^^ Idea GPRS/Edge plans are quite cheap though..I would recommend you go for Idea NetSetter. Their data card costs the same I guess (approx 2.5k) and data plans are quite reasonably priced. Obviously not as cheap as MTNLs plans but you can definitely expect better speeds!
Pat is offline
Old 19-12-2008, 12:28 PM   #14 (permalink)
I did it all for d n00ki3
sibot's Avatar
Correct me if I'm wrong, but isn't the reception of MTNL very unreliable? What speeds are we looking at from MTNL Data Card?
Intel Core2Duo E4400 - 2Ghz | Asus P5B-MX Motherboard | 2 GB DDR2 RAM, 410 GB HDD | 8500 Nvidia Geforce XFX | Creative Audigy 2 ZS | iCool 480W | DVD-RW(Sata)
www.compmart.in
sibot is offline
Old 19-12-2008, 01:37 PM   #15 (permalink)
Krazy_About_Technology's Avatar
I too will recommend IDEA netsetter over this one. Although data plan is a bit expensive for unlimited usage, its quoted speed is 246 Kbps and in real world performance, it gives around 128-200 kbps, depending upon Signal Strength, network load etc. In day time, between 12:00PM to 4:00PM and in the night after 12:30 or so, i get around 160-200kbps. Note that i am telling about the speed i get by using my phone. With USB device, you can expect beter results.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
Krazy_About_Technology is offline
Old 19-12-2008, 03:22 PM   #16 (permalink)
How do you expect it to work without any sim? Tata and Reliance data cards have removable sims, don't know about MTNL, But no phone/data card can work without any sim.
Yes
Yes, Idea GPRS is better than MTNL. On phone you can get unlimited usage plan for Rs.500+taxes per month(in Delhi)
Old 20-12-2008, 01:52 AM   #17 (permalink)
aditya_v's Avatar
IDEA netsetter with EDGE seems amazing to me right now...
aditya_v is offline
Old 22-12-2008, 05:11 PM   #18 (permalink)
sibot's Avatar
I received a message from Idea regarding the same, use your phone with your laptop and access unlimited internet for Rs.500/-, is it the same one that you're using? Require any special features in the phone for this?
www.compmart.in
sibot is offline
Old 22-12-2008, 05:44 PM   #19 (permalink)
Pat
Pat's Avatar
499 plus taxes.
You need GPRS/Edge enabled phone or you can go for data-card from Idea (costs 2.5k)
Pat is offline
Old 23-12-2008, 10:20 PM   #20 (permalink)
sibot's Avatar
499 plus taxes.
I have a D750i, which has GPRS. Would I be able to connect the phone with my laptop and go online via my laptop? Sorry for asking so many questions, I'm noob at this. Thanks!
www.compmart.in
sibot is offline
Old 24-12-2008, 12:15 PM   #21 (permalink)
^^Yes you can use that, but speed will be limited to 50kbps(kilo bits per second, max)
Old 24-12-2008, 02:00 PM   #22 (permalink)
Can ports be forwarded in Idea Netsetter ? Also is it a static ip like in Bsnl's EVDO ?
I'll be mainly using it for browsing & downloading through bittorrent & rapidshare.
snubbed is offline
probs with 749 NU plan from mtnl SunnyChahal Chit-Chat 2 04-12-2007 10:36 PM
Anyone having fixed IP address in MTNL 256 unlimited plan in Delhi? gaurav_indian Chit-Chat 34 04-08-2007 12:15 AM
Best MTNL triband plan? fortebuster Networking 15 25-05-2007 09:19 PM
