Go Back   Digit Technology Discussion Forum > News > Technology News
Technology News News from the world of technology that our members stumble across. NOTE: Sources to be mentioned at the beginning of each post.
Old 12-11-2008, 05:40 PM   #1 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
Smile Microsoft Releases Direct3D 11 Technical Preview for Developers
Microsoft Corp. has issued DirectX software development kit (SDK) that contains basic technical preview of Direct3D 11. Even though the preview does not expose all the features of DirectX 11, it gives a signal to software developers that Direct3D 11 is around the corner and that they can take advantage of appropriate functionality.
This version of the Direct3D 11 technical preview includes support for the following:
Tessellation
Direct3D 11 provides additional pipeline stages to support real-time tessellation of high order primitives. With extensively programmable capabilities, this feature allows many different methods for evaluating high-order surfaces, including subdivision surfaces using approximation techniques, Bezier patches, adaptive tessellation, and displacement mapping. This feature will only be available on Direct3D 11-class hardware, so in order to evaluate this feature you will need to use the Reference Rasterizer. For a demo of tessellation in action, check out the SubD11 sample available through the Sample Browser.
Compute Shader
The Compute Shader is an additional stage independent of the Direct3D 11 pipeline that enables general purpose computing on the GPU. In addition to all shader features provided by the unified shader core, the Compute Shader also supports scattered reads and writes to resources through Unordered Access Views, a shared memory pool within a group of executing threads, synchronization primitives, atomic operators, and many other advanced data-parallel features. A variant of the Direct3D 11 Compute Shader has been enabled in this release that can operate on Direct3D 10-class hardware. It is therefore possible to developing Compute Shaders on actual hardware, but an updated driver is required. The full functionality of the Direct3D 11 Compute Shader will is intended for support of Direct3D 11-class hardware, so in order to evaluate the full functionality you will need to use the Reference Rasterizer until such hardware is available. For a demo of the Compute Shader in action, check out the HDRToneMappingCS11 sample available through the Sample Browser.
Multithreaded Rendering
The key API difference from Direct3D 10 in Direct3D 11 is the addition of deferred contexts, which enables scalable execution of Direct3D commands distributed over multiple cores. A Deferred Context captures and assembles actions like state changes and draw submissions that can be executed on the actual device at a later time. By utilizing Deferred Contexts on multiple threads, an application can distribute the CPU overhead needed in the Direct3D11 runtime and the driver to multiple cores, enabling better use of an end-user's machine configuration. This feature is available for use on current Direct3D 10 hardware as well as the reference rasterizer. For a demonstration of API usage, check out the MultithreadedRendering11 sample available through the Sample Browser.
Dynamic Shader Linkage
In order to address the combinatorial explosion problem seen in specializing shaders for performance, Direct3D 11 introduces a limited form of runtime shader linkage that allows for near-optimal shader specialization during execution of an application. This is achieved by specifying the implementations of specific functions in shader code when the shader is assigned to the pipeline, allowing the driver to inline native shader instructions quickly rather than forcing the driver to recompile the intermediate language into native instructions with the new configuration. Shader development is exposed through the introduction of classes and interfaces to HLSL. For a demonstration, check out the Dynamic Shader Linkage 11 sample available through the Sample Browser.
Windows Advanced Rasterizer Platform (WARP)
Available in this SDK through Direct3D 11 and eventually also through Direct3D 10.1, WARP is a fast, multi-core scaling rasterizer that is fully Direct3D 10.1 compliant. Utilizing this technology is as simple as passing the D3D10_DRIVER_TYPE_WARP flag in your device creation.
Direct3D 10 and Direct3D 11 on Direct3D 9 Hardware (D3D10 Level 9)
Available in this SDK through Direct3D 11 and eventually also through Direct3D 10.1, the Direct3D API can target most Direct3D 9 hardware as well as Direct3D 10, Direct3D 10.1 and Direct3D 11 hardware. This is achieved by providing the Feature Level mechanism, which groups hardware into six categories depending on functionality: 9_1, 9_2, 9_3, 10_0, 10_1 and 11_0. A card only meets a feature level if it is fully compliant to that level, and each level is a strict super-set of those below it. Functionality is minimally emulated to assure no unexpected performance cliffs are encountered. Thus, features like Geometry Shaders are not available for Direct3D 9 level targets.
