Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 09-12-2008, 01:15 PM   #1 (permalink)
Thumbs up Nokia Siemens Double EDGE Speeds
Nokia Siemens Networks' Dual Carrier EDGE solution, which will be available as a software upgrade, is the first step in evolving EDGE. Dual Carrier is based on the 3GPP release 7 standard. As a strong innovator of EDGE Evolution, Nokia Siemens Networks already has additional plans to introduce in its networks the next substantial step, the so called EGPRS 2B, to further double the end user experience in up- and downlink performance. This will result in downlink speeds of up to 1.2 Mbps and will double uplink speed to up to 473 kbps, thus quadrupling the capabilities of EDGE today.
GSM/EDGE operators can serve their customers even better using the Dual Carrier solution as the demand for data services and connectivity is booming, proven by the steep increase on mobile broadband traffic in 3G/HSPA networks today. With Dual Carrier solution, 3G/HSPA operators can offer better service continuity for their data services.
Source: http://tech2.in.com/india/news/mobil...speeds/53491/0
ThinkFree is offline
Old 09-12-2008, 06:57 PM   #2 (permalink)
Linux all the way
Default Re: Nokia Siemens Double EDGE Speeds
thats quite close to 3G network.. what are their real world speed expectations??
At times life takes a U turn and you get back where you were...
Vishal Patil is offline
Old 09-12-2008, 11:19 PM   #3 (permalink)
Tech.Masti's Avatar
I already posted it some months ago
Tech.Masti is offline
BSNL Nokia Siemens c2110 configuration:help !! GeekyBoy PC Components / Configurations 1 08-09-2008 02:20 PM
how to configure bsnl nokia siemens c2110 entrana Broadband and DTH 4 17-06-2008 09:19 AM
Slow speeds on Airtel GRPS even with EDGE gary4gar Mobiles and Tablets 30 27-09-2007 08:16 PM
Bluetooth & EDGE Speeds rollcage Mobiles and Tablets 7 02-11-2006 11:41 AM
