02-03-2009, 08:58 PM
#31 (permalink)
Here Since 2003
Re: DiskMax 3.1
Will it work in windows 7?
My Blog :: http://www.pallab.net
Twitter :: http://www.twitter.com/indyan
03-03-2009, 11:35 AM
#32 (permalink)
Developer
Re: DiskMax 3.1
Absolutely. It has been tested on Windows 7 beta. DiskMax will identify Windows 7 as Windows Vista because Win7 will start identifying itself as Win7 only when it hits RTM.
You will need to start DiskMax with administrative privileges if you need to perform all activities like clearing event logs, scanning other user accounts, defragmentation, etc.
I am not keen to make DiskMax refuse to run without administrative privileges so the duty of elevating it is left to the user. (Right-click and select 'Run as administrator' for those who don't know - all this will be in the documentation I am compiling)
03-03-2009, 07:20 PM
#33 (permalink)
Here Since 2003
Re: DiskMax 3.1
Installed it and gave it a whirl.
Here are a couple of screenshots :
# Detects Win7 as Win Vista.
# Recovered about 15gb.
Suggetion : #Add support for other popular browsers like Opera, Safari and Chrome.
# I would have the minimize and quit buttons at top right, in order to be consistent with windows ui.
05-03-2009, 06:41 AM
#34 (permalink)
"Aal Izz Well"
Re: DiskMax 3.1
good work..s/w looks cool..let me try...
http://twitter.com/krazzywarrior
05-03-2009, 10:22 AM
#35 (permalink)
Developer
Re: DiskMax 3.1
@Indyan
15GB? That's amazing. Your Windows installation must be pretty old to have accumulated that much junk... Or you are just a really heavy user..
I agree with your comments regarding the minimize and quit buttons but there is a programmatic reason why it had to be done this way... I intend to try to return to the Windows ui norm but I am pushing that to a release further down the line...
Thanks for your comments and screenshots!
05-03-2009, 05:12 PM
#36 (permalink)
Here Since 2003
Re: DiskMax 3.1
I installed the beta build in 2nd or 3rd week of Januaury. And I had used Tuneup Disk Cleaner a couple of weeks back. So it's certainly impressive.
05-03-2009, 05:19 PM
#37 (permalink)
Re: DiskMax 3.1
OT: Indyan dude .. check ur inbox ...
Edit : Thanx buddy for the prompt action.
Wats the Favourite Mathematical Function of DIGIT FORUM ????
Its "A SINE WAVE" constant
Y ??
They Both keep going "UP AND DOWN, UP AND DOWN............" !!!!!!!!
05-03-2009, 05:20 PM
#38 (permalink)
Legen-wait for it-dary!
Re: DiskMax 3.1
@Indyan
How old is that win7? On a freshly installed win7 build 7022, DM shaves off 570 MB or so.
05-03-2009, 06:39 PM
#39 (permalink)
Here Since 2003
Re: DiskMax 3.1
I already started the install date.^
Anyway, its so huge because of the large number of softwares I have installed.
12-03-2009, 10:36 PM
#40 (permalink)
Re: DiskMax 3.1
is there no way to use this software without registering over the internet?i have a few friends who wanted to use it but they do not have an internet connection.
View my Portfolio here-
Pixels and Polygons | On Linkedin | On Facebook
Available for freelance. PM me for details.
MSI 890 GXM G65, Phenom X6 1055T, G.Skill 1600Mhz "Ripjaws" 2x2gb Kit, MSI GTX 470, WD Black 500Gb, NZXT Gamma, Corsair Vx550, Hp 22x DVD-Rw, Benq G2420HD, Logitech Mx-518, Xbox 360 Gamepad for PC
13-03-2009, 09:44 AM
#41 (permalink)
Developer
Re: DiskMax 3.1
DiskMax 3
"Registration" is actually a request placed for a web counter (like the one on webpages) which will increment on each request so that I know how many installs have taken place. It will try to connect for about 3 times and then time out if unsuccessful. DiskMax will then start running as usual. However, unless registered, the user will have to go through this whole cycle every time DiskMax is started. (The same repeats for an update check)
I request that, if possible, the user "registers" DiskMax so that looking at the popularity of my various applications, I can decide which one I can allocate more of my time to for improvement.
DiskMax 4
This version is much more relaxed about the whole thing. There is an update check about 3 days after install so that users can evaluate the program before allowing it to connect to the internet to check for updates. If the user decides not to check for updates, there is a penalty waiting period of 15 seconds before DiskMax 4 starts up and works as usual. Please note that, as stated in the EULA, no information of any sort is ever transmitted onto the internet at any time.
I have included an professional help file in the latest copy of DiskMax 4 available. Those of you who are using it, please tell me if the help file explains everything about DiskMax clearly.
16-04-2009, 09:59 PM
#42 (permalink)
Developer
Re: DiskMax 3.1
DiskMax 4 is now compatible with Windows XP/2003.
DiskMax 3 has been discontinued.
Please read the first post for more...