Runtime Binaries
All runtime binaries provided in the Direct3D 11 tech preview that will be available on Windows 7 and Windows Vista SP1 are installed with the SDK and are labeled as "Beta" components (i.e. D3D11_beta.DLL). All beta-labeled components are time-bombed. To create projects to evaluate these new components, you must link to their equivalent beta-labeled import libraries (i.e. D3D11_beta.lib). If you have a PDC copy of Windows 7, the headers, libs, and pdbs provided in the Windows SDK with the build are appropriate for development using the Direct3D 11 components providing in Windows 7. Please reserve the use of the headers, libs, and pdbs in this SDK to the beta components provided herein.
D3DX11
D3DX11 current only supports texture loading functions for Direct3D 11 resources. In the future, this component will provide many of the technologies available in D3DX10 like a mesh container format as well as the Effects 11 system. An important difference between D3DX11 and D3DX10 is that D3DX11 does not contain shader compilation functionality. Instead this is provided directly through the D3D Compiler component, described below.
HLSL and Direct3D Compiler
The HLSL compiler has several new features for supporting the new technologies available in Direct3D 11. This includes object oriented programming through interfaces and classes, a direct indexing syntax for resource loads, and the 'precise' keyword for ensuring that all operations performed with a specific variable adhere to the strict floating point rules. Almost all new linguistic features have valid functionality on existing shader targets. In addition to supporting all Direct3D 9, Direct3D 10, Direct3D 10.1, and Direct3D 11 shaders the HLSL compiler also supports the special targets needed to write shaders for Direct3D 10 Level 9 targets. The D3D Compiler is now directly accessible outside of D3DX10 and D3DX11 through D3DCompiler.H and D3DCompiler.lib. With these new files, an application is not required to link to D3DX in order to perform runtime compilation, and an application is not required to include the compiler if only D3DX functionality is needed.
D3D11 Reference Rasterizer
The Reference Rasterizer provides a gold-standard rasterization implementation for evaluation of Direct3D 11 features not yet available in hardware. The Reference Rasterizer is also provided as a way to verify a specific hardware implementation's accuracy to the rasterization standard. The reference rasterizer is designed for correctness, not performance. To create a reference device, simply pass the D3D_DRIVER_TYPE_REFERENCE flag at device creation.
D3D11 SDK Layers
Direct3D11 SDK Layers provide a mechanism for tracking the operation of the Direct3D 11 runtime during development. Currently this is used for providing useful debug information, which not only includes errors on improper use but also warnings that recommend best practice use of the runtime and often provides in-depth, useful information for debugging. It is highly recommended that the debug output from D3D11 SDK Layers is turned on at all times during development and an application generates no debug output during execution before it is released or used with PIX for Windows for profiling. Enabling the debug layer is as simple as passing the D3D11_CREATE_DEVICE_DEBUG flag at device creation time. Developers are strongly encouraged to use layers in debug builds. Layers are not recommended for use in profile or release builds.
Source
Dell 15z + WD 2TB
Dell Studio 1555 + WD 1TB
iPhone 4 32 GB
Samsung Galaxy S2 White
Good Desktop Power Of C2D + 4850
NIGHTMARE is offline
Old 12-11-2008, 05:58 PM   #2 (permalink)
M3TAL H3AD M3
skippednote's Avatar
Default Re: Microsoft Releases Direct3D 11 Technical Preview for Developers
Great update.
I spit Rainbows.
skippednote is offline
Microsoft to ODF Technical Committee: Come Enter the Belly of the Beast praka123 Technology News 27 26-06-2008 01:58 AM
Microsoft Releases Preview of New Version of Its Robotics Platform iMav Technology News 1 10-04-2008 07:33 AM
MIX08 - Steve Ballmer screams “Web developers. Web developers. Web developers” naveen_reloaded Chit-Chat 9 13-03-2008 01:30 PM
Windows Vista 5600 Release Candidate 1 (RC 1) - A Technical Preview qudra Software Q&A 4 10-09-2006 03:45 PM
*[NEW!]* Opera 7.6 Technical Preview 3! [deXter] QnA (read only) 7 17-11-2004 07:21 PM
- by chris
